CCleaner Community Forums
Winapp2.ini
Winapp2.ini additions
MODIFIED ENTRY
http://forum.piriform.com/index.php?showtopic=32310&st=2660#entry228235
[Common Language Runtime Logs*]
LangSecRef=3025
Detect=HKCU\Software\Microsoft\Windows
Default=False
FileKey1=%LocalAppData%\Microsoft\CLR_v2.0\*|*.log
FileKey2=%LocalAppData%\Microsoft\CLR_v2.0_32\*|*.log
FileKey3=%LocalAppData%\Microsoft\CLR_v4.0\*|*.log
FileKey4=%LocalAppData%\Microsoft\CLR_v4.0_32\*|*.log
FileKey5=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0\*|*.log
FileKey6=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0_32\*|*.log
FileKey7=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0\*|*.log
FileKey8=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0_32\*|*.log
FileKey9=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0\*|*.log
FileKey10=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v2.0_32\*|*.log
FileKey11=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0\*|*.log
FileKey12=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v4.0_32\*|*.log
Share this post
Link to post
It's working good on this old XP computer. Thanks for sharing it!!!
You're welcome.
Share this post
Link to post
MODIFIED ENTRY
http://forum.pirifor...660#entry228235
LangSecRef=3025
Default=False
This will work too
LangSecRef=3025
Default=False
FileKey1=%LocalAppData%\Microsoft\CLR_v*.*|*.*|RECURSE
FileKey2=%WinDir%\System32\config\systemprofile\AppData\Local\Microsoft\CLR_v*.*|*.*|RECURSE
FileKey3=%WinDir%\SysWOW64\config\systemprofile\AppData\Local\Microsoft\CLR_v*.*|*.*|RECURSE
Share this post
Link to post
This will work too
LangSecRef=3025
Default=False
I think this is better.
Share this post
Link to post
Modified Entry:
Removed ExcludeKey1 and modified FileKey3.
[Quicken Logs*]
LangSecRef=3021
Detect=HKLM\SOFTWARE\Intuit\Quicken
Default=False
FileKey1=%AppData%\Intuit\Quicken\Log|*.txt;*.log
FileKey2=%CommonAppData%\Intuit\Quicken\Log|*.log
FileKey3=%CommonAppData%\Intuit\Quicken\Log\installer|*.*|REMOVESELF
Share this post
Link to post
New Entry for NETGEAR Router:
[NETGEAR Genie (logs)**]
LangSecRef=3024
Detect1=HKLM\Software\NETGEAR Genie
Detect2=HKLM\Software\Wow6432Node\NETGEAR Genie
Default=False
FileKey1=%LocalAppData%\NETGEARGenie\log\|*.log
Share this post
Link to post
Halite BitTorrent Client[/url] log files and configuration backups.
[Halite Logs and Backups*]
LangSecRef=3021
DetectFile1=%LocalAppData%\Halite\
Default=False
FileKey1=%LocalAppData%\Halite|HaliteLog.txt
FileKey2=%LocalAppData%\Halite|Halite.xml.*|RECURSE
Edited by Nergal
Removed program link, if other want this product they can search for it
Share this post
Link to post
Nergal you left a url tag :P
Thanks Fuebar & others. Sorry I've been quiet on the thread, been a bit busy. Fear not though, I've been keeping up with submissions!
Share this post
Link to post
Nergal you left a URL tag :P
doh! oh well let it ride I say.
Share this post
Link to post
LangSecRef=3024
Default=False
I think Detect1 is enough, ccleaner should automatically check the Wow6432Node
Share this post
Link to post
Gotcha and thanks on the Detect1 being enough....was not sure.
ALSO, please change the ** to a single *. I use the ** to signal my private customizations and sometimes forget to change to * when I post here. Sorry! :wacko:
Share this post
Link to post
Change this
[DatacardService*]
LangSecRef=3024
DetectFile=%CommonAppData%\DatacardService\DataCardMonitor.exe
Default=False
FileKey1=%CommonAppData%\DatacardService\log|*.log
to this
[DatacardService Log*]
LangSecRef=3022
Detect=HKLM\System\CurrentControlSet\Services\HWDeviceService.exe
Default=False
FileKey1=%CommonAppData%\DatacardService\log|*.*
and
[Tele2 Mobile Partner*]
LangSecRef=3022
DetectFile=%ProgramFiles%\Tele2 Mobile Partner\Tele2 Mobile Partner.exe
Default=False
FileKey1=%ProgramFiles%\Tele2 Mobile Partner\Log|*.txt
FileKey2=%CommonAppData%\Tele2 Mobile Partner\log|*.*
Share this post
Link to post
Link to download Winapp2.ini Version: v3.26.121221
must be Version: v3.27.130124 i think :)
(in first post)
Share this post
Link to post
@Back_track: What? also Thanks!
@Rohk: Thanks! This seems neat. Alan_B might get territorial ;)
http://social.techne...b8-fbdb7d9c15bd
questions?
[Windows 7 delt Transcoded Wallpaper cache*]
LangSecRef=3025
DetectOS=|6.1
Default=False
Warning= You have to refresh your background!
Share this post
Link to post
NEW ENTRIES
[Chivalry: Medieval Warfare*]
LangSecRef=Games
Detect=HKCU\Software\Valve\Steam\Apps\219640
Default=False
FileKey1=%Documents%\My Games\Chivalry Medieval Warfare\UDKGame\Logs|*.*
[Don't Starve*]
LangSecRef=Games
DetectFile=%ProgramFiles%\Steam\steamapps\common\dont_starve
Default=False
FileKey1=%ProgramFiles%\Steam\steamapps\common\dont_starve\bin|log.txt
Share this post
Link to post
questions?
LangSecRef=3025
DetectOS=|6.1
Default=False
Okay I see now, it will be recreated according to that thread.
Share this post
Link to post
The detect key for this entry doesn't exist here on Win7:
[TomTom*]
LangSecRef=3021
Detect=HKCU\Software\TomTom
Default=False
FileKey1=%LocalAppData%\TomTom\HOME3\cache|*.*|RECURSE
FileKey2=%LocalAppData%\TomTom\HOME3|Log.txt
FileKey3=%AppData%\TomTom\HOME\Profiles\*|Log.txt
The only usable reg detect key I have is HKLM\SOFTWARE\Classes\tomtomhome
Share this post
Link to post
New:
[Microsoft Security Essentials (Old Defs)*]
LangSecRef=3024
Detect=HKLM\Software\Microsoft\Microsoft Antimalware
Default=False
Warning=This will make it impossible to roleback to the previous definition files.
FileKey1=%CommonAppData%\Microsoft\Microsoft Antimalware\Definition Updates\Backup|*.*
I'm not sure about the LangSecRef= number, don't know if it's better suited under "Utilities" or "Windows".
Share this post
Link to post
Register a new account
Sign in
