CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
[intel Chipset Device Software (Install Logs)*]
LangSecRef=3024
Detect=HKLM\SOFTWARE\Intel\Infinst
Default=False
FileKey1=%ProgramFiles%\Intel\InfInst|*.*|REMOVESELF
FileKey2=%SystemDrive%\Intel\Logs|*.*
The only thing I had on my system was a ReadMe.txt file located in: %ProgramFiles%\Intel\InfInst
But of course my version is ages old that came from Dell for this XP system.
Edited by Andavari
Share this post
Link to post
This may not apply to winapp2.ini solely but thohgtI'd post here anyway.
The Windows Disk Cleanup (cleanmgr.exe) can be set to cleanup the following areas: (using windows 7 64 bit)
- Temporary setup files
- Downloaded Program files
- Temporary Internet Files
- Offline pages
- debug dump files
- old chkdsk files
- previous windows installations
- recycle bin
- service pack backup files
- setup log files
- system error memory dump files
- """"""""""""""" minidump files
- temporary files
- temporary windows installation files
- files discarded by windows upgrade
- per user archived windows error reporting files
- per user queued """"""""""""""""""""""""""""""""""""
- system archived """"""""""""""""""""""""""""""""""""
- system queued """"""""""""""""""""""""""""""""""""""
- windows upgrade log files
Which of these are already done by CCleaner (+ winapp2.ini) and their section and item names please?
Any more of these to be added ?
Share this post
Link to post
I downloaded and installed the software you mention.
To delete the folders would have deleted the uninstallers present.
I don't know how many different ways I have to say this, but you're wrong! Just cos that is the case on your system doesn't make it the case for every other.
Share this post
Link to post
- Offline pages
- debug dump files
- old chkdsk files
- recycle bin
- setup log files
- temporary files
Between CCleaner and Winapp2 that I can think of for sure
temp internet files
recycle bin
setup log is probably included between the two windows logs
WER is in both ccleaner and winapp2
Share this post
Link to post
%ProgramData%\Microsoft\RAC\PublishedData\*.*
%ProgramData%\Microsoft\RAC\StateData\*.*
to be included (?) in:
[MS Reliability Monitor*]
LangSecRef=3025
Detect=HKLM\Software\Microsoft\Reliability Analysis\RAC
Default=False
FileKey1=%CommonAppData%\Microsoft\RAC\Temp|*.*
from an email
Share this post
Link to post
Modified Entry: [Quicken Logs*] Added FileKey4
[Quicken Logs*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Intuit\Quicken
Default=False
FileKey1=%AppData%\Intuit\Quicken\Log|*.txt;*.log
FileKey2=%CommonAppData%\Intuit\Quicken\Log|*.log
FileKey3=%CommonAppData%\Intuit\Quicken\Log\installer|*.*|REMOVESELF
FileKey4=%ProgramData%\Intuit\SendError\|*.log|
Share this post
Link to post
Hi, it seems that "uTorrent more" delete too much files now ( all the settings, language, ipfilter,... ) !! :unsure:
BTW: it's perfect for new clean install, but only for that!!!
Share this post
Link to post
Already mentioned HERE, so will hopefully be removed in future update.
Share this post
Link to post
Yes, i know...but i not seen any answer!!
But ok, thx!! ;)
Share this post
Link to post
New Entry
To remove the Recents, you must remove FileKey7 (Adobe Photoshop Elements 12 Prefs.psp).
[Adobe Photoshop Elements 12*]
LangSecRef=3021
Detect=HKCU\Software\Adobe\Photoshop Elements\12.0
Default=False
RegKey1=HKCU\Software\Adobe\Elements Organizer\12.0\CurrentMediaFilePath
RegKey2=HKCU\Software\Adobe\Photoshop Elements\12.0\common\settings\Elements MRU
RegKey3=HKCU\Software\Adobe\Photoshop Elements\12.0\CurrentMediaFilePath
RegKey4=HKCU\Software\Adobe\Photoshop Elements\12.0\VisitedDirs|STARTUPIMAGEDIRECTORY
FileKey1=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|face.thumb.9.cache
FileKey2=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|thumb.5.cache
FileKey3=%CommonAppData%\Adobe\Elements Organizer\Catalogs\My Catalog|WaldoData\waldo.cache
FileKey4=%CommonAppData%\Adobe\Photoshop Elements\File Agent|WatchFolder.3.cache
FileKey5=%AppData%\Adobe\Elements Organizer\12.0\Organizer|status.dat
FileKey6=%AppData%\Adobe\Elements Organizer\12.0\Organizer|*.txt
FileKey7=%AppData%\Adobe\Photoshop Elements\12.0\Editor|Adobe Photoshop Elements 12 Prefs.psp
Share this post
Link to post
New Entry
LangSecRef=3021
Detect=HKCUSoftwareAdobePhotoshop Elements12.0
Default=False
RegKey1=HKCUSoftwareAdobeElements Organizer12.0CurrentMediaFilePath
RegKey2=HKCUSoftwareAdobePhotoshop Elements12.0commonsettingsElements MRU
RegKey3=HKCUSoftwareAdobePhotoshop Elements12.0CurrentMediaFilePath
RegKey4=HKCUSoftwareAdobePhotoshop Elements12.0VisitedDirs|STARTUPIMAGEDIRECTORY
FileKey1=%CommonAppData%AdobeElements OrganizerCatalogsMy Catalog|face.thumb.9.cache
FileKey2=%CommonAppData%AdobeElements OrganizerCatalogsMy Catalog|thumb.5.cache
FileKey3=%CommonAppData%AdobeElements OrganizerCatalogsMy Catalog|WaldoDatawaldo.cache
FileKey4=%CommonAppData%AdobePhotoshop ElementsFile Agent|WatchFolder.3.cache
FileKey5=%AppData%AdobeElements Organizer12.0Organizer|status.dat
FileKey6=%AppData%AdobeElements Organizer12.0Organizer|*.txt
FileKey7=%AppData%AdobePhotoshop Elements12.0Editor|Adobe Photoshop Elements 12 Prefs.psp
We've already had this conversation on this application; removing recents is not worth losing one's prefs.
Share this post
Link to post
WTF? What idiot added *.dat to utorrent more?
Its deleting all the settings
If you are not going to remove it, then add a warning
Share this post
Link to post
I'm sure there are people who don't mind using these including me. I have two other WELL-KNOWN privacy erasing programs! I have sent them this entry & they have accepted it in their programs as it is with a warning about losing preferences.
None of the privacy erasing programs erase Installation Packages of Installed Programs except CCleaner because of entries available in Winapp2.ini. Entries like removing all iPhone, iPad, iPod backups at once doesn't make sense. You should pay some attention on these issues.
Share this post
Link to post
New Entries
[Auslogics Registry Cleaner 3*]
LangSecRef=3024
Detect1=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x
Detect2=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x
Default=False
Warning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.
FileKey1=%CommonAppData%\Auslogics\Registry Cleaner\3.x|*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSE
RegKey1=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey2=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey3=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey4=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.LastScan
RegKey5=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey6=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey7=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey8=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.LastScan
[DVDFab Media Player 2*]
LangSecRef=3023
Detect=HKCU\Software\FabPlayer
Default=False
FileKey1=%Documents%\DVDFab Media Player|*.log
[VSO Media Player 1*]
LangSecRef=3023
Detect=HKCU\Software\VSO\VSO Media Player\1
Default=False
RegKey1=HKCU\Software\VSO\VSO Media Player\1\RecentlyOpenedFiles
[Zoner Photo Studio 16*]
LangSecRef=3023
Detect=HKCU\Software\ZONER\Zoner Photo Studio 16
Default=False
FileKey1=%LocalAppData%\Zoner\ZPS 16\ZPSCache.dat|*.*
FileKey2=%Pictures%|*.uid-zps
[Zoner Photo Studio 16 (AutoSave)*]
LangSecRef=3023
Default=False
FileKey1=%LocalAppData%\Zoner\OriginalsRepository|*.JPG.info;*.JPG.original|RECURSE
Share this post
Link to post
Saad I ran though all the changes that occur with the removal of that file in april. (and in the post above it told you why we don't care what "other programs do")
Since then you've been much more discriminating about your entries; even admonishing other submitters when they over step those lines, so why now are you resubmitting as if none of that occurred?
EDIT:
For others to sound off about this subject, this is what occurs when preferences is removed
http://forum.piriform.com/index.php?showtopic=32310&view=findpost&p=233286
I don't have an iDevice how could I pay attention to those entries? You know I don't work for piriform don't you?
(Full disclosure, edited heavily previous to any other postings but after notice of reply was sent)
Share this post
Link to post
New entries:
ResumeMaker Logs*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\Folders
Default=False
FileKey1=%CommonAppData%\Individual Software\ResumeMaker\R12|*.log
[Civilization 5 Cache*]
Section=Games
Detect1=HKCU\SOFTWARE\Firaxis\Civilization5
Detect2=HKCU\Software\Valve\Steam\Apps\8930
Default=False
FileKey1=%Documents%\My Games\Sid Meier's Civilization 5\cache|*.db
[Civilization 5 Logs*]
Section=Games
Default=False
FileKey1=%Documents%\My Games\Sid Meier's Civilization 5\Logs|*.*
[Civilization 5 Old Autosaves*]
Section=Games
Default=False
FileKey1=%Documents%\My Games\Sid Meier's Civilization 5\Saves\*\auto\prev|*.Civ5Save
Share this post
Link to post
Revised Entry
[iTunes Logs*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Apple Computer, Inc.\iTunes
Default=False
FileKey1=%AppData%\Apple Computer\Logs\CrashReporter\MobileDevice|*.crash;*.log|RECURSE
FileKey2=%AppData%\Apple Computer\Logs\CrashReporter\MobileDevice\*\DiagnosticLogs|*.*|RECURSE
FileKey3=%WinDir%\System32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
FileKey4=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
Share this post
Link to post
Thanks :D
How're these new entries lookin, folks? Cursory looks seem okay to be, but with the exception of
Since we know what happens when we delete settings (even accidentally)
Share this post
Link to post
Revised Entry
http://forum.piriform.com/index.php?showtopic=32310&st=3400&do=findComment&comment=240420
LangSecRef=3024
Default=False
RegKey4=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey5=HKLM\SOFTWARE\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.LastScan
RegKey6=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey7=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey8=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey9=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.ErrorsRemovedTotal
RegKey10=HKLM\SOFTWARE\Wow6432Node\Auslogics\Registry Cleaner\3.x\Settings|RegCleaner.AppLogic.LastScan
Share this post
Link to post
Revised Entry
http://forum.pirifor...380#entry240257
[CyberLink AudioDirector 4*]
LangSecRef=3023
Detect=HKCU\Software\CyberLink\AudioDirector4
Default=False
FileKey1=%LocalAppData%\Cyberlink\AudioDirector\4.0|*.*|RECURSE
FileKey2=%Documents%\Cyberlink\AudioDirector\4.0\SplitterIndex|*.*|RECURSE
RegKey1=HKCU\Software\CyberLink\AudioDirector4\MediaObj\MediaCache5\Data5
Share this post
Link to post
New Entry
[CopyTrans Suite*]
LangSecRef=3023
DetectFile=%AppData%\WindSolutions\CopyTransControlCenter\Applications\CopyTransControlCenter.exe
Default=False
FileKey1=%CommonAppData%\WindSolutions|*.txt|RECURSE
Share this post
Link to post
Revised Entry
http://forum.piriform.com/index.php?showtopic=32310&st=3400&do=findComment&comment=240500
[iTunes Logs*]
LangSecRef=3023
Default=False
FileKey3=%AppData%\Apple Computer\Logs\DeviceLink|*.log
FileKey4=%AppData%\Apple Computer\Logs\MobileBackup|*.log
FileKey5=%WinDir%\System32\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
FileKey6=%WinDir%\SysWOW64\config\systemprofile\AppData\Roaming\Apple Computer\Logs|*.log|RECURSE
Share this post
Link to post
New Entries:
[Civilization 5 Installers*]
Section=Games
Detect=HKCU\SOFTWARE\Firaxis\Civilization5
Default=False
Warning=This will remove DirectX and Visual C++ installers copied to Civilization 5 installation directory. They can be reinstalled from your installation source.
FileKey1=%ProgramFiles%\Civilization V*\DirectX|*.*|REMOVESELF
FileKey2=%ProgramFiles%\Civilization V*\VCRedist|*.*|REMOVESELF
[spooky Mall Logs*]
Section=Games
Detect1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Spooky Mall1.0
Default=False
FileKey1=%CommonAppData%/SpookyMall|*.xml_log
FileKey2=%ProgramFiles%\Foxy Games\Spooky Mall|*.log
Share this post
Link to post
New Entries:
[All Zombies Must Die! Installers*]
Section=Games
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\All Zombies Must Die!_is1
Default=False
Warning=This will remove AMD CPU Driver Package, DirectX and Visual C++ installers copied to All Zombies Must Die installation directory. They can be reinstalled from your installation source.
FileKey1=%ProgramFiles%\Doublesix Games\All Zombies Must Die!\Prerequisites|*.*|REMOVESELF
[All Zombies Must Die! Logs*]
Section=Games
Default=False
FileKey1=%Documents%\My Games\UnrealEngine3\Bzb2Game\Logs|*.*
[burn Zombie Burn! Log*]
Section=Games
Detect=HKLM\SOFTWARE\Burn Zombie Burn
Default=False
FileKey1=%ProgramFiles%\P2 Games\Burn Zombie Burn|*.log
[burn Zombie Burn! .NET Installer*]
Section=Games
Default=False
Warning=This will remove the NET Framework 3.0 installer copied to Burn Zombie Burn installation directory. It can be reinstalled from your installation source.
FileKey1=%ProgramFiles%\P2 Games\Burn Zombie Burn\REQS\NET|*.*|REMOVESELF
[Civilization 4 Cache*]
Section=Games
Detect=HKLM\SOFTWARE\Firaxis Games
Default=False
FileKey1=%AppData%\My Games\Beyond the Sword\cache|*.dat
FileKey2=%AppData%\My Games\Sid Meier's Civilization 4\cache|*.dat
FileKey3=%AppData%\My Games\Warlords\cache|*.dat
FileKey4=%LocalAppData%\My Games\Beyond the Sword\cache|*.dat
FileKey5=%LocalAppData%\My Games\Sid Meier's Civilization 4\cache|*.dat
FileKey6=%LocalAppData%\My Games\Sid Meier's Civilization IV Colonization\cache|*.dat
FileKey7=%LocalAppData%\My Games\Warlords\cache|*.dat
[Civilization 4 Logs*]
Section=Games
Default=False
FileKey1=%Documents%\My Games\Beyond the Sword\Logs|*.*
FileKey2=%Documents%\My Games\Sid Meier's Civilization 4\Logs|*.*
FileKey3=%Documents%\My Games\Sid Meier's Civilization IV Colonization\Logs|*.*
FileKey4=%Documents%\My Games\Warlords\Logs|*.*
FileKey5=%ProgramFiles%\Firaxis Games\Sid Meier's Civilization 4|*.txt
FileKey6=%ProgramFiles%\Firaxis Games\Sid Meier's Civilization 4\Beyond the Sword|*.txt
FileKey7=%ProgramFiles%\Firaxis Games\Sid Meier's Civilization 4\Warlords|*.txt
FileKey8=%ProgramFiles%\2K Games\Firaxis Games\Sid Meier's Civilization IV Colonization|*.txt
Share this post
Link to post
Register a new account
Sign in
