Moderators Nergal Posted February 7, 2013 Moderators Share Posted February 7, 2013 I want to make this little event a chance to quote Andrew's words as if they've come from my own fingers; To everyone in this now 2776 reply post And thank you to the volunteers who have contributed the winapp2.ini project that benefits BleachBit, CCleaner, and System Ninja. Now let us all drop this subject and follow @siliconman01's example by getting back to work . Love y'all Grumpy Gus Gustavison ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
SMalik Posted February 7, 2013 Share Posted February 7, 2013 New Entry: [Windows 7/8 Search (Windows.edb)*] LangSecRef=3025 DetectOS=6.1| Warning=Checkmark this entry to remove file Windows.edb ONLY if you have Windows Search service disabled. Windows.edb can be several hundred megabytes in size and is not needed if Search is disabled. Default=False FileKey1=%ProgramData%\Microsoft\Search\Data\Applications\Windows\|Windows.edb NOTE: This entry MAY be applicable to Windows Vista and XP; however, I have no way of testing it on these systems. I suspect that if search/Indexing is disabled on Windows Vista and XP, then Windows.edb can be removed. [indexing Traces*] entry removes .db files. There is no need to add a duplicate entry. It is safe to remove .db files from that location. There is no need to add a warning. Link to comment Share on other sites More sharing options...
SMalik Posted February 7, 2013 Share Posted February 7, 2013 Please change the [MS Office UnsavedFiles*] entry's name to [MS Office Unsaved Files*]. Link to comment Share on other sites More sharing options...
SMalik Posted February 7, 2013 Share Posted February 7, 2013 NEW ENTRY [Roxio Creator NXT Pro*] LangSecRef=3021 Detect=HKCU\Software\Roxio\EMC14 Default=False RegKey1=HKCU\Software\Roxio\EMC14\VideoUI\RecentFiles\Productions RegKey2=HKCU\Software\Roxio\EMC14\VideoUI\RecentFiles\Catalogs RegKey3=HKLM\Software\Roxio\EMC14\Common SDK\Users RegKey4=HKLM\Software\Wow6432Node\Roxio\EMC14\Common SDK\Users Link to comment Share on other sites More sharing options...
SMalik Posted February 8, 2013 Share Posted February 8, 2013 MODIFIED ENTRY Added the highlighted line. [Tag&Rename 3*] LangSecRef=3024 Detect=HKCU\Software\Softpointer\Tag&Rename3\Config Default=False RegKey1=HKCU\Software\Softpointer\Tag&Rename3\Config|FCurrentFolder RegKey2=HKCU\Software\Softpointer\Tag&Rename3\Config|FHistoryList RegKey3=HKCU\Software\Softpointer\Tag&Rename3\Config|FileListHeader FileKey1=%Music%|*.jpg Link to comment Share on other sites More sharing options...
siliconman01 Posted February 8, 2013 Share Posted February 8, 2013 [indexing Traces*] entry removes .db files. There is no need to add a duplicate entry. It is safe to remove .db files from that location. There is no need to add a warning. Windows.edb is in a different folder than addressed by Indexing Traces*. It is in the Windows folder and not in the three folders of Indexing Traces* [indexing Traces*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 8, 2013 Author Share Posted February 8, 2013 So would you consider it worth adding to Indexing Traces, or remaining separate? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted February 8, 2013 Share Posted February 8, 2013 Yes, it can be added to Indexing Traces. I tested it with Windows Search enabled on Windows 7 and Windows 8. When CCleaner tries to remove Windows.edb, it cannot because the service has it in use. No error messages are emitted either. So I agree that the Warning message is not needed either. Again, I have no way of testing it on XP or Vista. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
FreeRyde Posted February 9, 2013 Share Posted February 9, 2013 I took the liberty of merging siliconman01's new 'Windows 7/8 Search (Windows.edb)' entry into 'Indexing Traces'... and adding FileKey4 for XP. FileKey4 reflects 'Windows.edb' location In XP FileKey5 reflects 'Windows.edb' location In Windows Vista/7/8 [indexing Traces*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE FileKey4=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\|Windows.edb FileKey5=%ProgramData%\Microsoft\Search\Data\Applications\Windows|Windows.edb As previously stated, Search/Indexing service must be disabled or the process stopped for 'Windows.edb' to be removed Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 9, 2013 Author Share Posted February 9, 2013 %CommonAppData% is the same as %ProgramData% winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted February 9, 2013 Share Posted February 9, 2013 %ProgramData% is the same as %ProgramData% I second that Link to comment Share on other sites More sharing options...
Moderators Nergal Posted February 9, 2013 Moderators Share Posted February 9, 2013 %ProgramData% is the same as %ProgramData% wait oranges are oranges?!? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 9, 2013 Author Share Posted February 9, 2013 Fixed. I think I auto corrected it in my head because they're the same! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted February 9, 2013 Share Posted February 9, 2013 Fixed. You'r no fun any more Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 10, 2013 Author Share Posted February 10, 2013 Don't worry, I haven't changed much: %ProgramData% is still indeed the same as %ProgramData% winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
FreeRyde Posted February 10, 2013 Share Posted February 10, 2013 On XP, when using %ProgramData% C:\Documents and Settings\All Users\Application Data\Microsoft\Search\Data\Applications\Windows\Windows.edb is not detected by CCleaner. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 10, 2013 Author Share Posted February 10, 2013 Yes, %CommonAppData% is forwards-compatible with vista/7/8 though. %ProgramData% keys aren't needed. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
FreeRyde Posted February 10, 2013 Share Posted February 10, 2013 I'm a little 'slow' sometimes! I get it now. Thanks Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 10, 2013 Author Share Posted February 10, 2013 updated winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted February 11, 2013 Share Posted February 11, 2013 Looks like you overlooked the one below: [MS Office 2013 SkyDrive (setup logs)*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\SkyDrive Default=False FileKey1=%LocalAppData%\Microsoft\SkyDrive\Setup\Logs\|*.* Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
CSGalloway Posted February 11, 2013 Share Posted February 11, 2013 Version: v3.27.130210 Windows XP Pro sp3 with full updates. Shows up: [Windows 7/8 Transcoded Wallpaper Cache*] [bugsplat*] I did have Pando but never had the "lol_beta_riotgames_com" subkey, as in the INI. Link to comment Share on other sites More sharing options...
ProPaan Posted February 11, 2013 Share Posted February 11, 2013 i think this need to be reviewed [Age of Empires*] Section=Games Detect=HKLM\SOFTWARE\Microsoft\Microsoft Games Default=False FileKey1=%Documents%\My Games\Age of Empires 2|*.txt FileKey2=%Documents%\My Games\Age of Mythology|*.txt FileKey3=%Documents%\My Games\Age of Empires 3|*.txt cuz i dont ever had this game, and its shows it in ccleaner,detect is wrong, it need to be more specified to Age Of Empires, in HKLM\SOFTWARE\Microsoft\Microsoft Games i only have halo, and its shows Age Of Empires. sorry for bad english Link to comment Share on other sites More sharing options...
ProPaan Posted February 11, 2013 Share Posted February 11, 2013 new entry [MTA San Andreas 1.3 Logs*] Section=Games Detectfile=%ProgramFiles%\MTA San Andreas 1.3\Multi Theft Auto.exe Default=False FileKey1=%ProgramFiles%\MTA San Andreas 1.3/MTA/logs|*.* FileKey2=%ProgramFiles%\MTA San Andreas 1.3/server/mods/deathmatch/backups|*.* FileKey3=%ProgramFiles%\MTA San Andreas 1.3/server/mods/deathmatch/logs|*.* Link to comment Share on other sites More sharing options...
Winapp2.ini Posted February 11, 2013 Author Share Posted February 11, 2013 Looks like you overlooked the one below: [MS Office 2013 SkyDrive (setup logs)*] LangSecRef=3021 Detect=HKCU\Software\Microsoft\SkyDrive Default=False FileKey1=%LocalAppData%\Microsoft\SkyDrive\Setup\Logs\|*.* Whoops! i think this need to be reviewed [Age of Empires*] Section=Games Detect=HKLM\SOFTWARE\Microsoft\Microsoft Games Default=False FileKey1=%Documents%\My Games\Age of Empires 2|*.txt FileKey2=%Documents%\My Games\Age of Mythology|*.txt FileKey3=%Documents%\My Games\Age of Empires 3|*.txt cuz i dont ever had this game, and its shows it in ccleaner,detect is wrong, it need to be more specified to Age Of Empires, in HKLM\SOFTWARE\Microsoft\Microsoft Games i only have halo, and its shows Age Of Empires. sorry for bad english I'll need someone with those installed to provide a better bath :x winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted February 11, 2013 Share Posted February 11, 2013 I'll need someone with those installed to provide a better bath :x Is the 'bath' where programdata is the same as programdata? Link to comment Share on other sites More sharing options...
