SMalik Posted November 28, 2012 Share Posted November 28, 2012 You forgot to add this one: http://forum.pirifor...440#entry225010 I have also tried the lines that were left for testing and everything looks very safe. [Windows 8 App Cache*] LangSecRef=3025 DetectOS=6.2| Detect=HKLM\SOFTWARE\Microsoft\ Default=False FileKey1=%LocalAppData%\Packages\*.*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\*.*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey4=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey5=%LocalAppData%\Packages\*.*\AC\INetCache\*.*|RECURSE FileKey6=%LocalAppData%\Packages\*\AC\INetCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\*.*\AC\INetCookies|*.*|RECURSE FileKey8=%LocalAppData%\Packages\*\AC\INetCookies|*.*|RECURSE FileKey9=%LocalAppData%\Packages\*.*\AC\INetHistory|*.*|RECURSE FileKey10=%LocalAppData%\Packages\*\AC\INetHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\*.*\AC\AppCache|*.*|RECURSE FileKey12=%LocalAppData%\Packages\*\AC\AppCache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\*.*\AC\Temp|*.* FileKey14=%LocalAppData%\Packages\*\AC\Temp|*.* FileKey15=%LocalAppData%\Packages\*.*\AC\PRICache|*.* FileKey16=%LocalAppData%\Packages\*\AC\PRICache|*.* FileKey17=%LocalAppData%\Packages\*.*\LocalState\Cache|*.*|RECURSE FileKey18=%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSE FileKey19=%LocalAppData%\Packages\*.*\LocalState\navigationHistory|*.*|RECURSE FileKey20=%LocalAppData%\Packages\*\LocalState\navigationHistory|*.*|RECURSE Link to comment Share on other sites More sharing options...
siliconman01 Posted November 28, 2012 Share Posted November 28, 2012 Winapp2 v1.0.121025 entry below shows on my XP system, and did remove QuickLaunch icons in XP. [Windows 7 QuickLaunch*] LangSecRef=3025 DetectOS=|6.1| Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\Quick Launch|*.lnk Winapp2 v1.0.121126 entry below doesn't show on my XP system. The first pipe symbol - | has been removed from the 'DetectOS' line, and has corrected the XP issue. [Windows 7/8 QuickLaunch*] LangSecRef=3025 Warning=This will remove all of your QuickLaunch icons. DetectOS=6.1| Detect=HKCU\Software\Microsoft\Internet Explorer Default=False FileKey1=%AppData%\Microsoft\Internet Explorer\Quick Launch|*.lnk Thanks for testing/showing fix for this XP problem. It is correct as issued in the latest release of Winapp2.ini. Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 28, 2012 Author Share Posted November 28, 2012 oh wow, I did fix it. Glad I'm not completely losing my mind just yet winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted November 28, 2012 Moderators Share Posted November 28, 2012 Just compared the old format to the new format, interesting result. Running them both together and separately (with and without ccleaner restarts in between) produced mostly similar results, some varying by some tenths of a second but nothing major. is the new format the use of ; in file keys? I like it when did this get discovered? I missed it. I like it. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 28, 2012 Author Share Posted November 28, 2012 I was semi-concious of it until recently when I was making an entry and I was like, "there's an entry in winapp.ini that uses semicolons, that'll probably save space" took me a few tries to workout how to recurse (initially I tried ;*.*|RECURSE;*.*2|RECURSE but that did not work) but I figured it out. Ho-ah. My intention going in was to shrink the file, the speed boost was an unintended but welcomed side effect. To clarify: yes, the new format is delimited by semi colons instead of CLRF and having separate filekeys. That entry in particular compared an extreme case of 25 file keys over thousands of folders. This is the first version to use them. The entries in winapp.ini that made me realize you can do this are [Avast! Antivirus 4] ID=2160 LangSecRef=3024 Detect=HKCU\Software\ALWIL Software\Avast\4.0 Default=True FileKey1=%ProgramFiles%\Alwil Software\Avast4\DATA\report|avast.xsl;Resident protection.txt;Simple user interface.txt;Simple user interface*.xml FileKey2=%ProgramFiles%\Alwil Software\Avast4\DATA\log|*.* [Avast! Antivirus 5] ID=2161 LangSecRef=3024 Detect=HKCU\Software\ALWIL Software\Avast\5.0 Default=True FileKey1=%ProgramData%\Alwil Software\Avast5\report|avast.xsl;avast.xsl;Resident protection.txt;Simple user interface.txt;Simple user interface*.xml FileKey2=%ProgramData%\Alwil Software\Avast5\log|*.* side note: teehee, piriform goofed and has 2 "avast.xsl" in there. I ran the same changes through winapp.ini and it'd shave 3KB off of it. Small gains and whatnot Would be far more for both files if the same format applied to RegKeys winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 28, 2012 Moderators Share Posted November 28, 2012 Can anyone explain the purpose of this entry? [Cached Shell Extensions*] LangSecRef=3025 Detect=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions Default=False RegKey1=HKCU\Software\Microsoft\Windows\CurrentVersion\Shell Extensions\Cached It cleans up the right-click context menu cache. After using it especially when right clicking you may or will notice your on-screen mouse hourglass cursor display as it rebuilds the cache - usually only takes a few short seconds. Link to comment Share on other sites More sharing options...
SMalik Posted November 30, 2012 Share Posted November 30, 2012 MODIFIED ENTRY Backups location changed http://www.acelogix.com/forums/viewtopic.php?f=1&t=4195 [Ace Utilities*] LangSecRef=3024 Detect=HKCU\Software\Acelogix\Ace Utilities Default=False FileKey1=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.reg Link to comment Share on other sites More sharing options...
Winapp2.ini Posted November 30, 2012 Author Share Posted November 30, 2012 Thanks winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
siliconman01 Posted December 1, 2012 Share Posted December 1, 2012 MODIFIED ENTRY Backups location changed http://www.acelogix.....php?f=1&t=4195 [Ace Utilities*] LangSecRef=3024 Detect=HKCU\Software\Acelogix\Ace Utilities Default=False FileKey1=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.reg Please keep the original location of the backups as well. The location change only goes into effect on fresh installs of Ace Utilities. "Over the top" upgrades retain the original location of the backups. Most users do an "Over the top" upgrade so their backup location will remain in the Documents folder. [Ace Utilities*] LangSecRef=3024 Detect=HKCU\Software\Acelogix\Ace Utilities Default=False FileKey1=%LocalAppData%\Acelogix\Ace Utilities\Backups|*.reg FileKey2=%Documents%\Ace Utilities Backups|*.reg Windows 10 x64 Pro on ASUS Maximus VIII Extreme motherboard, i7-6700k CPU,H220 X2 Liquid Cooler, 64 gbyte RipJaws DDR4 3200 RAM, Samsung 970 Pro NVMe M.2 500 gbyte SSD + Samsung 850 Pro 512 gbyte SSD, EVGA RTX 3060 Titan graphics card (Home Built System); Windows 11x64 Pro on 512 gigabyte Dell XPS 15 2-in-1 Laptop/tablet and Dell XPS 8940 PC. ASUS RT-AC88U router, 14 tbyte WD My Cloud PR2100 NAS Server, 200 Mbps cable Internet, MS Edge Chromium, MS Office 2021 (Local), Casper 11, DisplayFusion (3 Flat Panel Displays per system): Latest Bitdefender Internet Security, Quicken, Weather Watcher Live, ThumbsPlus 10, Sticky Password 8, WD Smartware, CyberLink PowerDVD23, MSI AfterBurner, Rainmeter, 8GadgetPack, and many more. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 1, 2012 Author Share Posted December 1, 2012 I had planned to keep the old location preserved as well, fear not. I usually try to maintain older locations to maximize compatibility. A recent example of this would be [TeXnicCenter*] LangSecRef=3021 Detect1=HKCU\Software\ToolsCenter\TeXnicCenter Detect2=HKCU\Software\ToolsCenter\TeXnicCenterNT Default=False RegKey1=HKCU\Software\ToolsCenter\TeXnicCenter\Recent File List RegKey2=HKCU\Software\ToolsCenter\TeXnicCenter\Recent Project List RegKey3=HKCU\Software\ToolsCenter\TeXnicCenter\Session RegKey4=HKCU\Software\ToolsCenter\TeXnicCenter\Settings\Options|LastOpenedFolder RegKey5=HKCU\Software\ToolsCenter\TeXnicCenterNT\Recent File List RegKey6=HKCU\Software\ToolsCenter\TeXnicCenterNT\Recent Project List RegKey7=HKCU\Software\ToolsCenter\TeXnicCenterNT\Session RegKey8=HKCU\Software\ToolsCenter\TeXnicCenterNT\Settings\Options|LastOpenedFolder winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
nodles Posted December 1, 2012 Share Posted December 1, 2012 MODIFIED ENTRY [Jagex Cache*] Section=Games DetectFile=%UserProfile%\jagexcache Default=False FileKey1=%WinDir%\.jagex*|*.*|REMOVESELF FileKey2=%UserProfile%\jagex*|*.*|RECURSE FileKey3=%UserProfile%|jagex* ExcludeKey1=PATH|%UserProfile%\jagexcache\jagexlauncher Added ExcludeKey1 so the entry doesn't break the launcher/client. Link to comment Share on other sites More sharing options...
FreeRyde Posted December 3, 2012 Share Posted December 3, 2012 New entry: [HyperSnap 7*] LangSecRef=3021 Detect1=HKCU\Software\Hyperionics\HyperSnap 7 Default=False FileKey1=%ProgramFiles%\HyperSnap 7|*.txt FileKey2=%ProgramFiles%\HyperSnap 7|*.url FileKey3=%Program Files (x86)%\HyperSnap 7|*.txt FileKey4=%Program Files (x86)%\HyperSnap 7|*.url RegKey1=HKCU\Software\Hyperionics\HyperSnap 7\Recent File List| Modified entry: Added RegKey1 [Conceiva Mezzmo*] LangSecRef=3023 Detect=HKLM\SOFTWARE\Conceiva Default=False FileKey1=%ProgramFiles%\Conceiva\Mezzmo|*.txt FileKey2=I:\Conceiva\Mezzmo|*.txt RegKey1=HKCU\Software\Conceiva\Mezzmo\General\LastWatchFolder| Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 3, 2012 Share Posted December 3, 2012 Modified Added FileKey 21+22 and gave it a temp section [Windows 8 App Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKLM\SOFTWARE\Microsoft\ Default=False FileKey1=%LocalAppData%\Packages\*.*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey2=%LocalAppData%\Packages\*.*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey3=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\Content|*.* FileKey4=%LocalAppData%\Packages\*\AC\Microsoft\CryptnetUrlCache\MetaData|*.* FileKey5=%LocalAppData%\Packages\*.*\AC\INetCache\*.*|RECURSE FileKey6=%LocalAppData%\Packages\*\AC\INetCache|*.*|RECURSE FileKey7=%LocalAppData%\Packages\*.*\AC\INetCookies|*.*|RECURSE FileKey8=%LocalAppData%\Packages\*\AC\INetCookies|*.*|RECURSE FileKey9=%LocalAppData%\Packages\*.*\AC\INetHistory|*.*|RECURSE FileKey10=%LocalAppData%\Packages\*\AC\INetHistory|*.*|RECURSE FileKey11=%LocalAppData%\Packages\*.*\AC\AppCache|*.*|RECURSE FileKey12=%LocalAppData%\Packages\*\AC\AppCache|*.*|RECURSE FileKey13=%LocalAppData%\Packages\*.*\AC\Temp|*.* FileKey14=%LocalAppData%\Packages\*\AC\Temp|*.* FileKey15=%LocalAppData%\Packages\*.*\AC\PRICache|*.* FileKey16=%LocalAppData%\Packages\*\AC\PRICache|*.* FileKey17=%LocalAppData%\Packages\*.*\LocalState\Cache|*.*|RECURSE FileKey18=%LocalAppData%\Packages\*\LocalState\Cache|*.*|RECURSE FileKey19=%LocalAppData%\Packages\*.*\LocalState\navigationHistory|*.*|RECURSE FileKey20=%LocalAppData%\Packages\*\LocalState\navigationHistory|*.*|RECURSE FileKey21=%LocalAppData%\Packages\*.*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE FileKey22=%LocalAppData%\Packages\*\AC\Microsoft\Internet Explorer\DOMStore|*.*|RECURSE Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 3, 2012 Author Share Posted December 3, 2012 Would it be wise to make individual entries for each windows 8 application? Or stick with that all-encompassing one? winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 3, 2012 Share Posted December 3, 2012 Would it be wise to make individual entries for each windows 8 application? Or stick with that all-encompassing one? My original goal was to make individual ones. Kind of got stuck on which ones to group and what to call the Entries... then it got out of control with 22 FileKeys Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 3, 2012 Author Share Posted December 3, 2012 Well, the good news is, that I think I have a way of making them for individual metro apps. Just waiting on an update to the application I used to make the test entry to make sure it isn't broken by updates. I don't expect it will be though. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 3, 2012 Share Posted December 3, 2012 I have these separate ones The xbox Games, Music, & Video ones I'm not sure if they'll break peoples personally saved items. The most i've used those three was to open the app to see what they were. [bing News Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKCU\Software\Classes\bingnews\ Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingNews*\LocalState\appCache|*.* [Xbox Games Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKCU\Software\Classes\xboxgames\ Default=False FileKey1=%LocalAppData%\Packages\Microsoft.XboxLIVEGames*\LocalState\ImageCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.XboxLIVEGames*\LocalState\PlayReady|*.*|RECURSE [Microsoft Music Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKCU\Software\Classes\microsoftmusic Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneMusic*\LocalState\ImageCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ZuneMusic*\LocalState\PlayReady|*.*|RECURSE [Microsoft Video Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKCU\Software\Classes\microsoftvideo Default=False FileKey1=%LocalAppData%\Packages\Microsoft.ZuneVideo*\LocalState\ImageCache|*.*|RECURSE FileKey2=%LocalAppData%\Packages\Microsoft.ZuneVideo*\LocalState\PlayReady|*.*|RECURSE [bing Map Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKCU\Software\Classes\bingmaps\ Default=False FileKey1=%LocalAppData%\Packages\Microsoft.BingMaps*\LocalState\Bing.Maps|*.*|RECURSE [store Cache*] Section=Windows 8 Apps DetectOS=6.2| Detect=HKCU\Software\ Default=False FileKey1=%LocalAppData%\Packages\WinStore*\AC\Microsoft\Windows Store\Cache|*.*|RECURSE Link to comment Share on other sites More sharing options...
FreeRyde Posted December 3, 2012 Share Posted December 3, 2012 New entries: [DVDFab 9*] LangSecRef=3023 Detect=HKCU\Software\DVDFab Default=False FileKey1=%ProgramFiles%\DVDFab 9|Changes.txt FileKey2=%ProgramFiles%\DVDFab 9|lgpl-2.1.txt FileKey3=%ProgramFiles%\DVDFab 9|License.txt FileKey4=%ProgramFiles%\DVDFab 9|License_Italian.txt FileKey5=%ProgramFiles%\DVDFab 9|Readme.txt FileKey6=%Program Files%\DVDFab 9|*.url FileKey7=%Documents%\DVDFab\Log|*.*|REMOVESELF FileKey8=%Documents%\DVDFab\Temp|*.*|REMOVESELF FileKey9=%Documents%\PcSetup|*.*|REMOVESELF RegKey1=HKCU\Software\DVDFab\V9|BuyURL [ultraISO More*] LangSecRef=3024 Detect=HKCU\Software\EasyBoot Systems Default=False FileKey1=%ProgramFiles%\UltraISO|*.txt FileKey2=%ProgramFiles%\UltraISO\backup|*.*|REMOVESELF RegKey1=HKCU\Software\EasyBoot Systems\UltraISO\5.0|LogFile RegKey2=HKCU\Software\EasyBoot Systems\UltraISO\5.0|OpenFolder English only for those interested: [ultraISO*] Section=Language Files Detect=HKCU\Software\EasyBoot Systems\UltraISO\5.0 Default=False FileKey1=%ProgramFiles%\UltraISO\lang|*.*|REMOVESELF Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 3, 2012 Author Share Posted December 3, 2012 Thanks! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 3, 2012 Moderators Share Posted December 3, 2012 Well, the good news is, that I think I have a way of making them for individual metro apps. Just waiting on an update to the application I used to make the test entry to make sure it isn't broken by updates. I don't expect it will be though. I wonder why there hasn't been an update yet, I check everyday but wonder if it has something to do with http://www.theverge.com/2012/11/11/3631108/tweetro-user-token-limit-api http://www.guardian.co.uk/technology/appsblog/2012/nov/16/twitter-tweetro-app-blocked-tokens but (just one hour before my posting this) http://www.neowin.net/news/tweetro-windows-8-app-released-for-999 (9.99 is stupid-expensive I'll keep the free one for now) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 3, 2012 Author Share Posted December 3, 2012 In a recent interview with Lazyworm Applications co-founder Atta Elayyan, he told Neowin that the people who have already downloaded the previous free version of Tweetro will have to pay the full price of Tweetro+ in order to continue to use the app. Oh. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 4, 2012 Moderators Share Posted December 4, 2012 And the First major victim of the new twitter API happens booooooo back to topic ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted December 4, 2012 Author Share Posted December 4, 2012 I guess I could just install a bunch of metro apps and wait till one has an update to make an entry for it and test. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Nergal Posted December 4, 2012 Moderators Share Posted December 4, 2012 the CBZ reading apps get a lot of updates everyone we shall start the bidding here ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Coffee4Joe Posted December 5, 2012 Share Posted December 5, 2012 (edited) Modified DetectFile to Detect [Windows Sticky Notes Cache*] LangSecRef=3021 Warning=Selecting this will also delete all sticky notes currently in use. Detect=HKLM\SOFTWARE\Classes\StickyNotes Default=False FileKey1=%AppData%\Microsoft\Sticky Notes|*.snt FileKey2=%UserProfile%\Searches|Sticky Notes (Windows Sticky Notes).searchconnector-ms Modified DetectFile from %AppData%\IObit\IObit Uninstaller\log to %AppData%\IObit\IObit Uninstaller\ [iObit Uninstaller Logs*] LangSecRef=3024 DetectFile=%AppData%\IObit\IObit Uninstaller\ Default=False FileKey1=%AppData%\IObit\IObit Uninstaller\Log|*.log Edited December 5, 2012 by Coffee4Joe Link to comment Share on other sites More sharing options...
