Winapp2.ini additions
Winapp2.ini
  • Moderators
merging entries
If it makes 1) your job easier and 2) makes the file smaller in MB, then I'm for it.
Link to comment
Ditto!
Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System);  Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC.  ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system):   Bitdefender Internet Security 2022, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD22, MSI AfterBurner, Rainmeter, Windows Sidebar, and many more.
Link to comment
I think piriform implementing colon delimiting for RegKeys (the way FileKeys are) would have the most dramatic effect on the file size :D one can dream (my math suggests this change, if implemented in winapp.ini would save ~23KB - not a lot but huge when considering how much ccleaner gets downloaded - and not all filekeys are delimited this way either so there's room for more!)
Link to comment
I wonder if Smalik will return once it's up on GitHub. I know he didn't seem to like it here at Piriform anymore, but I would hate to have to lose someone who was so dedicated to this project.
I am a maintainer for Winapp2. I also have a open-source group on Steam.
http://steamcommunity.com/groups/opencommunity
Link to comment
Thank you very much for your kind words. I'll definitely join you guys on Github.
Link to comment
New Entries
[CorelDRAW Graphics Suite X7*]
LangSecRef=3021
Detect=HKCU\SOFTWARE\Corel\CorelDRAW\17.0
Default=False
FileKey1=%ProgramFiles%\Corel\CorelDRAW Graphics Suite X7\Setup|*.*|REMOVESELF
FileKey2=%CommonAppData%\Bitstream\Font Navigator\6.0\Cache|*.*|RECURSE
FileKey3=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Draw\Export|dialog.export.web.xml
FileKey4=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Draw\Presets\HTML Export|default.pst
FileKey5=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Config|corelpdf.ini
FileKey6=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Draw|FindAndReplaceMRU.xml
FileKey7=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Draw\PreviewCache|*.*|RECURSE
FileKey8=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Connect|Connect.config
FileKey9=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Config|corelpdf.ini
FileKey10=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\PHOTO-PAINT\PreviewCache|*.*|RECURSE
FileKey11=%LocalAppData%\Corel\CorelDRAW Graphics Suite X7\Config|capture.ini
RegKey1=HKCU\Software\Bitstream\Font Navigator\6.0\Copy|Folders
RegKey2=HKCU\Software\Bitstream\Font Navigator\6.0\Move|Folders
RegKey3=HKCU\Software\Corel\CorelDRAW\17.0\Draw\Application Preferences\Directories|DrawDocsDir
RegKey4=HKCU\Software\Corel\CorelDRAW\17.0\Draw\Application Preferences\Framework|RecentFiles
RegKey5=HKCU\Software\Corel\CorelDRAW\17.0\Draw\Application Preferences\HTML Export|DestPath
RegKey6=HKCU\Software\Corel\CorelDRAW\17.0\Draw\Application Preferences\NewFromTemplate|BrowseTemplateDir
RegKey7=HKCU\Software\Corel\CorelDRAW\17.0\PHOTO-PAINT\Application Preferences\Framework|RecentFiles
[Foxit PhantomPDF 8*]
LangSecRef=3021
Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0
Default=False
FileKey1=%LocalAppData%\Foxit PhantomPDF\msilog|*.log
FileKey2=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.ds
FileKey3=%AppData%\Foxit Software\RMS|FXRMS_Log.txt
RegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\MRU\File MRU
RegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\MRU\Place MRU
RegKey3=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\Preferences\History
RegKey4=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\Recent File List
RegKey5=HKCU\Software\Foxit Software\Foxit PhantomPDF 8.0\Foxit PhantomPDF Advanced Editor\Recent File List
[Kodi Crash Logs*]
LangSecRef=3023
DetectFile=%AppData%\kodi
Default=False
FileKey1=%AppData%\kodi|*.dmp
[Kodi Logs*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\kodi|*.log
[Temporary ASP.NET Files*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\.NETFramework
Default=False
FileKey1=%WinDir%\Microsoft.NET\Framework\*\Temporary ASP.NET Files|*.*|REMOVESELF
FileKey2=%WinDir%\Microsoft.NET\Framework64\*\Temporary ASP.NET Files|*.*|REMOVESELF
Link to comment
Revised Entries
[Adobe Patch Files*]
LangSecRef=3021
Detect=HKCU\Software\Adobe
Default=False
FileKey1=%ProgramFiles%\Adobe\Adobe\AdobePatchFiles|*.*|RECURSE
FileKey2=%ProgramFiles%\Common Files\Adobe\Adobe\AdobePatchFiles|*.*|RECURSE
FileKey3=%CommonAppData%\Adobe\CameraRaw\Adobe\AdobePatchFiles|*.*|RECURSE
Added:
[Adobe Premiere Elements 11*]
LangSecRef=3023
Detect=HKCU\Software\Adobe\Premiere Elements\11.0
Default=False
RegKey1=HKCU\Software\Adobe\Premiere Elements\11.0\MRUDocuments
FileKey1=%CommonAppData%|StreamingMediaTechnologyLog.txt
FileKey2=%AppData%\Adobe\Common\Thumbnail Cache|*.*|RECURSE
FileKey3=%Documents%\Adobe\Premiere Elements\11.0|*.log
FileKey4=%Documents%\NewBlueFX\Logs|*.log;*.txt
Added: %CommonAppData%|StreamingMediaTechnologyLog.txt
[Adobe Premiere Elements 12 More*]
LangSecRef=3023
Detect=HKCU\Software\Adobe\Premiere Elements\12.0
Default=False
RegKey1=HKCU\Software\Adobe\Premiere Elements\12.0\MRUDocuments
FileKey3=%Documents%\Adobe\Premiere Elements\12.0|*.log
[Adobe Premiere Elements 13*]
LangSecRef=3023
Detect=HKCU\Software\Adobe\Premiere Elements\13.0
Default=False
RegKey1=HKCU\Software\Adobe\Premiere Elements\13.0\MRUDocuments
FileKey3=%Documents%\Adobe\Premiere Elements\13.0|*.log
FileKey4=%Documents%\NewBlueFX\Logs|*.txt
[Ashampoo Burning Studio 16*]
LangSecRef=3024
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16
Default=False
FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 16\log|*.xml;*.txt
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Backup Project\BackupOptions|CustomLocation
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\BDMV Disc Project\SelectBDMVFolder|BdmvPath
RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\BrowseImageFile|ImagePath
RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Burn Image Project\SelectImage|ImagePath
RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\DumpImage|ImagePath
RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\MoviesPage|Path
RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\DVD-Video Disc Project\SaveDialog_authed.CMoviesPage.Movies|InitialDirectory
RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Logs
RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\tempFiles
RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Unknown Project
RegKey15=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey16=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey17=HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
Added: HKCU\Software\Ashampoo\Ashampoo Burning Studio 16\Data Disc Project\DumpImage|ImagePath
[Ashampoo Burning Studio 2016*]
LangSecRef=3024
Detect=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016
Default=False
FileKey1=%AppData%\Ashampoo\Ashampoo Burning Studio 2016\log|*.xml;*.txt
RegKey1=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Audio Disc Project\SaveDialog_CPlaylistDlgEx|InitialDirectory
RegKey2=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Backup Project\BackupOptions|CustomLocation
RegKey3=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\BrowseImageFile|ImagePath
RegKey4=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Browse Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey5=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SaveDialog_SelectImageBrowse|InitialDirectory
RegKey6=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Burn Image Project\SelectImage|ImagePath
RegKey7=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\SaveDialog_AddFilesAndDirs|InitialDirectory
RegKey8=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Data Disc Project\DumpImage|ImagePath
RegKey9=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Logs
RegKey10=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\tempFiles
RegKey11=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\Unknown Project
RegKey12=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VCD Project\SaveDialog_OnAddMovies|InitialDirectory
RegKey13=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\DumpImage|ImagePath
RegKey14=HKCU\Software\Ashampoo\Ashampoo Burning Studio 2016\VIDEO_TS Disc Project\SelectVideoTSFolder|VideoTSPath
Added lots of new paths.
[Hauppauge WinTV*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Hauppauge
Default=False
FileKey1=%SystemDrive%\|hcwDriverInstall.txt
FileKey2=%Public%\Videos\Pause Buffer|*.*|RECURSE
FileKey3=%Public%\WinTV\Channel Database|hcwChanDB_5-lastgood.mdb
FileKey4=%Public%\WinTV\Logs\minidump|*.*|RECURSE
FileKey5=%Public%\WinTV|Settings-old.xml
Added:
Link to comment
The entries listed below should be removed. The reasons are listed under each entry.
[Aiseesoft Studio Logs*]
There is no such program with this name that exists and because of Detect=HKCU\Software\Aiseesoft Studio, it conflicts with current [Aiseesoft Media Converter Ultimate*] entry. Looks like someone made a universal entry to wipe all of the Aiseesoft program's logs.
[Apple Installer Cache*]
iTunes can't be removed completely if there are no Installer files in these locations.
[Cached File Extensions*]
It's not cache. I mistakenly provided this entry. It removes valid file extensions.
[Video Converter Pro*]
The current [Leawo Video Converter Pro*] entry and this one are the same.
[Wondershare MobileGo for iOS*]
[Wondershare MobileGo*] entry covers this one.
Link to comment
Welcome back SMalik!
This entry should be removed.  It is actually for jv16 PowerTools and removes a .bak file which is against the standing rules for Winapp2.ini.  File hosts_PTBackup*.bak is created when jv16 PowerTools "Immunize my Computer" tool inserts the MVPS entries into the HOSTS file.  Removing hosts_PTBackup*.bak prevents the user from being able to restore the HOSTS file back to the original.
[MaceCraft PowerTools hosts backups*]
LangSecRef=3024
Default=False
DetectFile=%ProgramFiles%\jv16 PowerTools *\jv16PT.exe
FileKey1=%WinDir%\System32\drivers\etc|hosts_PTBackup*.bak
Link to comment
LangSecRef=3024
Default=False
Thank you.
Link to comment
Revised Entry
[Microsoft Edge More*]
LangSecRef=3022
Detect=HKCU\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.MicrosoftEdge_8wekyb3d8bbwe
DetectFile=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_8wekyb3d8bbwe
Default=False
FileKey1=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!001\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey2=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\#!002\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey3=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\Microsoft\CryptnetUrlCache|*.*|RECURSE
FileKey4=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Data|*.*|RECURSE
FileKey5=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AC\MicrosoftEdge\User\Default\DataStore\Indexed\Data|*.*|RECURSE
FileKey6=%LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AppData\User\Default\Indexed DB|*.*|RECURSE
Added: %LocalAppData%\Packages\Microsoft.MicrosoftEdge_*\AppData\User\Default\Indexed DB|*.*|RECURSE
Link to comment
  • Moderators
What about this other one (don't remember if you created it or not), just wondering that's all:
[Cached Shell Extensions*]
Link to comment
Dunno if this is the right thread to ask but Trim.bat is not working properly for me. After I input O (for it to organize) it just crashes and even if I input S (for it to skip) it also crashes after it's done analyzing via debug CCleaner. Any insights please?
Link to comment
  • Moderators
which windows?
Link to comment
try deleting the #TRIMMER folder.
WFM windows 10
Link to comment
Still the same.
Also it's saying that 'MORE' is not recognized as an internal or external command upon starting the trim.bat.
Try what dvdbane said. If none of those work, make sure you are not running CCleaner (even in background, check task manager to make sure) and make sure to run trim.bat as admin rights. If none of those work, try running it under safe mode. That has sometimes helped for me.
Link to comment
redownload trim.bat from winapp2.com and re-try
Tried that a couple of times still the same.
I tried this as well. I made sure that CCleaner is not running even on background. I also made sure that I give admins rights to the bat file (cause the trim.bat warns if you don't). However I haven't tried running it on safe mode. I'll try it later today and report back if it works. Thanks.
Link to comment
It's not cache. It removes valid file extensions. I think it explains itself.
If someone has CCleaner Professional and uses one user account to clean all user accounts on the machine, it deletes all valid file extensions from the user accounts that are not logged in. Also, even if someone has CCleaner Free edition with one use account and runs CCleaner in Safe Mode, it still removes all valid file extensions. In normal mode, CCleaner won't remove file extensions because the user hive is in use.
Link to comment
Okay I've tried running trim.bat on safe mode... still the same... it just closes as soon as i press organize and skip.
Link to comment
Any updates on this issue? It's a pain to launch CCleaner with 2k entries on the winapp2. VOLDEMORT has a trim function but it doesn't preserve the some of the checked item for Google Chrome.
Link to comment
Register a new account
Sign in
Important Information
