CCleaner Community Forums
Winapp2.ini additions
Lost me again!
I'll look into the Age of Empires path.
The games are all here... somewhere.
btw...
MTA San Andreas 1.3=
Multi Theft Auto (MTA) is an open source mod that adds network functionality to Rockstar's Grand Theft Auto San Andreas.
Link to post
Modified entry:
[Age of Empires*]
Section=Games
Detect1=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires*
Detect2=HKLM\SOFTWARE\Microsoft\Games\Age of Empires
Default=False
FileKey1=%Documents%\My Games\Age of Mythology|*.txt
FileKey2=%Documents%\My Games\Age of Empires 3|*.txt
FileKey3=%ProgramFiles%\Microsoft Games\Age of Empires|*.RTF;*.GID
FileKey4=%ProgramFiles%\Microsoft Games\Age of Empires II|EULA.RTF;EULAx.RTF
FileKey5=%ProgramFiles%\Microsoft Games\Age of Mythology|*.rtf;*.txt
FileKey6=%ProgramFiles%\Microsoft Games\Age of Empires III|*.rtf;ESOEULA.TXT
ExcludeKey1=FILE|%ProgramFiles%\Microsoft Games\Age of Mythology|*Readme.rtf;*Readmex.rtf
ExcludeKey2=FILE|%ProgramFiles%\Microsoft Games\Age of Empires III|*Readme.rtf;*ReadmeX.rtf;*ReadmeY.rtf
RegKey1=HKLM\SOFTWARE\Microsoft\Games\Age of Empires\1.00|Zone
RegKey2=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires|Zone
RegKey3=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires Expansion\1.0|Zone
RegKey4=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires\2.0|Zone
RegKey5=HKLM\SOFTWARE\Microsoft\Microsoft Games\Age of Empires II: The Conquerors Expansion\1.0|Zone
- Edited Detection
- Deleted original FileKey1
- Added FileKeys 3 to 6
- Added RegKeys 1 to 5
- Added ExcludeKeys 1 & 2
Link to post
is it safe to delete event logs in C:\Windows\System32\winevt\Logs ?
That folder contains the event viewer logs, which I'm pretty sure has been stated won't be added to winapp2.
Link to post
Correct on both counts...
However, It is safe to to delete them provided you're certain the logs won't be required for troubleshooting.
The logs can't be deleted without stopping the service. An entry would probably be fine with a warning.
But that's not my call.
Link to post
I think the fact that it cant be removed without stopping the service was the main argument against it. I'd go back and look, but 2800 posts is a lot to sift through! :lol:
Link to post
  • Moderators
shouldn't be removed by public file, else unsuspecting people (those who don't know what an event logs is so a warning doesn't suffice) will make tech support much harder.
if you want to add it to yer own g'ahead
Link to post
Probably a lot safer to clear them through 'Control Panel > Administrative Tools'.
The age and log size can also be tweaked smaller via 'Properties'.
Safer but a PITA on Win7 as there's loads of different logs and they can only be cleared one at a time. Unless of course you use a nifty little batch file: Win7 Clear Event Viewer.zip ;)
Link to post
New entry:
[Windows Update*]
LangSecRef=3025
DetectFile=%WinDir%\SoftwareDistribution\Download
Default=False
FileKey1=%WinDir%\SoftwareDistribution\Download|*.*|RECURSE
These files seem to be not longer needed after installing Windows updates.
Link to post
  • Moderators
New entry:
[Windows Update*]
LangSecRef=3025
Default=False
no
Microsoft says not to remove this, discussed multiple time in this and many other threads
Link to post
This warning doesn't show up [Windows 7/8 Transcoded Wallpaper Cache*]
Warning= You have to refresh your background! (have to reinstall it)
[Windows QuickLaunch ImplicitAppShortcuts*]
DetectFile=%AppData%\Microsoft\Internet Explorer\Quick Launch\User Pinned\ImplicitAppShortcuts
Removed always your pinned configuration screen. (since a few updates ago the only pinned shortcut in that place (Win7 X64)
Warning= This will remove your pinned configuration screen shortcut.
Link to post
Modified Entry: Changed DetectOS=|6.1 to DetectOS=6.1|
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
DetectOS=6.1|
Default=False
Warning=You have to refresh your background!
Link to post
New entry: Microsot Office Customization Tool (I use this to personalize my office 2007/2010/2013 installs)
[MS Office Customization Tool*]
LangSecRef=3021
Detect1=HKCU\Software\Microsoft\OfficeCustomizeWizard\12.0
Detect2=HKCU\Software\Microsoft\OfficeCustomizeWizard\14.0
Detect3=HKCU\Software\Microsoft\OfficeCustomizeWizard\15.0
Default=False
RegKey1=HKCU\Software\Microsoft\OfficeCustomizeWizard\12.0\RecentFileList
RegKey2=HKCU\Software\Microsoft\OfficeCustomizeWizard\14.0\RecentFileList
RegKey3=HKCU\Software\Microsoft\OfficeCustomizeWizard\15.0\RecentFileList
Link to post
MODIFIED ENTRY
[Auslogics Registry Cleaner*]
LangSecRef=3024
Detect=HKCU\Software\Auslogics\Registry Cleaner
Warning=This will remove your backups, and you will be unable to undo any changes you made with Auslogics Registry Cleaner.
Default=False
FileKey1=%AppData%\Auslogics|*.htm;*.html;*.log;*.rsc;*.sta;*.xml|RECURSE
RegKey1=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.ErrorsFailed
RegKey2=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.ErrorsFound
RegKey3=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.ErrorsRemoved
RegKey4=HKCU\Software\Auslogics\Registry Cleaner\2.x\Settings|RegCleaner.AppLogic.LastScan
Link to post
Problem
My Control Panel was Pinned into the Windows Taskbar.
After I added the Winapp2.ini and used CCleaner,
the Control Panel Shortcut (pinned into the Windows Taskbar) No Longer opened!
What Winapp2.ini Entry is causing this?
Link to post
Register a new account
Sign in
