JDPower Posted March 20, 2011 Share Posted March 20, 2011 The services window has been displaying wrong for a while now on my XP laptop and now the exact same thing has happened on another XP machine. Anyone got any clue what's causing this: Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 20, 2011 Share Posted March 20, 2011 Are both of your laptops using (what looks like) a windows 7 theme? Try setting it back to the default Luna and open it again. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
JDPower Posted March 20, 2011 Author Share Posted March 20, 2011 Are both of your laptops using (what looks like) a windows 7 theme? Try setting it back to the default Luna and open it again. No, one is using a Vista style theme, the other is using the default XP theme(and resetting, or turning off, themes makes no difference) Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 20, 2011 Share Posted March 20, 2011 If you have the install disc (some systems have an i386 folder located at the root directory also,) try running system file check. I really have no idea what would cause such a strange error, unless some piece of software you had on both systems damaged the file somehow. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 20, 2011 Moderators Share Posted March 20, 2011 I recently had the exact same problem JD, and I couldn't find a fix, or a cause. I even replaced the "services.msc" file in system32 with one from my daughters Notebook, but that didn't make any difference at all, so it isn't a problem with with the file, and I messed about with everything else I could think of. It only got fixed by restoring an Image, although I didn't do the restore for that reason. It's a weird one to be sure. I'm running XP SP3 with no installed themes, or any other graphic type "add-ons" which could be the cause. I would love to know the answer, but googling didn't bring up anything. EDIT: Forgot, I took a screenshot at the time, for what it's worth. Link to comment Share on other sites More sharing options...
JDPower Posted March 20, 2011 Author Share Posted March 20, 2011 Sods law I'd find someone who had the same problem, and no fix lol. Not gonna do an image restore just for this, its a minor annoyance more than anything. Just wish I knew what the common link was that caused it. Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 20, 2011 Moderators Share Posted March 20, 2011 I read somwhere that someone had a similar problem and they sorted it by updating the driver for their Logitech mouse. Do you have setpoint.exe? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
JDPower Posted March 20, 2011 Author Share Posted March 20, 2011 Yeah I found that when Googling Hazel, neither have Logitech mice (both are laptops) or setpoint Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 20, 2011 Moderators Share Posted March 20, 2011 Shame, thought it was worth a mention just in case JD. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
JDPower Posted March 20, 2011 Author Share Posted March 20, 2011 No probs, appreciate all and any possible solutions Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 20, 2011 Moderators Share Posted March 20, 2011 Sods law I'd find someone who had the same problem, and no fix lol. Not gonna do an image restore just for this, its a minor annoyance more than anything. Just wish I knew what the common link was that caused it. Let me know when that minor annoyance becomes a major niggle. Now that I know I wasn't alone with the glitch, I'm more keen to find the common denominator we must share. I'll have a think as to what I lost when I did the restore. The Image was only a couple of months old and I still have it, so I'll mount it as a drive and compare it with my current C: drive and see if anything obvious jumps out. Out of interest, I don't have setpoint.exe either but worth a shot hazel. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted March 20, 2011 Share Posted March 20, 2011 Maybe microsoft is sabotaging Windows XP boxes, so you'll buy Windows 7 ! winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 21, 2011 Moderators Share Posted March 21, 2011 I have that blacked out s**t in Windows Add/Remove Programs, I'm at the point of thinking it's some borked Windows Update that did it because I've seen it on a bunch of Windows XP machines and the only thing they'd all have 100% in common is Windows Updates. You can get yourself a small free replacement for the Services.msc, it's Nirsoft ServiWin!!! In Nirsoft ServiWin you'd need to change the display to services by clicking: View->Services Screenshot: Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 21, 2011 Moderators Share Posted March 21, 2011 Two other things that come to mind. 1. Nvidia grapics cards? 2. Does it still happen when you open services.msc in safe mode? Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted March 21, 2011 Moderators Share Posted March 21, 2011 In my case of having that blacked out area (only in Add/Remove Programs) it happened even with an ATI card. I had the blacked out area with a messed up XP install, and it happened immediately after a fresh install after doing some Windows Updates, that was back in January 2010. Link to comment Share on other sites More sharing options...
TeeJay3800 Posted March 21, 2011 Share Posted March 21, 2011 I had a very similar problem on my XP SP3 machine several weeks ago, but rather than affecting the Services window, it affected the Windows Security Center. I never did find a fix, so I ended up formatting and re-installing Windows from scratch. That obviously doesn't help you, just thought I'd share. Dell Latitude D600 Windows 7 Ultimate 32-bit SP1 Link to comment Share on other sites More sharing options...
JDPower Posted March 22, 2011 Author Share Posted March 22, 2011 Two other things that come to mind. 1. Nvidia grapics cards? 2. Does it still happen when you open services.msc in safe mode? 1. Nope, one an ATI, one an Intel onboard gfx 2, Yup, still happens in safe mode. I'm glad I'm not the only one at a total loss to explain how the hell it happened. And thanks for the ServiWin suggestion Andavari, at least that's a usable workaround Link to comment Share on other sites More sharing options...
