Winapp2.ini additions
Winapp2.ini
Can someone explain what effect checking and runnning these two entries will do to a system?
[Cached File Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\FileExts
[Cached Shell Extensions*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions
Default=False
RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached
Link to comment
  • Moderators
LangSecRef=3025
Default=False
It's safe to remove and Windows will re-make any keys in there on its own. It helps remove allot of rubbish one-off file extension keys.
Example:
If unpacking an icon package that also has MAC OS extensions for icons that Windows can't use those extensions end up going into FileExts and clogging the registry, after awhile allot of rubbish ends up in there.
LangSecRef=3025
Default=False
Safe to use, it cleans up the right-click area. You may or will notice after using it that a cursor busy will flash for several seconds.
Link to comment
Modified entries
[iObit Advanced SystemCare Ultimate V6 Backup*]
LangSecRef=3024
DetectFile=%ProgramFiles%\IObit\Advanced SystemCare Ultimate
Default=False
FileKey1=%ProgramFiles%\IObit\Advanced SystemCare Ultimate\Backup|*.*|RECURSE
[iObit Advanced SystemCare V6 Logs*]
LangSecRef=3024
DetectFile=%CommonAppData%\IObit\Advanced SystemCare V6
Default=False
FileKey1=%AppData%\IObit\Advanced SystemCare V6\Log|*.*|RECURSE
New entries
[iObit Advanced SystemCare V6 Backup*]
LangSecRef=3024
Default=False
FileKey1=%AppData%\IObit\Advanced SystemCare V6\Backup|*.*|RECURSE
FileKey2=%ProgramFiles%\IObit\Advanced SystemCare 6\Backup|*.*|RECURSE
FileKey3=%ProgramFiles%\IObit\Advanced SystemCare 6\SecurityHole_Backup|*.*|RECURSE
[iObit Advanced SystemCare V6 Temp*]
LangSecRef=3024
Default=False
FileKey1=%ProgramFiles%\IObit\Advanced SystemCare 6|*.cab_Temp|REMOVESELF
[EnhanceMy8*]
LangSecRef=3024
DetectFile=%ProgramFiles%\EnhanceMy8
Default=False
FileKey1=%AppData%\SeriousBit\EnhanceMy8\Backups|*.*|RECURSE
FileKey2=%AppData%\SeriousBit\EnhanceMy8|Logs.txt
Link to comment
New entries:
[Aliens: Colonial Marines*]
Section=Games
Detect=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Aliens: Colonial Marines_is1
Default=False
FileKey1=%Documents%\My Games\Aliens Colonial Marines\PecanGame\Logs|*.*
[Warcraft III*]
Section=Games
Detect=HKLM\SOFTWARE\Blizzard Entertainment\Warcraft III
Default=False
FileKey1=%ProgramFiles%\Warcraft III|*.txt;*.log;*.html
ExcludeKey1=FILE|%ProgramFiles%\Warcraft III|*CustomKeyInfo.txt;*CustomKeysSample.txt
Link to comment
Merged World of Warcraft ADB Cache Files & World of Warcraft WDB Cache Files rules (both share same Cache folder):
[World of Warcraft Cache Files*]
Section=Games
Detect=HKCU\Software\Blizzard Entertainment\World of Warcraft
Default=False
FileKey1=%ProgramFiles%\World of Warcraft\Cache|*.*|REMOVESELF
FileKey2=%Public%\Games\World of Warcraft\Cache|*.*|REMOVESELF
FileKey3=%SystemDrive%\World of Warcraft\Cache|*.*|REMOVESELF
Modified:
[World of Warcraft Error Files*]
Section=Games
Default=False
FileKey1=%ProgramFiles%\World of Warcraft\Errors|*.*|REMOVESELF
FileKey2=%Public%\Games\World of Warcraft\Errors|*.*|REMOVESELF
FileKey3=%SystemDrive%\World of Warcraft\Errors|*.*|REMOVESELF
- added REMOVESELF... Folder will be regenerated should errors occur.
[World of Warcraft Logfiles*]
Section=Games
Default=False
FileKey1=%ProgramFiles%\World of Warcraft\Logs|*.log;*.txt;*.html
FileKey2=%Public%\Games\World of Warcraft\Logs|*.log;*.txt;*.html
FileKey3=%SystemDrive%\World of Warcraft\Logs|*.log;*.txt;*.html
- Edited FileKeys to include txt & html files
Recommend removal:
'World of Warcraft Backup Files' entry (lua.bak are stored in World of Warcraft\WTF\Account\<accountname>\)
Every account name is different. lua.bak files are not stored in 'Errors' folder.
[[World of Warcraft Backup Files*]
Section=Games
Warning=This will delete all the .lua.bak files in your world of Warcraft folder, so and you wont be able to restore from them if something goes wrong.
Default=False
FileKey1=%ProgramFiles%\World of Warcraft\Errors|*.lua.bak|RECURSE
FileKey2=%Public%\games\World of Warcraft\Errors|*.lua.bak|RECURSE
FileKey3=%HomeDrive%\World of Warcraft|*.lua.bak|RECURSE
Link to comment
  • Moderators
[ClassicShell Startmenu Recent Apps*]
LangSecRef=3024
Detect=HKCU\Software\IvoSoft\ClassicStartMenu\
Default=False
RegKey1=HKCU\Software\IvoSoft\ClassicStartMenu\MRU
Tested on windows8 (assume it'll work in windows 7 too)
Link to comment
  • Moderators
Updated (added RegKey2):
[Kodak AiO Software (Disable Startup)*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Kodak\Kodak AiO Software
Detect2=HKLM\SOFTWARE\Eastman Kodak Company\KODAK AiO Home Center
Default=False
Warning=Disables the Kodak AiO Software from automatically starting with Windows. Note: Everytime you print the Kodak AiO Software will automatically re-enable itself to start with Windows.
RegKey1=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run|EKAIO2StatusMonitor
RegKey2=HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Run|EKStatusMonitor
Updated (added FileKey8):
[Kodak AiO Software (Logs)*]
LangSecRef=3021
Default=False
FileKey1=%CommonAppData%\Kodak\Inkjet Logging|*.bak|RECURSE
FileKey2=%CommonAppData%\Kodak\Inkjet Logging|*.html|RECURSE
FileKey3=%CommonAppData%\Kodak\Inkjet Logging|*.lock|RECURSE
FileKey4=%CommonAppData%\Kodak\Inkjet Logging|*.log|RECURSE
FileKey5=%CommonAppData%\Kodak\Inkjet Logging|Format.css
FileKey6=%CommonAppData%\Kodak\Inkjet Logging\Twain\kds_aio2esp\twain|*.txt|RECURSE
FileKey7=%CommonAppData%\Kodak\Inkjet Logging\Twain\kds_aio2esp\twain|*.xml|RECURSE
FileKey8=%LocalAppData%|LaunchHomeCenter.log
Link to comment
Modified entry:
[samsung Kies*]
LangSecRef=3023
Detect=HKCU\Software\Samsung\Kies2.0
Default=False
FileKey1=%AppData%\Samsung\Kies|UpdateLog.txt;UpdateList.txt;*.mlca;*.mlme;*.mlpb;*.mlpgb;*.log|RECURSE
FileKey2=%AppData%\Samsung\Kies\UpdateTemp|*.*|RECURSE
FileKey3=%CommonAppData%\Samsung\Kies|ConnectionManager.log;Kiesairmessage.log
FileKey4=%AppData%\Samsung\Kies\TempFiles|*.*|RECURSE
FileKey5=%CommonAppData%\Samsung\Device Error Recovery|*.log
- Added FileKeys 4 & 5
Link to comment
Updated for CCleaner v3.28
Thanks for the updated Winapp2.ini, and thanks for fixing the variable for 'World of Warcraft Backup Files'.
I searched the forum for answers to clean further into the WTF folder tree; without luck.
I should've just asked.
* You have noted 'World of Warcraft Backup Files' modification in v3.28.130225 'What's new' text, but overlooked updating in Winapp2.ini v3.28.130225
I did need to edit paths slightly (should be Account, not Accounts).
Tested and works great now; finding 16 files.
- Edited FileKeys to .bak from .lua.bak to account for all .bak files
- Added .old files removal to FileKeys
- Edited Warning
Modified entry:
Section=Games
Default=False
Warning=This will delete all your World of Warcraft backup files. You won't be able to restore from them if something goes wrong.
FileKey1=%ProgramFiles%\World of Warcraft\WTF\Account\*|*.bak;*.old|RECURSE
FileKey2=%Public%\games\World of Warcraft\WTF\Account\*|*.bak;*.old|RECURSE
FileKey3=%SystemDrive%\World of Warcraft\WTF\Account\*|*.bak;*.old|RECURSE
:lol: For the record... My daughter is the gamer, not I.
Link to comment
  • Moderators
On (some) Items With DetectOS and a Detect which is general, only the OS one is needed.
Example
[Notification Cache*]
DetectOS=6.2|
Section=Windows 8 Apps
Default=False
FileKey1=%LocalAppData%\Microsoft\Windows\Notifications|*.*|RECURSE
Struck out line unneeded, DetectOS detects.
Other Examples
[Windows 7/8 MUICache*]
[Windows 7/8 QuickLaunch*]
[Windows 7/8 ShellBags*]
[Windows 7/8 Transcoded Wallpaper Cache*]
[Windows 8 ScreenShot Index*]
[Windows 8 Search History*]
[Windows 8 Start Menu Cache*]
Edited by Nergal
Link to comment
Are you sure? Everything seems in order on my local copy, and on the download page.
Section=Games
Default=False
Warning=This will delete all the .lua.bak files in your world of warcraft folder, so and you wont be able to restore from them if something goes wrong.
FileKey1=%ProgramFiles%\World of Warcraft|*.lua.bak|RECURSE
FileKey2=%Public%\games\World of Warcraft|*.lua.bak|RECURSE
FileKey3=%SystemDrive%\World of Warcraft|*.lua.bak|RECURSE
True enough that I am missing the \accounts\ portion, but it should world all the same.
Link to comment
Example
Other Examples
Excellent point, will definitely remember this for next time!
Link to comment
Damn, why do you always have to be right! :P
Your edit does work as it should. My apologies.
I have games installed to G:\ and neglected to edt before testing.
Please accept this as my Modified entry:
Section=Games
Default=False
FileKey1=%ProgramFiles%\World of Warcraft|*.bak;*.old|RECURSE
FileKey2=%Public%\games\World of Warcraft|*.bak;*.old|RECURSE
FileKey3=%SystemDrive%\World of Warcraft|*.bak;*.old|RECURSE
- Edited Warning
New entry:
[Warcraft III Backup Files*]
Section=Games
Default=False
Warning=This will delete all your Warcraft III backup files. You won't be able to restore from them if something goes wrong.
FileKey1=%ProgramFiles%\Warcraft III|*.bak;*.old|RECURSE
Link to comment
  • Moderators
Also not sure win8 app need detectOS (yet) as the detected directory will (read should) only appear in Windows 8 and those detect do seem to work on an "and" basis as when I uninstalled BingTravel it disappeared from my ccleaner even though I was still on detectOS-defined-OS.
Link to comment
May be my mistake, left over from before app specific Detects where added.
Link to comment
  • Moderators
LOL except Store leave that as detectOS only as all Windows 8s will have that app
Link to comment
My thoughts on the DetectOS thing are, I imagine, that when CCleaner sees DetectOS=6.2, on say windows 7, it doesn't even bother looking at the rest of the entry. Probably some miniscule speed boost. I'd have to run tests to actually be sure.
Link to comment
You don't need FileKey1 and FileKey2. FileKey3 covers everything.
[Auslogics Registry Cleaner*]
LangSecRef=3024
Detect=HKCU\Software\Auslogics\Registry Cleaner
Default=False
Warning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.
FileKey1=%AppData%\Auslogics\Registry Cleaner\User Reports|*.*
FileKey2=%AppData%\Auslogics\Rescue\Auslogics Registry Cleaner|*.*
FileKey3=%AppData%\Auslogics|*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSE
RegKey1=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey2=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey3=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey4=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.LastScan
Link to comment
New entry:
[Microsoft Flight Simulator X*]
Section=Games
Detect=HKLM\SOFTWARE\Microsoft\Microsoft Games\Flight Simulator\10.0
Default=False
FileKey1=%ProgramFiles%\Microsoft Games\Microsoft Flight Simulator X|*.log;*.rtf;*.html;*.URL
FileKey2=%ProgramFiles%\Microsoft Games\Microsoft Flight Simulator X\Modules|*.log
ExcludeKey1=FILE|%ProgramFiles%\Microsoft Games\Microsoft Flight Simulator X|*kiosk.rtf;*readme.rtf;*Readme.htm
Link to comment
Thanks for the update!
New entry:
[CrystalDiskInfo*]
LangSecRef=3024
DetectFile=%ProgramFiles%\CrystalDiskInfo\Smart
Default=False
Warning=This will delete all saved SMART data (for history/graph function).
FileKey1=%ProgramFiles%\CrystalDiskInfo\Smart|*.*|RECURSE
Modified entry [spybot - Search & Destroy 2 Logs*]:
[spybot Search and Destroy 2*]
LangSecRef=3024
Detect=HKCU\Software\Safer Networking Limited\Spybot - Search & Destroy 2
Default=False
FileKey1=%Documents%\ProcAlyzer Dumps|*.*|REMOVESELF
FileKey2=%CommonAppData%\Spybot - Search & Destroy\Logs|*.*|RECURSE
FileKey3=%CommonAppData%\Spybot - Search & Destroy\System Configuration Snapshots|*.*|REMOVESELF
Modified entries:
[spybot Search and Destroy Hosts Backups*]
LangSecRef=3024
Detect1=HKLM\Software\Safer Networking Limited\SpybotSnD
Detect2=HKCU\Software\Safer Networking Limited\Spybot - Search & Destroy 2
Default=False
FileKey1=%WinDir%\System32\drivers\etc|hosts.*.backup
[spybot Search and Destroy Updates*]
LangSecRef=3024
Default=False
FileKey1=%ProgramFiles%\Spybot - Search & Destroy\Updates|*.zip
FileKey2=%ProgramFiles%\Spybot - Search & Destroy 2\Updates\Downloads|*.cab
FileKey3=%ProgramFiles%\Spybot - Search & Destroy 2\Updates\Extracts|*.sbi;*.sbs;*.uti
Link to comment
New entry:
[Ad-Aware Antivirus*]
LangSecRef=3021
DetectFile=%ProgramFiles%\Ad-Aware Antivirus\AdAware.exe
Default=False
FileKey1=%CommonAppData%\Ad-Aware Antivirus\Logs|*.*|RECURSE
FileKey2=%AppData%\Ad-Aware Antivirus\Logs|*.*|RECURSE
FileKey3=%CommonAppData%\Lavasoft\AntiMalware\Logs|*.*|RECURSE
FileKey4=%CommonAppData%\Lavasoft\AntiMalware\History|*.*|RECURSE
FileKey5=%CommonAppData%\Lavasoft\AntiMalware\Events|*.*|RECURSE
[Webroot SecureAnywhere*]
LangSecRef=3024
DetectFile=%ProgramFiles%\Webroot\WRSA.exe
Default=False
FileKey1=%CommonAppData%\WRData|WRLog.log
Link to comment
Register a new account
Sign in
Important Information
