beyondhelp Posted November 11, 2005 Share Posted November 11, 2005 I performed "scan for issues", fix issues, and re-ran the "scan for issues". The same issues re-appear. What may be wrong? Link to comment Share on other sites More sharing options...
Glenn Posted November 11, 2005 Share Posted November 11, 2005 The entire same list? or just some? Any specific categories? Link to comment Share on other sites More sharing options...
beyondhelp Posted November 12, 2005 Author Share Posted November 12, 2005 Exact same items in issues list. Link to comment Share on other sites More sharing options...
Glenn Posted November 12, 2005 Share Posted November 12, 2005 Just to make sure ... as a final step, did you see a panel like this and click either "Fix Issue" or "Fix All Selected Issues"? Link to comment Share on other sites More sharing options...
Admin MrG Posted November 12, 2005 Admin Share Posted November 12, 2005 You need to be logged in as an administrator to remove some of the issues. Piriform.com - [CCleaner - Defraggler - Recuva - Speccy] Link to comment Share on other sites More sharing options...
beyondhelp Posted November 12, 2005 Author Share Posted November 12, 2005 Just to make sure ... as a final step, did you see a panel like this and click either "Fix Issue" or "Fix All Selected Issues"? 22030[/snapback] I did have this screen, all items were checked, and "fix all issues" were clicked. After the items were supposedly fixed, I scaned for issues again, and the same issues re-appeard. Link to comment Share on other sites More sharing options...
beyondhelp Posted November 12, 2005 Author Share Posted November 12, 2005 You need to be logged in as an administrator to remove some of the issues. 22043[/snapback] I have the same problem wether I'm logged in as administrator, or user. The only difference is, different issues appear. (Differnt issues between Admin. and user.) Scanning again ( as either administrator or user ) the same issues re- appear, depending on which user IS logged in. Link to comment Share on other sites More sharing options...
SenutyEnool Posted November 14, 2005 Share Posted November 14, 2005 Is it not recommeded to reboot after having 'Fixed' the issues? Or am I barking up the wrong tree on this? The reason I ask is because I have the same problem. Upon fixing the issues and re-scanning the same ones re-appear. Cheers Link to comment Share on other sites More sharing options...
