Compare Posted December 18, 2012 Share Posted December 18, 2012 Please Help ! Ccleaner v.3.25 whit winapp2.ini v3.25.121212 Problem!? http://www.youtube.com/watch?v=KIL3FhjKO7M&feature=youtu.be What i can do it !? Link to comment Share on other sites More sharing options...
FreeRyde Posted December 18, 2012 Share Posted December 18, 2012 weird that an EULA is in FLAC o.O but okay! Thanks! I thought so too. I have edited the post: - Forgot the asterisks in the entry's names. - Compressed FileKeys - Removed original 'FileKey1=%appdata%Nero\Nero Burning ROM|*.log'. Must have been remnant; possibly from a Nero portable. Link to comment Share on other sites More sharing options...
Alan_B Posted December 18, 2012 Share Posted December 18, 2012 What i can do it !? First, desist from double posts. Second, remove WinApp2.ini and try again. Then do NOT continue in this topic but continue with the topic you started at http://forum.piriform.com/index.php?showtopic=37449 Link to comment Share on other sites More sharing options...
FreeRyde Posted December 18, 2012 Share Posted December 18, 2012 Merged and Modified: [AI Roboform*] LangSecRef=3022 Detect=HKCU\Software\Siber Systems Default=False FileKey1=%ProgramFiles%\Siber Systems\AI RoboForm|*.txt FileKey2=%AppData%\RoboForm\_gsdata_mirrors_|*.*|RECURSE FileKey3=%Documents%\My RoboForm Data\_gsdata_|*.log;*.gss;*.gsl FileKey4=%Documents%\My RoboForm Data|mru.rfo;cache.rfo FileKey5=%Documents%\My RoboForm Data\*.*|mru.rfo;cache.rfo ExcludeKey1=FILE|%ProgramFiles%\Siber Systems\AI RoboForm|affid.txt RegKey1=HKCU\Software\Siber Systems\RoboForm\Query-MRU Tested with Roboform 7 and RoboForm Everywhere (online sync). The files rebuild and all works fine. I have yet to see 'RegKey1' in the registry, even after using 'Roboform Search'. Recommend deleting the line. Originals: [AI Roboform*] LangSecRef=3022 Detect=HKCU\Software\Siber Systems Default=False FileKey1=%ProgramFiles%\Siber Systems\AI RoboForm|*.txt FileKey2=%AppData%\RoboForm\_gsdata_mirrors_|*.*|RECURSE ExcludeKey1=FILE|%ProgramFiles%\Siber Systems\AI RoboForm|affid.txt [AI Roboform Search*] LangSecRef=3022 Detect=HKCU\Software\Siber Systems Default=False RegKey1=HKCU\Software\Siber Systems\RoboForm\Query-MRU FileKey1=%Documents%\My RoboForm Data\**|mru.rfo|RECURSE Merged: [Ahead Nero 8*] LangSecRef=3021 Detect=HKCU\Software\Nero\Nero8 Default=False FileKey1=%AppData%\Nero\Nero8\Nero Burning ROM|*.log RegKey1=HKCU\Software\Nero\Nero8\Cover Designer\Recent File List RegKey2=HKCU\Software\Nero\Nero8\Nero - Burning Rom\Recent File List Originals: [Ahead Nero 8 Logs*] LangSecRef=3021 Detect=HKCU\Software\Nero\Nero8 Default=False FileKey1=%AppData%\Nero\Nero8\Nero Burning ROM|*.log [Ahead Nero 8 MRU*] LangSecRef=3021 Detect=HKCU\Software\Nero\Nero8 Default=False RegKey1=HKCU\Software\Nero\Nero8\Cover Designer\Recent File List RegKey2=HKCU\Software\Nero\Nero8\Nero - Burning Rom\Recent File List Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 18, 2012 Author Share Posted December 18, 2012 Compare: Where are you downloading your copy of winapp2.ini from? FreeRyde: Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted December 19, 2012 Share Posted December 19, 2012 Please Help ! Ccleaner v.3.25 whit winapp2.ini v3.25.121212 Problem!? What i can do it !? Your problem is not recognised as a CCleaner Bug so your other topic has been locked This problem may take many posts with lots of unrelated posts in-between which will only distract us. I have therefore started a separate topic under Discussions and I ask that we should continue discussion in that topic "Debugging CCleaner and WinApp2.ini" http://forum.pirifor...showtopic=37464 P.S. Please include your Operating System and whether 32 bit of 64 bit in your first response to that topic Link to comment Share on other sites More sharing options...
JDPower Posted December 19, 2012 Share Posted December 19, 2012 Your problem is not recognised as a CCleaner Bug so your other topic has been locked This problem may take many posts with lots of unrelated posts in-between which will only distract us. I have therefore started a separate topic under Discussions and I ask that we should continue discussion in that topic "Debugging CCleaner and WinApp2.ini" http://forum.pirifor...showtopic=37464 P.S. Please include your Operating System and whether 32 bit of 64 bit in your first response to that topic Wow, way to confuse a new member - tell him not to post here but continue his dedicated thread instead, go to that thread and get told not to continue that original thread but continue getting help here, come back here then get told not to discuss it here or in the original thread but in a completely different thread he never even started Link to comment Share on other sites More sharing options...
Alan_B Posted December 19, 2012 Share Posted December 19, 2012 Wow, way to confuse a new member - tell him not to post here but continue his dedicated thread instead, go to that thread and get told not to continue that original thread but continue getting help here, come back here then get told not to discuss it her or in the original thread but in a completely different thread he never even started Please look again and consider who said what to whom and when and why. Double posts are generally deprecated, hence I advised continuing with the identical problem that was started under CCleaner Bugs. That topic was locked by a moderator for a valid reason that he stated, hence this became the topic for a continuation. Twas not I I am not prepared to analyse a problem that is dispersed with unrelated addition suggestions across a topic that is 130 pages and growing And since I had a diagnostic script available I chose to start a dedicated topic in the discussion forum. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 19, 2012 Moderators Share Posted December 19, 2012 A note to all: currently, yes, the moderation staff would rather all winapp2 bugs be kept in this thread, however I honestly think Alan has a bit of a point, maybe we can look at the issue again. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 19, 2012 Author Share Posted December 19, 2012 I also think it would be best to keep all winapp2.ini related discussion here, even if it seems tangential, it's likely better here than cluttering the CCleaner discussion / bug report pages. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Alan_B Posted December 19, 2012 Share Posted December 19, 2012 We only know that there is an incompatibility somewhere in the combination of :- a specific computer ; its operating system ; its installed applications ; CCleaner ; and WinApp2.ini . After watching the video it is my guess that a particular set of installed applications causes a particular set of file and/or registry detects which cause CCleaner to activate a monstrous set of application check-boxes without any names. Perhaps many names are missing because of a problem with Windows fonts. Perhaps there is a RAM defect which causes CCleaner to go into a recursive loop when it uses a critical amount of memory. There is a possibility of a defect in WinApp2.ini, BUT I would have expected this to have been evident to whoever submitted that defective entry. To me it seems better to have one more topic amongst the many thousands which gracefully expire out of sight upon completion, rather than mixing up posts with diagnostics and error reports along with the prime purpose of collating user submission in a pinned topic that never expires, I find it easier to deal with a specific problem in a specific topic so that all the information is close together when I need to refresh my memory, but would be happy for the topic to be moved into this WinApp2.ini Additions topic when the problem has been resolved. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 20, 2012 Moderators Share Posted December 20, 2012 I love Alan's batch file and look forward to the result ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 20, 2012 Author Share Posted December 20, 2012 The B in Alan_B stands for Batch. Alan_B, the Baron o' Batch Files winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Compare Posted December 20, 2012 Share Posted December 20, 2012 Your problem is not recognised as a CCleaner Bug so your other topic has been locked This problem may take many posts with lots of unrelated posts in-between which will only distract us. I have therefore started a separate topic under Discussions and I ask that we should continue discussion in that topic "Debugging CCleaner and WinApp2.ini" http://forum.pirifor...showtopic=37464 P.S. Please include your Operating System and whether 32 bit of 64 bit in your first response to that topic I installed windows 7 x64 and a new problem disappeared. Thanks man ! Link to comment Share on other sites More sharing options...
Compare Posted December 20, 2012 Share Posted December 20, 2012 Compare: Where are you downloading your copy of winapp2.ini from? FreeRyde: Thanks! http://www.winapp2.com/downloads.html most likely had a virus or I do not know what but after installation vindovs 7 problems disappear, at least for now! Link to comment Share on other sites More sharing options...
Alan_B Posted December 20, 2012 Share Posted December 20, 2012 I installed windows 7 x64 and a new problem disappeared. Thanks man ! I am pleased you fixed your problem. I am slightly disappointed my script was not needed, BUT relieved that I did not have to embark on the tedious process of :- analysing a very long CC-INFO.TXT to determine what WinApp2.ini entries corresponded to your installation ; determining where the disruption occurred ; and then entering a long series of trial and error tests. A new Windows 7 installation and everyone wins Link to comment Share on other sites More sharing options...
siliconman01 Posted December 21, 2012 Share Posted December 21, 2012 Modified Entry: [DriverMax*] LangSecRef=3024 Detect=HKCU\Software\Innovative Solutions\DriverMax Default=False FileKey1=%LocalAppData%\Innovative Solutions\DriverMax\Backup|*.* FileKey2=%LocalAppData%\Innovative Solutions\DriverMax\Temp|*.* FileKey3=%LocalAppData%\Innovative Solutions\DriverMax\TempBackup|*.* FileKey4=%LocalAppData%\Innovative Solutions\DriverMax\Agent\Downloded Drivers|*.* Added FileKey4. And "Yes", the program spelling "Downloded Drivers" is as it is spelled in the code. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
TheAslan Posted December 21, 2012 Share Posted December 21, 2012 CCleaner 3.26.1888 released Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 21, 2012 Share Posted December 21, 2012 CCleaner 3.26.1888 released I think the Mayans got him It already happened here in new york, i died. I am dead. my ghost is posting this. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 21, 2012 Author Share Posted December 21, 2012 will update winapp2.ini accordingly tonight, wasn't expecting ccleaner to update for another week and I'm about to go christmas shopping (my ghost is at least) winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 22, 2012 Author Share Posted December 22, 2012 Updated winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
SMalik Posted December 22, 2012 Share Posted December 22, 2012 MODIFIED ENTRIES [internet Explorer 10*] LangSecRef=3022 DetectFile=%LocalAppData%\Microsoft\Windows\WebCache Default=False FileKey1=%LocalAppData%\Microsoft\SmartScreen|*.tmp FileKey2=%LocalAppData%\Microsoft\Vault\*|*.vcrd FileKey3=%LocalAppData%\Microsoft\Windows\AppCache|*.*|RECURSE FileKey4=%LocalAppData%\Microsoft\Windows\WebCache.old|*.*|REMOVESELF FileKey5=%LocalAppData%\Microsoft\Windows\WebCache|*.*|RECURSE FileKey6=%LocalLowAppData%\Microsoft\Windows\AppCache|*.*|RECURSE Added the highlighted lines. ---------------------------- [Roxio Creator 2012 Pro*] LangSecRef=3021 Detect=HKCU\Software\Roxio\EMC13 Default=False RegKey1=HKCU\Software\Roxio\EMC13\VideoUI\RecentFiles\Catalogs RegKey2=HKLM\Software\Roxio\EMC13\Common SDK\Users RegKey3=HKLM\Software\Wow6432Node\Roxio\EMC13\Common SDK\Users Corrected the Detect path. ---------------------------- [TomTom*] LangSecRef=3021 Detect=HKCU\Software\TomTom Default=False FileKey1=%LocalAppData%\TomTom\HOME3\cache|*.*|RECURSE FileKey2=%LocalAppData%\TomTom\HOME3|Log.txt FileKey3=%AppData%\TomTom\HOME\Profiles\*|Log.txt Added the highlighted lines. ---------------------------- [Windows Power Efficiency Diagnostics*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows Default=False FileKey1=%CommonAppData%\Microsoft\Windows\Power Efficiency Diagnostics|*.xml ExcludeKey1=FILE|%CommonAppData%\Microsoft\Windows\Power Efficiency Diagnostics\energy-report-latest.xml Corrected the Detect path. Link to comment Share on other sites More sharing options...
SMalik Posted December 22, 2012 Share Posted December 22, 2012 Coffee4Joe provided the entry listed below a few weeks ago. It is a very useful entry. I think this should be added into the Winapp2.ini. http://forum.piriform.com/index.php?showtopic=32310&st=2440&do=findComment&comment=225010 [Windows 8 App Cache*] LangSecRef=3025 DetectOS=6.2| Detect=HKLM\SOFTWARE\Microsoft\ Default=False FileKey1=%LocalAppData%\Packages\*.*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\*.*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey4=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey5=%LocalAppData%\Packages\*.*\AC\INetCache\*.*|RECURSE FileKey6=%LocalAppData%\Packages\*\AC\INetCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\*.*\AC\INetCookies|*.*|RECURSE FileKey8=%LocalAppData%\Packages\*\AC\INetCookies|*.*|RECURSE FileKey9=%LocalAppData%\Packages\*.*\AC\INetHistory|*.*|RECURSE FileKey10=%LocalAppData%\Packages\*\AC\INetHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\*.*\AC\AppCache|*.*|RECURSE FileKey12=%LocalAppData%\Packages\*\AC\AppCache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\*.*\AC\Temp|*.* FileKey14=%LocalAppData%\Packages\*\AC\Temp|*.* FileKey15=%LocalAppData%\Packages\*.*\AC\PRICache|*.* FileKey16=%LocalAppData%\Packages\*\AC\PRICache|*.* FileKey17=%LocalAppData%\Packages\*.*\LocalState\Cache|*.*|RECURSE FileKey18=%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSE FileKey19=%LocalAppData%\Packages\*.*\LocalState\navigationHistory|*.*|RECURSE FileKey20=%LocalAppData%\Packages\*\LocalState\navigationHistory|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 22, 2012 Author Share Posted December 22, 2012 in lieu of that, I think it'd be wiser to pursue individual metro app entries. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
FreeRyde Posted December 22, 2012 Share Posted December 22, 2012 Thanks for the update. Much appreciated. Query... miss or pass? http://forum.pirifor...560#entry226815 Link to comment Share on other sites More sharing options...
