CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
Google Chrome History (link to each website visited, the ones that are in your bookmarks) is not being wiped. I think we should consider adding the files listed below in a separate entry:
%LocalAppData%\Google\Chrome\User Data\Default
History
Thumbnails
Share this post
Link to post
I would suggest a warning be added to that entry as deleting reg backups from a registry cleaner as aggressive as Regseeker (or ANY reg cleaner for that matter) is not necessarily a good idea.
We shouldn't have any entries in Winapp2.ini to remove any kind of backup files. CCleaner is a program to wipe junk files, why is there a need to add entries to wipe some program installation files and iDevice backups in CCleaner?
Share this post
Link to post
I thought the idea behind the winapp2.ini concept is people put whatever they want in there to personalise it to their own systems.
It shouldn't be used on any system in it's full state without knowing what entries it includes.
Some wouldn't want RegSeeker Backups removed, some don't want Event Logs, even just a few posts earlier, some wouldn't want HTML Help files removed.
winapp2.ini is the users choice to make CC as aggressive as they wish and each user should customise it accordingly.
the very use of it should have an overriding warning: User Beware
Share this post
Link to post
This
Mta, while that may be the intent of the file/thread but in practice that's not occurring in the majority of user experience. on top of which many items are added to the program's actual rules and the over aggressive entries have in the past caused trouble with an application because the submitter thought it a good idea to remove even if it wasn't.
Share this post
Link to post
With RegSeeker having its backups removed is too dangerous due to its aggressiveness and false positives.
Share this post
Link to post
The entries listed below replace [Nero 12 Platinum HD Suite*], [Nero Burning ROM 11*] and [Nero Burning ROM 12*]. These also cover Nero Video 11&12. Please compare the attached snapshots to tell the difference.
[Nero 11*]
LangSecRef=3021
Detect1=HKLM\SOFTWARE\Nero\Nero 11\Nero11Suite
Detect1=HKLM\SOFTWARE\Wow6432Node\Nero\Nero 11\Nero11Suite
Default=False
FileKey1=%LocalAppData%\Nero\Nero 11\Nero Vision\Cache\GraphicObjectCache|*.*
FileKey2=%LocalAppData%\Nero\Nero 11\Nero Vision\Cache|*.*
FileKey3=%AppData%\Nero\Nero 11\Nero BackItUp\Cache|*.*
FileKey4=%AppData%\Nero\Nero Burning ROM|*.log
FileKey5=%AppData%\Nero\Nero 11\Nero Burning ROM|*.log
FileKey6=%AppData%\Nero\Nero 11\Nero Recode\AnalysisData|*.dat
FileKey7=%AppData%\Nero\Nero 11\Nero Recode\Thumbs|*.*
FileKey8=%AppData%\Nero\Nero 11\Nero Vision\NVFACache|*.*
FileKey9=%AppData%\Nero\Nero 11\Nero Vision|*.txt;*.bin
FileKey10=%AppData%\Nero\Nero 11\Nero3D|*.log
FileKey11=%CommonAppData%\Nero\PeakFiles|*.tmp
RegKey1=HKCU\Software\Nero\Nero Blu-ray Player\Settings|DefFolder
RegKey2=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Compilation|VolumeLabelAutoTemplate
RegKey3=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Compilation|VolumeLabelUDFTemplate
RegKey4=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Compilation|VolumeLabelISOTemplate
RegKey5=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Compilation|VolumelabelJolietTemplate
RegKey6=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Recent File List
RegKey7=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Settings|WorkingDir
RegKey8=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Settings|TrackSaveDir
RegKey9=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Settings|EncodingLastDir
RegKey10=HKCU\Software\Nero\Nero 11\Nero Burning ROM\Settings|NeroCompilation
RegKey11=HKCU\Software\Nero\Nero 11\Nero CoverDesigner\Recent File List
RegKey12=HKCU\Software\Nero\Nero 11\Nero Express\Compilation|VolumeLabelAutoTemplate
RegKey13=HKCU\Software\Nero\Nero 11\Nero Express\Compilation|VolumeLabelISOTemplate
RegKey14=HKCU\Software\Nero\Nero 11\Nero Express\Compilation|VolumelabelJolietTemplate
RegKey15=HKCU\Software\Nero\Nero 11\Nero Express\Compilation|VolumeLabelUDFTemplate
RegKey16=HKCU\Software\Nero\Nero 11\Nero Express\Recent File List
RegKey17=HKCU\Software\Nero\Nero 11\Nero Express\Settings|BootImageDir
RegKey18=HKCU\Software\Nero\Nero 11\Nero Express\Settings|BrowserDir
RegKey19=HKCU\Software\Nero\Nero 11\Nero Express\Settings|ImageDir
RegKey20=HKCU\Software\Nero\Nero 11\Nero Express\Settings|WorkingDir
RegKey21=HKCU\Software\Nero\Nero 11\Nero Express\General|OFDLastAudioDir
RegKey22=HKCU\Software\Nero\Nero 11\Nero Express\General|OFDLastISODir
RegKey23=HKCU\Software\Nero\Nero 11\Nero Express\General|OFDLastVideoDVDKey
RegKey24=HKCU\Software\Nero\Nero 11\Nero Express\Settings|NeroCompilation
RegKey25=HKCU\Software\Nero\Nero 11\Nero Express\Settings|TrackSaveDir
RegKey26=HKCU\Software\Nero\Nero 11\Nero Toolkit\DiscSpeed\Capture|Folder
RegKey27=HKCU\Software\Nero\Nero 11\Nero Toolkit\DiscSpeed\Save|Folder
RegKey28=HKCU\Software\Nero\Nero 11\Nero Vision\Application|AudioDir
RegKey29=HKCU\Software\Nero\Nero 11\Nero Vision\Application|CaptureDir
RegKey30=HKCU\Software\Nero\Nero 11\Nero Vision\Application|DocDir
RegKey31=HKCU\Software\Nero\Nero 11\Nero Vision\Application|ExportAudioDir
RegKey32=HKCU\Software\Nero\Nero 11\Nero Vision\Application|ExportVideoDir
RegKey33=HKCU\Software\Nero\Nero 11\Nero Vision\Application|ImportVideoDir
RegKey34=HKCU\Software\Nero\Nero 11\Nero Vision\Application|MediaDir
RegKey35=HKCU\Software\Nero\Nero 11\Nero Vision\Application|PicDir
RegKey36=HKCU\Software\Nero\Nero 11\Nero Vision\Application|PicSaveDir
RegKey37=HKCU\Software\Nero\Nero 11\Nero Vision\Application|TmpDir
RegKey38=HKCU\Software\Nero\Nero 11\Nero Vision\Application|VideoDir
RegKey39=HKCU\Software\Nero\Nero 11\Nero WaveEditor\Directories|Last
RegKey40=HKCU\Software\Nero\Nero 11\Nero WaveEditor\Recent File List
[Nero 12*]
LangSecRef=3021
Detect1=HKLM\SOFTWARE\Nero\Nero 12\Nero12Suite
Detect1=HKLM\SOFTWARE\Wow6432Node\Nero\Nero 12\Nero12Suite
Default=False
FileKey1=%LocalAppData%\Nero\Nero 12\Nero Vision\Cache\GraphicObjectCache|*.*
FileKey2=%LocalAppData%\Nero\Nero 12\Nero Vision\Cache|*.*
FileKey3=%AppData%\Nero\Nero 12\Nero BackItUp\Cache|*.*
FileKey5=%AppData%\Nero\Nero 12\Nero Burning ROM|*.log
FileKey6=%AppData%\Nero\Nero 12\Nero Recode\AnalysisData|*.dat
FileKey7=%AppData%\Nero\Nero 12\Nero Recode\Thumbs|*.*
FileKey8=%AppData%\Nero\Nero 12\Nero Vision\NVFACache|*.*
FileKey9=%AppData%\Nero\Nero 12\Nero Vision|*.txt;*.bin
FileKey10=%AppData%\Nero\Nero 12\Nero3D|*.log
FileKey12=%CommonAppData%\Nero\PeakFiles|*.tmp
RegKey2=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Compilation|VolumeLabelAutoTemplate
RegKey3=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Compilation|VolumeLabelUDFTemplate
RegKey4=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Compilation|VolumeLabelISOTemplate
RegKey5=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Compilation|VolumelabelJolietTemplate
RegKey6=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Recent File List
RegKey7=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Settings|WorkingDir
RegKey8=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Settings|TrackSaveDir
RegKey9=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Settings|EncodingLastDir
RegKey10=HKCU\Software\Nero\Nero 12\Nero Burning ROM\Settings|NeroCompilation
RegKey12=HKCU\Software\Nero\Nero 12\Nero CoverDesigner\Recent File List
RegKey12=HKCU\Software\Nero\Nero 12\Nero Express\Compilation|VolumeLabelAutoTemplate
RegKey13=HKCU\Software\Nero\Nero 12\Nero Express\Compilation|VolumeLabelISOTemplate
RegKey14=HKCU\Software\Nero\Nero 12\Nero Express\Compilation|VolumelabelJolietTemplate
RegKey15=HKCU\Software\Nero\Nero 12\Nero Express\Compilation|VolumeLabelUDFTemplate
RegKey16=HKCU\Software\Nero\Nero 12\Nero Express\Recent File List
RegKey17=HKCU\Software\Nero\Nero 12\Nero Express\Settings|BootImageDir
RegKey18=HKCU\Software\Nero\Nero 12\Nero Express\Settings|BrowserDir
RegKey19=HKCU\Software\Nero\Nero 12\Nero Express\Settings|ImageDir
RegKey20=HKCU\Software\Nero\Nero 12\Nero Express\Settings|WorkingDir
RegKey21=HKCU\Software\Nero\Nero 12\Nero Express\General|OFDLastAudioDir
RegKey22=HKCU\Software\Nero\Nero 12\Nero Express\General|OFDLastISODir
RegKey23=HKCU\Software\Nero\Nero 12\Nero Express\General|OFDLastVideoDVDKey
RegKey24=HKCU\Software\Nero\Nero 12\Nero Express\Settings|NeroCompilation
RegKey25=HKCU\Software\Nero\Nero 12\Nero Express\Settings|TrackSaveDir
RegKey26=HKCU\Software\Nero\Nero 12\Nero Toolkit\DiscSpeed\Capture|Folder
RegKey27=HKCU\Software\Nero\Nero 12\Nero Toolkit\DiscSpeed\Save|Folder
RegKey28=HKCU\Software\Nero\Nero 12\Nero Vision\Application|AudioDir
RegKey29=HKCU\Software\Nero\Nero 12\Nero Vision\Application|CaptureDir
RegKey30=HKCU\Software\Nero\Nero 12\Nero Vision\Application|DocDir
RegKey31=HKCU\Software\Nero\Nero 12\Nero Vision\Application|ExportAudioDir
RegKey32=HKCU\Software\Nero\Nero 12\Nero Vision\Application|ExportVideoDir
RegKey33=HKCU\Software\Nero\Nero 12\Nero Vision\Application|ImportVideoDir
RegKey34=HKCU\Software\Nero\Nero 12\Nero Vision\Application|MediaDir
RegKey35=HKCU\Software\Nero\Nero 12\Nero Vision\Application|PicDir
RegKey36=HKCU\Software\Nero\Nero 12\Nero Vision\Application|PicSaveDir
RegKey37=HKCU\Software\Nero\Nero 12\Nero Vision\Application|TmpDir
RegKey38=HKCU\Software\Nero\Nero 12\Nero Vision\Application|VideoDir
RegKey39=HKCU\Software\Nero\Nero 12\Nero WaveEditor\Directories|Last
RegKey40=HKCU\Software\Nero\Nero 12\Nero WaveEditor\Recent File List
Share this post
Link to post
Fix/Modify typo \*.session:
[session Manager deleted sessions*]
LangSecRef=3026
SpecialDetect=DET_MOZILLA
Default=False
FileKey1=%AppData%\Mozilla\Firefox\Profiles\*\sessions\Deleted Sessions|*.session
Share this post
Link to post
New Entry: [snagit 11 Local Dumps (.dmp)*]
LangSecRef=3024
Detect=HKCU\Software\TechSmith\SnagIt\11
Default=False
Warning=This will delete the local dump files (.dmp) automatically created SnagIt 11 if it encounters an error/crash.
FileKey1=%LocalAppData%\TechSmith\Snagit\CrashDumps\|*.*
Share this post
Link to post
New Entrie:
This is not the Steam version, this is for if you installed as stand alone game.
[War Thunder*]
Section=Games
Detect=HKCU\Software\Gaijin\WarThunder
Default=False
FileKey1=%ProgramFiles%\War Thunder\.launcher_log\|*.txt
FileKey2=%ProgramFiles%\War Thunder\_debuginfo\|*.clog
If installed via Steam
FileKey1=%ProgramFiles%\Steam\SteamApps\common\War Thunder\.launcher_log|*.txt
FileKey2=%ProgramFiles%\Steam\SteamApps\common\War Thunder\_debuginfo|*.clog
Note:
[WinASO Registry Optimizer (Backups)*]
LangSecRef=3024
Detect=HKLM\Software\WinASO\Registry Optimizer
Default=False
FileKey1=%ProgramFiles%\WinASO\Registry Optimizer\backup|*.*|RECURSE
Would also need a warning seeing it removes backups or regvalues. The same warning for RegSeeker would do I think ?
Share this post
Link to post
I've been using this without problems:
[Windows SCM Logs*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%WinDir%\System32\LogFiles\Scm|*.*
Wouldn't
[Windows SCM Logs*]
LangSecRef=3025
Default=False
ExcludeKey1=FILE|%WinDir%\System32\LogFiles\Scm|*.EVM*
work also (don't have to list all the numbers)?
Thank you so much, I learned something new from you today.
Share this post
Link to post
New Entrie:
[War Thunder*]
Section=Games
Default=False
Steam support is usually pretty easy to add for games, since the addids (for detects) are public and most of the paths are the same as standalone installs, just in ~\steamapps\common
Share this post
Link to post
Modified Entry [jv16 PowerTools Registry Compact Backups*]: Added DetectFile6 for jv16 PowerTools 2014
LangSecRef=3024
DetectFile1=%ProgramFiles%\jv16 PowerTools 2009\jv16PT.exe
DetectFile2=%ProgramFiles%\jv16 PowerTools 2010\jv16PT.exe
DetectFile3=%ProgramFiles%\jv16 PowerTools 2011\jv16PT.exe
DetectFile4=%ProgramFiles%\jv16 PowerTools 2012\jv16PT.exe
DetectFile5=%ProgramFiles%\jv16 PowerTools 2013\jv16PT.exe
DetectFile6=%ProgramFiles%\jv16 PowerTools 2014\jv16PT.exe
Default=False
Warning=This removes the registry hive backup files generated by jv16 PowerTools during a registry compaction. These files are not needed once the compaction is successfully completed. They can be safely deleted. NOTE that the system must be rebooted following a registry compaction completion in order for jv16 to release these files for deletion.
FileKey1=%LocalAppData%\Microsoft\Windows|UsrClass.dat.jv16pt*
FileKey2=%SystemDrive%\Documents and Settings\NetworkService|NTUSER.DAT.jv16pt*
FileKey3=%SystemDrive%\Documents and Settings\LocalService|NTUSER.DAT.jv16pt*
FileKey4=%SystemDrive%\Documents and Settings\NetworkService.NT*|NTUSER.DAT.jv16pt*
FileKey5=%SystemDrive%\Documents and Settings\LocalService.NT*|NTUSER.DAT.jv16pt*
FileKey6=%UserProfile%|NTUSER.DAT.jv16pt*
FileKey7=%WinDir%\System32\config|Default.jv16pt*;software.jv16pt*;system.jv16pt*;SAM.jv16pt*;COMPONENTS.jv16pt*
FileKey8=%WinDir%\ServiceProfiles\LocalService|NTUSER.DAT.jv16pt*
FileKey9=%WinDir%\ServiceProfiles\NetworkService|NTUSER.DAT.jv16pt*
Share this post
Link to post
In the Nero entries case, I just have Nero Video 12 on my system and never installed any other Nero products before, but the current entries in CCleaner detect that as [Nero 12 Platinum HD Suite], [Nero 12 Platinum HD Suite*], [Nero Burning ROM 11*] and [Nero Burning ROM 12*].
I was not able to find the proper Detect paths for all the Nero products separately, that is why I just made a single entry for all of the Nero products.
Share this post
Link to post
New Entry
[Apple iDevices Software Updates*]
LangSecRef=3023
Detect=HKLM\SOFTWARE\Apple Computer, Inc.\
Default=False
FileKey1=%AppData%\Apple Computer\iTunes|*.ipsw|RECURSE
Replacing the entry listed below with [Apple iPhone Updater Logs*].because other Apple devices also create logs in that location with folders named after the devices. Please look at the snapshot attached with this post.
[Apple iDevices Updater Logs*]
LangSecRef=3023
Default=False
FileKey1=%AppData%\Apple Computer\iTunes|*.log|RECURSE
Share this post
Link to post
I haven't any problems to delt this on downloading :-)
It only resets your download progress when you had a break. On downloading you can't delt it :D
I would say its save... only on install the update
[NVIDIA GFExperience Updates*]
LangSecRef=3023
Warning=!!!Don't do this on install NV updates! Only after!!!
Detect=HKLM\Software\NVIDIA Corporation
Default=False
FileKey1=%SystemDrive%\ProgramData\NVIDIA\Updatus\DownloadManager|*.*
Share this post
Link to post
Revised Entry
Added FileKey2
[Zoner Photo Studio 15*]
LangSecRef=3023
Detect=HKCU\Software\ZONER\Zoner Photo Studio 15
Default=False
FileKey1=%LocalAppData%\Zoner\ZPS 15\ZPSCache.dat|*.*
FileKey2=%Pictures%|*.uid-zps
New Entry
[Zoner Photo Studio 15 (AutoSave)*]
LangSecRef=3023
Default=False
FileKey1=%LocalAppData%\Zoner\OriginalsRepository|*.JPG.info;*.JPG.original|RECURSE
Share this post
Link to post
New Entries
[Corel PaintShop Pro X6*]
LangSecRef=3023
Detect=HKCU\Software\Corel\PaintShop Pro\X6
Default=False
FileKey1=%LocalAppData%\Corel PaintShop Pro\16.0\Database|*.db
FileKey2=%LocalAppData%\Corel PaintShop Pro\16.0\Thumbs|*.*|RECURSE
[Corel PaintShop Pro X6 (AutoPreserve)*]
LangSecRef=3023
Default=False
FileKey1=%Pictures%\Corel Auto-Preserve|*.*
Share this post
Link to post
Did we decide not to include entries that deleted reg backups, only I notice there's an entry in the update that deletes all erunt reg backups (which on a side point seems completely pointless anyway - why install a program to make backups, then have a cleaner delete them all? :huh: )
Share this post
Link to post
NERGAL presses the virtual like button
Share this post
Link to post
Hope you at least TRIED pressing the actual like button, never know, one day it might actually work :P
Share this post
Link to post
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
Loading...
