Guest Shane0500 Posted December 14, 2010 Share Posted December 14, 2010 Windows Security Center: "Microsoft Security Essentials reports that it is turned off" Microsoft Security Essentials: "Microsoft Security Essentials is monitoring your computer and helping to protect it" How are these two things happening at the same time? Ive tried rebooting, no luck Ive tried disabling and re-enabling MSE real-time protection, no luck Ive updated MSE fully, no luck MS Windows XP Media Center Edition Professional 32-bit SP3 Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 14, 2010 Moderators Share Posted December 14, 2010 There are a few things here you could try, let us know how you get on please Shane. http://social.answers.microsoft.com/Forums/en/msestart/thread/ab9feb76-cfe6-45c7-b49f-10d0b0251dac Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Moderators Andavari Posted December 14, 2010 Moderators Share Posted December 14, 2010 There's also this where you may need to rebuild the WMI database for Security Center to properly report the status of installed security software such as antivirus. Link to comment Share on other sites More sharing options...
Guest Shane0500 Posted December 18, 2010 Share Posted December 18, 2010 Tried the other steps to fix the main problem, now another problem! 1. Uninstalled MSE 2. Got an error upon uninstall 3. Manually deleted the files and registry stuff related to MSE 4. Cant install MSE 2.0 I have the mseinstall.exe file saved, I get to the ready to install part, then: ---------------------------------------------------------------------------------- Cannot complete the Security Essentials installation An error has prevented The Security Essentials setup wizard from completing successfully. Please restart your computer and try again. Error Code:0x80070463 I have restarted and tried again The windows installer service starts automatically on startup I even used the OneCare cleanup tool (removed quite a lot of junk) Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 18, 2010 Moderators Share Posted December 18, 2010 Is your error code 0x80070463 as you say, or is it as in the thread below 0X80070643 ? Did you follow this thread? http://social.answers.microsoft.com/Forums/en-US/msestart/thread/2f8fa0b8-501c-4c6e-8858-f64aa377e587 Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Guest Shane0500 Posted December 18, 2010 Share Posted December 18, 2010 Error Code: 0x80070643 I have uninstalled all spyware/virus programs The windows installer service runs automatically on startup I have ran the OneCare cleanup utility I am pretty sure I have windows installer 3.1 as I am up-to-date with microsoft update Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted December 18, 2010 Moderators Share Posted December 18, 2010 Although it is no longer downloadable from Microsoft because it had problems with Microsoft office files, it may be worthwhile trying the Windows Installer CleanUp Tool still available from here http://majorgeeks.com/Windows_Installer_CleanUp_Utility_d4459.html Look for Microsoft Security Essentials in the list and click remove, then reboot. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Guest Shane0500 Posted December 19, 2010 Share Posted December 19, 2010 Downloaded Appremover (security program remover) removed Cyberdefender antivirus and antispyware, their website is rated RED by WOT, as a scam site. Used the cleanup tool to remove Microsoft Security Essentials and Microsoft Antispyware Downloading MSE at the moment, ill get back to you if it works or not. THANKS A BUNCH! Link to comment Share on other sites More sharing options...
Guest Shane0500 Posted December 19, 2010 Share Posted December 19, 2010 Everything working beautifully now, security center shows green for antivirus, that problem solved. MSE installed nicely, updated and running without problems, I like the wierd spiderweb layout of version 2. Thank you for helping me. Link to comment Share on other sites More sharing options...
