CCleaner Community Forums
Intelligent cookie cleaning function
Hello
I would like to know how I can enable/disable the new intelligent cookie cleaning function after CCleaner install.
Right after installation you have to choice if you want to enable/disable this function, but I could not find this in the options to change this afterwards.
I also would like to know how exactly this function works. Sounds interesting, but I would like to customize which cookies should be kept.
Link to post
  • Moderators
Go to Options>cookies
Right Click on the area with cookies to delete
and choose intelligent scan
Link to post
I think cookies to keep is a manual entry for each file whereas the intelligent scan conserves the cookies in a manner that is more automatic by scanning for useful cookies and keeping them. The end result is the same but one is less time consuming and more autonomous than the other.
Link to post
  • 3 years later...
Guest
This topic is now closed to further replies.
