CCleaner Community Forums
Sign in to follow this
Knighmare
HDD Weird Sound
It first happened when I was checking email, and now it's happening while I'm watching a video on the internet. It's like a grinding/scratching sound coming from the HDD. Nothing appears to be wrong with my files when this happens, but I was hoping that I could post my HDD's Speccy report and see if something is bad. Check it out:
Hard Drives
	TOSHIBA MK5065GSX ATA Device
		Manufacturer	TOSHIBA
		SATA type	SATA-II 3.0Gb/s
		Device type	Fixed
		ATA Standard	ATA8-ACS
		48-bit LBA	Supported
		Serial Number	80QIB1LFB
		Interface	SATA
		Capacity	488GB
		Real size	500,107,862,016 bytes
			S.M.A.R.T
				01 Read Error Rate	100 (100 worst) Data 0000000000
				02 Throughput Performance	100 (100) Data 0000000000
				03 Spin-Up Time	100 (100) Data 00000007C1
				04 Start/Stop Count	100 (100) Data 00000002C4
				05 Reallocated Sectors Count	100 (100) Data 0000000000
				07 Seek Error Rate	100 (100) Data 0000000000
				08 Seek Time Performance	100 (100) Data 0000000000
				09 Power-On Hours (POH)	099 (099) Data 0000000278
				0A Spin Retry Count	114 (100) Data 0000000000
				0C Device Power Cycle Count	100 (100) Data 00000002C4
				BF G-sense error rate	100 (100) Data 0000000016
				C0 Power-off Retract Count	100 (100) Data 0000000006
				C1 Load/Unload Cycle Count	100 (100) Data 0000001802
				C2 Temperature	100 (100) Data 00000F002D
				C4 Reallocation Event Count	100 (100) Data 0000000000
				C5 Current Pending Sector Count	100 (100) Data 0000000000
				C6 Uncorrectable Sector Count	100 (100) Data 0000000000
				C7 UltraDMA CRC Error Count	200 (200) Data 0000000000
				DC Disk Shift	100 (100) Data 0000000047
				DE Loaded Hours	099 (099) Data 000000019B
				DF Load/Unload Retry Count	100 (100) Data 0000000000
				E0 Load Friction	100 (100) Data 0000000000
				E2 Load 'In'-time	100 (100) Data 0000000157
				F0 Head Flying Hours	100 (100) Data 0000000000
				Temperature	114 ?F
				Temperature Range	ok (less than 122 ?F)
				Status	Good
			Partition 0
				Partition ID	Disk #0, Partition #0
				Size	100 MB
			Partition 1
				Partition ID	Disk #0, Partition #1
				Disk Letter	C:
				File System	NTFS
				Volume Serial Number	A81A205E
				Size	466GB
				Used Space	107GB (23%)
				Free Space	359GB (77%)
Share this post
Link to post
As long as it's not continuous grinding sound or knocking noise then you should have anything to worry about.
You might want to consider changing your AMM settings.
If you suspect your hard drive is dying then a bench check test using HD Tune should be able to confirm this.
Richard S.
Share this post
Link to post
Register a new account
Sign in
