Moderators Nergal 0 Posted May 9, 2014 Moderators Share Posted May 9, 2014 [Adobe Media Cache*] "Detect" path should be corrected. I think the first one is better. Unless it only valid for Creative Suite Version 6 I agree with the first being better ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Hav0c 0 Posted May 9, 2014 Share Posted May 9, 2014 Seems to be a bit of confusion with the Malwarebytes Anti-Malware. Combine entry [Malwarebytes Anti-Malware More*] LangSecRef=3024 Detect=HKLM\Software\Microsoft\Windows\CurrentVersion\App Paths\mbam.exe Default=False FileKey1=%CommonAppData%\Malwarebytes\Malwarebytes Anti-Malware\Logs|*.* FileKey2=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* FileKey3=%AppData%\Malwarebytes\Malwarebytes' Anti-Malware\Logs|*.* FileKey4=%CommonAppData%\Malwarebytes\Malwarebytes' Anti-Malware|mbam-setup.exe for version 2 and pre. There is nothing missing in FileKey1 as it is for version 2, FileKey2 is for pre version 2. The Detect used works for version 1.75 on my system. cant see why Detect1=HKCU\Software\Malwarebytes' Anti-Malware was added ?? Every line of code written by man can be undone by man . "A loser in the real world is still a loser in the net!" - .hack//SIGN . Getting old is inevitable, growing up is optional !! Link to post Share on other sites
SMalik 0 Posted May 10, 2014 Share Posted May 10, 2014 Unless it only valid for Creative Suite Version 6 I agree with the first being better I never had CS6 on my system. All I have is just Photoshop Elements 11 and Premiere Elements 11. I don't know which one from these two programs created this key: HKCU\Software\Adobe\Common CS6\Media Cache Link to post Share on other sites
Winapp2.ini 0 Posted May 10, 2014 Author Share Posted May 10, 2014 Likely anything part of the creative suite, the media cache is likely a shared component winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
APMichael 0 Posted May 10, 2014 Share Posted May 10, 2014 Shouldn't FileKey2 be? [Avidemux log*]LangSecRef=3023Detect1=HKLM\Software\Avidemux 2.4Detect2=HKLM\Software\Avidemux 2.5Detect3=HKLM\Software\Avidemux 2.6Default=FalseFileKey1=%AppData%\avidemux|admlog.txtFileKey2=%LocalAppData%\VirtualStore\Program Files (x86)\Avidemux*|admlog.txt Link to post Share on other sites
nodles 0 Posted May 10, 2014 Share Posted May 10, 2014 MODIFIED ENTRY [Adobe Acrobat XI More*] LangSecRef=3021 Detect=HKCU\Software\Adobe\Adobe Acrobat DetectFile1=%LocalAppData%\Adobe\Acrobat Default=False FileKey1=%LocalAppData%\Adobe\Acrobat|*.idx|RECURSE FileKey2=%LocalAppData%\Adobe\Acrobat\11.0|UserCache.bin FileKey3=%LocalAppData%\Adobe\Acrobat\11.0\Cache|*.* Added DF1. Do you think these could be added? Lenovo SWTOOLS folder contains driver installation files which usually ain't needed after first install (same as AMD/ATI entry). [Lenovo SWTOOLS*] LangSecRef=3025 DetectFile=%HomeDrive%\SWTOOLS Default=False FileKey1=%HomeDrive%\SWTOOLS|*.*|REMOVESELF There's also C:\Drivers folder which contains driver installation files. The folder was created during Lenovo driver install/update, but some other manufacturers might use the same folder. [Driver Installation Files*] LangSecRef=3025 DetectFile=%HomeDrive%\Drivers Default=False FileKey1=%HomeDrive%\Drivers|*.*|REMOVESELF Link to post Share on other sites
JDPower 0 Posted May 10, 2014 Share Posted May 10, 2014 There's also C:\Drivers folder which contains driver installation files. The folder was created during Lenovo driver install/update, but some other manufacturers might use the same folder. Dell also tend to create that folder for unpacking driver files too Link to post Share on other sites
Winapp2.ini 0 Posted May 10, 2014 Author Share Posted May 10, 2014 Did we decide on a way to handle VirtualStore? For every %ProgramFiles% path, we need to mirror it for VirtualStore, should I just do %LocalAppData%\VirtualStore\Program Files*\ so that it works cross bit? winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Coffee4Joe 0 Posted May 11, 2014 Share Posted May 11, 2014 Not sure if this is a bug or the store being stubborn. For some reason in Store* "FileKey13=%LocalAppData%\Packages\winstore_*\LocalState\Cache" doesn't get fully cleaned but can be manaully removed. Added FileKey2Gimp creates that webkit folder if you use the Create From Webpage option. [GIMP 2.8 More*] LangSecRef=3021 DetectFile=%UserProfile%\.gimp-2.8\ Default=False FileKey1=%LocalAppData%|recently-used.xbel FileKey2=%LocalAppData%\webkit|*.*|REMOVESELF Link to post Share on other sites
siliconman01 0 Posted May 11, 2014 Share Posted May 11, 2014 Modified Entry: Added FileKey3 [Snagit 11 More*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\11 Default=False Warning=This will delete the backups of the captures that you have performed with SnagIt 11. FileKey1=%LocalAppData%\TechSmith\Snagit|*.bin FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf;*.SNAG;*.SNAGundo;*.MP4 FileKey3=%Documents%\|SnagItDebug.log RegKey1=HKCU\Software\TechSmith\Snagit\11|CaptureCount RegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Moderators Nergal 0 Posted May 11, 2014 Moderators Share Posted May 11, 2014 Did we decide on a way to handle VirtualStore? For every %ProgramFiles% path, we need to mirror it for VirtualStore, should I just do %LocalAppData%\VirtualStore\Program Files*\ so that it works cross bit? No because VS is only made by programs not fixed for vista/7/8 and only some of them (the ones that try to store in program folder but don't run with UAC elevation and the ones (I think) set to run as XP or lower in compatibility mode) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted May 12, 2014 Author Share Posted May 12, 2014 So basically any program run with UAC enabled that tries to write log files to the program files directory will return a virtualstore entry, from my limited testing of it winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted May 12, 2014 Moderators Share Posted May 12, 2014 So basically any program run with UAC enabled that tries to write log files to the program files directory will return a virtualstore entry, from my limited testing of it Yup ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
ROCKNROLL 0 Posted May 12, 2014 Share Posted May 12, 2014 EDIT: [starCraft II Logs*]Section=GamesDetect=HKCU\Software\Blizzard Entertainment\StarCraft IIFileKey1=%ProgramFiles%\Starcraft II\Logs|*.*FileKey2=%Public%\games\Starcraft II\Logs|*.*FileKey3=%SystemDrive%\Starcraft II\Logs|*.*FileKey4=%Documents%\StarCraft II\GameLogs|*.*|RECURSE Added FileKey 4. I am a maintainer for Winapp2. I also have a open-source group on Steam. http://steamcommunity.com/groups/opencommunity Link to post Share on other sites
Winapp2.ini 0 Posted May 12, 2014 Author Share Posted May 12, 2014 Next update will be fairly big then, since a lot of filekeys point to logs/caches created in program files. I'll probably leave those out of the HTML page for my sanity winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Moderators Nergal 0 Posted May 13, 2014 Moderators Share Posted May 13, 2014 Next update will be fairly big then, since a lot of filekeys point to logs/caches created in program files. I'll probably leave those out of the HTML page for my sanity [OPINION]if the developers don't do it I wouldn't bother unless a certain one is suggested, and even then I'm sure Piriform knows better than us on this one [/] ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Winapp2.ini 0 Posted May 13, 2014 Author Share Posted May 13, 2014 [OPINION]if the developers don't do it I wouldn't bother unless a certain one is suggested, and even then I'm sure Piriform knows better than us on this one [/] oooh.. too late.. I already tweaked over 300 entries lol.. I suppose I could undo it, I did make a backup first winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted May 13, 2014 Share Posted May 13, 2014 This entry is in CCleaner now. Please keep the cleaning path ones that are not in the CCleaner entry and change the entry name to [Wondershare Video Converter Ultimate More*][Wondershare Video Converter Ultimate*]LangSecRef=3023Detect=HKLM\Software\Wondershare Video Converter UltimateDefault=FalseFileKey1=%ProgramFiles%\Wondershare Video Converter Ultimate\Log|*.*|RECURSEFileKey2=%ProgramFiles%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|RECURSEFileKey3=%CommonAppData%\Wondershare Video Converter Ultimate|*.dat.bakFileKey4=%CommonAppData%\Wondershare Video Converter Ultimate\TempSiteIconDir|*.*|RECURSEFileKey5=%CommonAppData%\Wondershare Video Converter Ultimate\TempThumbDir|*.*|RECURSESame issue with this one. Also, change the name to [Wondershare Video Converter Pro More*] and change the "Wondershare Video Converter*" with "Wondershare Video Converter Pro".[Wondershare Video Converter*]LangSecRef=3023Detect=HKLM\Software\Wondershare\Wondershare Video Converter ProDefault=FalseFileKey1=%AllUsersProfile%\Documents\Wondershare|*.*|REMOVESELFFileKey2=%CommonAppData%\Wondershare Video Converter*|*.dat.bakFileKey3=%CommonAppData%\Wondershare Video Converter*\TempSiteIconDirFileKey4=%CommonAppData%\Wondershare Video Converter*\TempThumbDirFileKey5=%ProgramFiles%\Wondershare\Video Converter*\Log|*.*|REMOVESELF Link to post Share on other sites
Winapp2.ini 0 Posted May 13, 2014 Author Share Posted May 13, 2014 Thanks winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
SMalik 0 Posted May 13, 2014 Share Posted May 13, 2014 Thanks Can you please post the entries here after you fix them? Link to post Share on other sites
siliconman01 0 Posted May 13, 2014 Share Posted May 13, 2014 New entries for SnagIt 12: [Snagit 12 Local Dumps (.dmp)*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\12 Default=False Warning=This will delete the local dump files (.dmp) automatically created SnagIt 12 if it encounters an error/crash. FileKey1=%LocalAppData%\TechSmith\Snagit\CrashDumps|*.* [Snagit 12 More*] LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\12 Default=False Warning=This will delete the backups of the captures that you have performed with SnagIt 12. FileKey1=%LocalAppData%\TechSmith\Snagit|*.bin FileKey2=%LocalAppData%\TechSmith\Snagit\DataStore|*.sdf;*.SNAG;*.SNAGundo;*.MP4 FileKey3=%Documents%\|SnagItDebug.log RegKey1=HKCU\Software\TechSmith\Snagit\12|CaptureCount RegKey2=HKCU\Software\TechSmith\Snagit\Stamps|StampCustomFolder [Snagit 12*] ID=2293 LangSecRef=3024 Detect=HKCU\Software\TechSmith\SnagIt\12 Default=True RegKey1=HKCU\Software\TechSmith\SnagIt\12\Recent Captures RegKey2=HKCU\Software\TechSmith\SnagIt\12\SnagItEditor\Recent File List FileKey1=%LocalAppData%\TechSmith\SnagIt|Tray.bin FileKey2=%LocalAppData%\TechSmith\SnagIt\DataStore\AppIcons|*.* FileKey3=%LocalAppData%\TechSmith\SnagIt\DataStore\WebSiteIcons|*.* FileKey4=%LocalAppData%\TechSmith\SnagIt\Thumbnails|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
Winapp2.ini 0 Posted May 13, 2014 Author Share Posted May 13, 2014 Can you please post the entries here after you fix them? Will do winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
siliconman01 0 Posted May 14, 2014 Share Posted May 14, 2014 New Entry: {Start Menu Reviver (Logs)*] [Start Menu Reviver (Logs)*] LangSecRef=3024 Detect=HKLM\Software\Start Menu Reviver Default=False FileKey1=%ProgramFiles%\ReviverSoft\Start Menu Reviver\Logs\|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 980 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA Nvidia GeForce 980 Titan card (Home Built System); Windows 10 x64 Pro on Dell 8700 SE desktop, Intel i7 4770 CPU, 24 gbyte RAM, Samsung 850 EVO mSATA 512 gbyte SSD, Samsung 850 Pro 512 gbyte SSD, Nvidia 750 Ti: Windows 10x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet. ASUS RT-AC88U router, 8 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2019 (Local), Casper 10, DisplayFusion (3 Flat Panel Displays per system): Kaspersky Internet Security 2021, Malwarebytes 4, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD20, MSI Burner, Rainmeter, Windows Sidebar, WD Smartware and many more. Link to post Share on other sites
SMalik 0 Posted May 15, 2014 Share Posted May 15, 2014 Revised Entries [Aimersoft Helper Compact*]LangSecRef=3021Detect=HKLM\Software\Aimersoft\Aimersoft Helper CompactDefault=FalseFileKey1=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact|ProductUpdateLists.xml;ASHelper.exe_temp;ASHelperSetup.exe_tempFileKey2=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Log|*.*|RECURSEFileKey3=%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Temp|*.*|RECURSEChanged the DetectFile to Detect.Added:%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact|ProductUpdateLists.xml;ASHelper.exe_temp;ASHelperSetup.exe_temp%CommonProgramFiles%\Aimersoft\Aimersoft Helper Compact\Temp|*.*|RECURSE[iSkysoft Helper Compact*]LangSecRef=3021Detect=HKLM\Software\iSkysoft\iSkysoft Helper CompactDefault=FalseFileKey1=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact|ProductUpdateLists.xml;ISHelper.exe_temp;ISHelperSetup.exe_tempFileKey2=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\Log|*.*|RECURSEFileKey3=%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\Temp|*.*|RECURSEAdded:%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact|ProductUpdateLists.xml;ISHelper.exe_temp;ISHelperSetup.exe_temp%CommonProgramFiles%\iSkysoft\iSkysoft Helper Compact\Temp|*.*|RECURSE[Wondershare Helper Compact*]LangSecRef=3021Detect=HKLM\Software\Wondershare\Wondershare Helper CompactDefault=FalseFileKey1=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_tempFileKey2=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Log|*.*|RECURSEFileKey3=%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSEAdded:%CommonProgramFiles%\Wondershare\Wondershare Helper Compact|ProductUpdateLists.xml;WSHelper.exe_temp;WSHelperSetup.exe_temp%CommonProgramFiles%\Wondershare\Wondershare Helper Compact\Temp|*.*|RECURSE Link to post Share on other sites
SMalik 0 Posted May 15, 2014 Share Posted May 15, 2014 Revised Entry [Foxit PhantomPDF 6 More*]LangSecRef=3021Detect=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0Default=FalseFileKey1=%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.dsFileKey2=%AppData%\Foxit Software\RMS|FXRMS_Log.txtRegKey1=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\Preferences\HistoryRegKey2=HKCU\Software\Foxit Software\Foxit PhantomPDF 6.0\RecentFilesAdded:%AppData%\Foxit Software\Foxit PhantomPDF\FormFiller|AutoComplete.ds Link to post Share on other sites
