CSGalloway Posted March 17, 2011 Share Posted March 17, 2011 Seems that not all of a message posting is being sent by email. Case in point: ============ Begin Paste ================= CSGalloway, randomcore has just posted a reply to a topic that you have subscribed to titled "Get the Latest Winapp2.ini File". ---------------------------------------------------------------------- ------------ QUOTE ---------- ----------------------------- why to exclude the virtual RegHives? can get wiped, too. if you clear the sandbox using sandboxie control the RegHive file won't remain. everything behind your username will be deleted. so after cleanup there is no "DefaultBox" and because of this there are no RegHives inside of DefaultBox. the only file that remains is "DONT-USE.TXT" ---------------------------------------------------------------------- The topic can be found here: http://forum.piriform.com/index.php?showtopic=29438&view=getnewpost If you have configured in your control panel to receive immediate topic reply notifications, you may receive an email for each reply made to this topic. Otherwise, only 1 email is sent per board visit for each subscribed topic. This is to limit the amount of mail that is sent to your inbox. Unsubscribing: -------------- You can unsubscribe at any time by logging into your control panel and clicking on the "Manage Watched Topics" link in the "Forums" tab. ============ End Paste ================= Can this be fixed please? Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted March 17, 2011 Moderators Share Posted March 17, 2011 Are you using IE9? Also I think the poster may have edited his post. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Nergal Posted March 17, 2011 Moderators Share Posted March 17, 2011 I think it's more that the email system is told not to include either quote or code (my emails look the same) here is the original post (...) I'd like to see an option to erase the contents of Sandboxie's default container folder. (...) ... ExcludeKey1=FILE|%SystemDrive%\Sandbox\%UserName%\DefaultBox\RegHive* ... why to exclude the virtual RegHives? can get wiped, too. if you clear the sandbox using sandboxie control the RegHive file won't remain. everything behind your username will be deleted. so after cleanup there is no "DefaultBox" and because of this there are no RegHives inside of DefaultBox. the only file that remains is "DONT-USE.TXT" ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
