SMalik Posted January 3, 2013 Share Posted January 3, 2013 NEW ENTRIES [Cryptographic Services Traces*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%WinDir%\System32\catroot2|*.chk FileKey2=%WinDir%\System32\catroot2|*.log FileKey3=%WinDir%\System32\catroot2|*.jrs FileKey4=%WinDir%\System32\catroot2|*.txt [indexing Traces*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE [Tipard Total Media Converter Platinum*] LangSecRef=3023 Detect=HKCU\Software\Tipard Studio\Tipard Total Media Converter Platinum Default=False RegKey1=HKCU\Software\Tipard Studio\Tipard Total Media Converter Platinum\Edit|LastVideoFilePath FileKey1=%LocalAppData%\Tipard Studio\Tipard Total Media Converter Platinum|*.txt [Xara Photo & Graphic Designer 6*] LangSecRef=3023 Detect=HKCU\Software\Xara\Xtreme_SE Default=False RegKey1=HKCU\Software\Xara\Xtreme_SE\6.1\Workspace FileKey1=%LocalAppData%\Xara\Xtreme_SE\6.1\Backups|*.txt ---------------------------------- MODIFIED ENTRIES Added the highlighted lines. [MAGIX Video Pro X4*] LangSecRef=3023 Detect=HKCU\Software\MAGIX AG\Videodeluxe18_pro Default=False FileKey1=%Documents%\MAGIX\Video_Pro_X4\AudioTemp|*.*|RECURSE FileKey2=%AppData%\MAGIX\Video_Pro_X4|*.log [Tipard Total Media Converter*] LangSecRef=3023 Detect=HKCU\Software\Tipard Studio\Tipard Total Media Converter Default=False RegKey1=HKCU\Software\Tipard Studio\Tipard Total Media Converter\Edit|LastVideoFilePath FileKey1=%LocalAppData%\Tipard Studio\Tipard Total Media Converter|*.txt Link to comment Share on other sites More sharing options...
SMalik Posted January 3, 2013 Share Posted January 3, 2013 How do you make an entry for Winapp2.ini to delete 'Read-only' files? Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 3, 2013 Author Share Posted January 3, 2013 not sure that you can, though I've never had issues deleting read-only files. Lots of code cleanups coming along, but few windows 8 applications. I'll try to work on that, if not for this release, than for the next. Win8 is not too popular just yet, though beep boop. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 3, 2013 Share Posted January 3, 2013 not sure that you can, though I've never had issues deleting read-only files. Lots of code cleanups coming along, but few windows 8 applications. I'll try to work on that, if not for this release, than for the next. Win8 is not too popular just yet, though beep boop. I made the entry listed below but, it is not deleting the files in that location as both the files are 'Read-only'. [saved Search Folders*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%UserProfile%\Searches|*.search-ms Link to comment Share on other sites More sharing options...
Coffee4Joe Posted January 3, 2013 Share Posted January 3, 2013 I made the entry listed below but, it is not deleting the files in that location as both the files are 'Read-only'. [saved Search Folders*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%UserProfile%\Searches|*.search-ms It works for me at deleting them but Clicking Analyze doesn't show a preview of the files beforehand (ccleaner bug?) Link to comment Share on other sites More sharing options...
SMalik Posted January 4, 2013 Share Posted January 4, 2013 It works for me at deleting them but Clicking Analyze doesn't show a preview of the files beforehand (ccleaner bug?) You're right. It is removing the files but, when Analyzing, CCleaner doesn't show these files. I just clicked the Analyze button before to see if CCleaner shows the files. Thanks for trying it. Link to comment Share on other sites More sharing options...
SMalik Posted January 4, 2013 Share Posted January 4, 2013 Could you please put [snagit 9 More*], [snagit 10 More*] and [snagit 11 More*] entries in order in the next release of Winapp2.ini. Link to comment Share on other sites More sharing options...
SMalik Posted January 4, 2013 Share Posted January 4, 2013 NEW ENTRY [saved Search Folders*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%UserProfile%\Searches|*.search-ms I have tried this on Win 7 and 8. http://windows.microsoft.com/en-US/windows7/Save-a-search Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 4, 2013 Author Share Posted January 4, 2013 how will that affect windows 7 users? also as for the snagit entries, I run a sort on it before release, so snagit keeps getting out of order because 1 comes before 9, even though 9 comes before 10. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 4, 2013 Moderators Share Posted January 4, 2013 NEW ENTRY [saved Search Folders*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%UserProfile%\Searches|*.search-ms not sure I understand, can you maybe tell us what saved searches are (I've never seen a way of saving a search, though I've never looked so make of that what you will) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 4, 2013 Author Share Posted January 4, 2013 the only two files in the folder for me were both created and modified last on the day I installed Windows. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 4, 2013 Moderators Share Posted January 4, 2013 do you add locations to your index? ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 4, 2013 Author Share Posted January 4, 2013 No, I shut my indexing off. That would probably explain that. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 4, 2013 Share Posted January 4, 2013 not sure I understand, can you maybe tell us what saved searches are (I've never seen a way of saving a search, though I've never looked so make of that what you will) http://windows.micro...7/Save-a-search I hope this answers the question. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted January 4, 2013 Moderators Share Posted January 4, 2013 http://windows.micro...7/Save-a-search I hope this answers the question. ok so the only thing cleaned is those searches? If so looks pretty good. Does that automatically also remove the shortcuts? A shortcut to the saved search will be added to the Favorites section of the navigation pane and that folder resides in that location in xp-windows8? also of concern is your entry Indexing Traces*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE does this cause dysfunction in any indexing usage? What are those folders ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted January 4, 2013 Author Share Posted January 4, 2013 Looks to me like windows will have to reindex the drives? Not sure. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted January 4, 2013 Share Posted January 4, 2013 ok so the only thing cleaned is those searches? If so looks pretty good. Does that automatically also remove the shortcuts? and that folder resides in that location in xp-windows8? also of concern is your entry Indexing Traces*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\GatherLogs\SystemIndex|*.*|RECURSE FileKey2=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\PropMap|*.*|RECURSE FileKey3=%CommonAppData%\Microsoft\Search\Data\Applications\Windows\Projects\SystemIndex\SecStore|*.*|RECURSE does this cause dysfunction in any indexing usage? What are those folders It doesn't automatically remove the shortcuts (shown in the 'shortcut' snapshot). I'm attaching the 'Indexing Traces' snapshot where you can read the details about this entry. Windows recreates a fresh index. Link to comment Share on other sites More sharing options...
Alan_B Posted January 4, 2013 Share Posted January 4, 2013 also as for the snagit entries, I run a sort on it before release, so snagit keeps getting out of order because 1 comes before 9, even though 9 comes before 10. Simple Change the name with an extra space, i.e. [snagit 9 More*] and not [snagit 9 More*] Link to comment Share on other sites More sharing options...
Coffee4Joe Posted January 4, 2013 Share Posted January 4, 2013 (edited) In 8 When you go to the Charms bar > Settings> Change PC Settings> PC Settings > Search > and click Delete Histroy. This is what it removes. New Entry plus added RegKey1 for some apps New Entry [Windows 8 Search History*] Section=3025 DetectOS=6.2| Detect=HKCU\Software\Microsoft\Windows Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Explorer\SearchHistory Edited [bing Search*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.Bing_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Bing_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.Bing_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Bing_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Bing_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Bing_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Bing_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Bing_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.Bing_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.Bing_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.Bing_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Bing_8wekyb3d8bbwe\SearchHistory [bing Finance*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.BingFinance_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.BingFinance_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingFinance_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingFinance_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingFinance_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingFinance_8wekyb3d8bbwe\SearchHistory [bing Maps*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.BingMaps_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.BingMaps_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingMaps_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingMaps_*\TempState|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingMaps*\LocalState\Bing.Maps|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.BingMaps*\AC\Microsoft\CLR_v4.0\NativeImages\Temp|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.BingMaps*\AC\Microsoft\CLR_v4.0|*.log|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingMaps_8wekyb3d8bbwe\SearchHistory [bing News*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.BingNews_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.BingNews_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingNews_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingNews_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingNews_*\TempState|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.BingNews*\LocalState\appCache|*.* RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingNews_8wekyb3d8bbwe\SearchHistory [bing Sports*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.BingSports_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.BingSports_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingSports_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingSports_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingSports_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingSports_8wekyb3d8bbwe\SearchHistory [bing Travel*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.BingTravel_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.BingTravel_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingTravel_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingTravel_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingTravel_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingTravel_8wekyb3d8bbwe\SearchHistory [bing Weather*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.BingWeather_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.BingWeather_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.BingWeather_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.BingWeather_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.BingWeather_8wekyb3d8bbwe\SearchHistory [Camera*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.Camera_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Camera_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.Camera_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Camera_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Camera_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Camera_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Camera_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Camera_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.Camera_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.Camera_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Camera_8wekyb3d8bbwe\SearchHistory [skyDrive App*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\microsoft.microsoftskydrive_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\microsoft.microsoftskydrive_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.microsoftskydrive_8wekyb3d8bbwe\SearchHistory [Microsoft Reader*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.Reader_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.Reader_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.Reader_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.Reader_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.Reader_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.Reader_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.Reader_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.Reader_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.Reader_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.Reader_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.Reader_8wekyb3d8bbwe\SearchHistory [Windows Communications Apps*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey10=%LocalAppData%\Packages\microsoft.windowscommunicationsapps_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowscommunicationsapps_8wekyb3d8bbwe\SearchHistory [Windows Photos*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\microsoft.windowsphotos_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\microsoft.windowsphotos_*\LocalState|*.*|RECURSE FileKey10=%LocalAppData%\Packages\microsoft.windowsphotos_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey11=%LocalAppData%\Packages\microsoft.windowsphotos_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\microsoft.windowsphotos_8wekyb3d8bbwe\SearchHistory [Xbox LIVE Games*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.XboxLIVEGames_*\TempState|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.XboxLIVEGames*\LocalState\ImageCache|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.XboxLIVEGames*\LocalState\PlayReady|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.XboxLIVEGames_8wekyb3d8bbwe\SearchHistory [Zune Music*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.ZuneMusic_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.ZuneMusic_*\TempState|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.ZuneMusic*\LocalState\ImageCache|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.ZuneMusic*\LocalState\PlayReady|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneMusic_8wekyb3d8bbwe\SearchHistory [Zune Video*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\Microsoft.ZuneVideo_8wekyb3d8bbwe Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\Microsoft.ZuneVideo_*\TempState|*.*|RECURSE FileKey13=%LocalAppData%\Packages\Microsoft.ZuneVideo*\LocalState\ImageCache|*.*|RECURSE FileKey14=%LocalAppData%\Packages\Microsoft.ZuneVideo*\LocalState\PlayReady|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\Microsoft.ZuneVideo_8wekyb3d8bbwe\SearchHistory [immersive Control Panel*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\windows.immersivecontrolpanel_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\windows.immersivecontrolpanel_*\TempState|*.*|RECURSE RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\windows.immersivecontrolpanel_cw5n1h2txyewy\SearchHistory [store*] Section=Windows 8 Apps DetectOS=6.2| DetectFile=%LocalAppData%\Packages\WinStore_cw5n1h2txyewy Default=False FileKey1=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\WinStore_*\AC\INetCache|*.*|RECURSE FileKey4=%LocalAppData%\Packages\WinStore_*\AC\INetCookies|*.*|RECURSE FileKey5=%LocalAppData%\Packages\WinStore_*\AC\INetHistory|*.*|RECURSE FileKey6=%LocalAppData%\Packages\WinStore_*\AC\AppCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\WinStore_*\AC\Temp|*.* FileKey8=%LocalAppData%\Packages\WinStore_*\AC\PRICache|*.* FileKey9=%LocalAppData%\Packages\WinStore_*\LocalState\Cache|*.*|RECURSE FileKey10=%LocalAppData%\Packages\WinStore_*\LocalState\navigationHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey12=%LocalAppData%\Packages\*\TempState|*.*|RECURSE FileKey13=%LocalAppData%\Packages\WinStore*\AC\Microsoft\Windows Store\Cache|*.*|RECURSE FileKey14=%LocalAppData%\Microsoft\Windows Store\Cache Medium IL|*.*|RECURSE FIleKey15=%LocalAppData%\Packages\WinStore_*\AC\Microsoft\Windows Store\Data|history.dat RegKey1=HKCU\Software\Classes\Local Settings\Software\Microsoft\Windows\CurrentVersion\AppModel\SystemAppData\WinStore_cw5n1h2txyewy\SearchHistory Edited January 4, 2013 by Coffee4Joe Link to comment Share on other sites More sharing options...
SMalik Posted January 5, 2013 Share Posted January 5, 2013 Simple Change the name with an extra space, i.e. [snagit 9 More*] and not [snagit 9 More*] Just leave it the way it is . Link to comment Share on other sites More sharing options...
SMalik Posted January 5, 2013 Share Posted January 5, 2013 MODIFIED ENTRY Added the highlighted line. [Freemake Video Downloader More*] LangSecRef=3022 Detect=HKCU\Software\Freemake\FreemakeVideoDownloader Default=False FileKey1=%Documents%\Freemake\FreemakeVideoDownloader|fvd.bin FileKey2=%ProgramFiles%\Freemake|*.txt Link to comment Share on other sites More sharing options...
Fuebar Posted January 7, 2013 Share Posted January 7, 2013 Some new entries: [Motorola Device Manager Logs*] LangSecRef=3024 DetectFile=%AppData%\Motorola\MotoHelper\installer.log Default=False FileKey1=%AppData%\Motorola\MotoHelper|installer.log NetBeans IDE installer logs and other runtime logs. [NetBeans IDE Logs*] LangSecRef=3021 DetectFile1=%UserProfile%\.nbi\log\ DetectFile2=%AppData%\NetBeans\ Default=False FileKey1=%UserProfile%\.nbi\log|*.log|RECURSE FileKey2=%AppData%\NetBeans\*\var\log|*.*|RECURSE WireShark recent files (they hold path information to the last browsed directory, and cache filters, [as far as I can tell] which could be considered insecure to some). [WireShark Recent Files*] LangSecRef=3024 DetectFile=%AppData%\Wireshark\ Warning=This will remove custom view settings (like window sizes and hidden toolbars, formatting and last-used profiles). Default=False FileKey1=%AppData%\Wireshark|recent FileKey2=%AppData%\Wireshark|recent_common And not sure if it really matters, but... capitalisation consistency in the Torchlight entry's file paths. Section=Games DetectFile=%AppData%\Runic Games\Torchlight Default=False FileKey1=%AppData%\Runic Games\Torchlight|*.log (Original had 'FileKey1=%AppData%\runic games\torchlight|*.log') Cheers. Link to comment Share on other sites More sharing options...
FreeRyde Posted January 9, 2013 Share Posted January 9, 2013 New Entries: [DiskMax*] LangSecRef=3024 Detect=HKCU\SOFTWARE\KoshyJohn.com Default=False FileKey1=%AppData%\KoshyJohn.com\DiskMax|*.txt [Farming Simulator*] Section=Games Detect=HKLM\Software\SCS Software Default=False FileKey1=%Documents%\My Games\FarmingSimulator2011|*.txt FileKey2=%Documents%\My Games\FarmingSimulator2011\pdlc2.1|*.dlc|REMOVESELF FileKey3=%Documents%\My Games\FarmingSimulator2011\shader_cache|*.xml|REMOVESELF FileKey4=%Documents%\My Games\FarmingSimulator2013|*.txt FileKey5=%Documents%\My Games\FarmingSimulator2013\pdlc|*.dlc|REMOVESELF FileKey6=%Documents%\My Games\FarmingSimulator2013\shader_cache|*.shc|REMOVESELF [Age of Empires*] Section=Games Detect=HKLM\SOFTWARE\Microsoft\Microsoft Games Default=False FileKey1=%Documents%\My Games\Age of Empires 2|*.txt FileKey2=%Documents%\My Games\Age of Mythology|*.txt FileKey3=%Documents%\My Games\Age of Empires 3|*.txt Modified entries: [Euro Truck Simulator*] Section=Games Detect1=HKCU\Software\SCS Software Detect2=HKLM\Software\SCS Software Default=False FileKey1=%Documents%\Euro Truck Simulator|*.log;*.crash FileKey2=%Documents%\Euro Truck Simulator 2|*.log;*.crash FileKey3=%ProgramFiles%\Euro Truck Simulator\licenses|*.txt|REMOVESELF FileKey4=%ProgramFiles%\Euro Truck Simulator 2\licenses|*.txt|REMOVESELF - Edited entry name - Added rules for '.crash' files - Added FileKey3 and 4 [18 Wheels of Steel*] Section=Games Detect=HKCU\Software\ValuSoft Default=False FileKey1=%Documents%\18 WoS Haulin|*.log;*.crash FileKey2=%Documents%\18 WoS American Long Haul|*.log;*.crash FileKey3=%Documents%\18 WoS Extreme Trucker|*.log;*.crash FileKey4=%Documents%\18 WoS Extreme Trucker 2|*.log;*.crash FileKey5=%ProgramFiles%\18 WoS Extreme Trucker|eula.txt FileKey6=%ProgramFiles%\18 WoS Extreme Trucker 2|eula.txt FileKey7=%ProgramFiles%\ValuSoft\18 Wheels of Steel Haulin|eula.txt FileKey8=%ProgramFiles%\ValuSoft\18 Wheels of Steel American Long Haul|eula.txt FileKey9=%ProgramFiles%\18 WoS Extreme Trucker\licenses|*.txt|REMOVESELF FileKey10=%ProgramFiles%\18 WoS Extreme Trucker 2\licenses|*.txt|REMOVESELF FileKey11=%ProgramFiles%\ValuSoft\18 Wheels of Steel Haulin\licenses|*.txt|REMOVESELF FileKey12=%ProgramFiles%\ValuSoft\18 Wheels of Steel American Long Haul\licenses|*.txt|REMOVESELF - Edited entry name - Added rules for '.crash' files - Added rules for newer 18 WoS Extreme Trucker 1&2 - Added FileKey3 through 12 Merged and Modified: [AI Roboform*] LangSecRef=3022 Detect=HKCU\Software\Siber Systems Default=False FileKey1=%ProgramFiles%\Siber Systems\AI RoboForm|*.txt FileKey2=%AppData%\RoboForm\_gsdata_mirrors_|*.*|RECURSE FileKey3=%Documents%\My RoboForm Data\_gsdata_|*.log;*.gss;*.gsl FileKey4=%Documents%\My RoboForm Data|mru.rfo;cache.rfo FileKey5=%Documents%\My RoboForm Data\*.*|mru.rfo;cache.rfo ExcludeKey1=FILE|%ProgramFiles%\Siber Systems\AI RoboForm|affid.txt RegKey1=HKCU\Software\Siber Systems\RoboForm\Query-MRU - Added rules for '.log .gss .gsl and cache.rfo' files - Added FileKey3 through 5 - Merged 'AI Roboform' and 'AI Roboform Search' entries [Ahead Nero 8*] LangSecRef=3021 Detect=HKCU\Software\Nero\Nero8 Default=False FileKey1=%AppData%\Nero\Nero8\Nero Burning ROM|*.log RegKey1=HKCU\Software\Nero\Nero8\Cover Designer\Recent File List RegKey2=HKCU\Software\Nero\Nero8\Nero - Burning Rom\Recent File List - Merged 'Ahead Nero 8 Logs' and 'Ahead Nero 8 MRU' entries Link to comment Share on other sites More sharing options...
2nd base Posted January 9, 2013 Share Posted January 9, 2013 Did something get rescribbled with this winapp file that would wipe out my search engine settings every time i run CCleaner? The winapp update is the only thing that I've done to the computer since it started happening this morning. It's annoying as all heck having to reapply my search engine settings every time i run CCleaner with this winapp file now. Link to comment Share on other sites More sharing options...
Alan_B Posted January 9, 2013 Share Posted January 9, 2013 The winapp update is the only thing that I've done to the computer since it started happening this morning. You probably also permit Microsoft updates which strike without notice, and some browsers are on rabid release cycles. Have you tried removing Winapp to confirm it is implicated ? What search engine on what browser ? Link to comment Share on other sites More sharing options...
