?10 Posted November 4, 2005 Share Posted November 4, 2005 Found this brilliant free music file convertor.I wanted to change my wma files all to mp3 files and it did it easily and quickly.theres a few more other files it converts either way.wav, ogg etc. Go to www.download.com and type in "Switch 1.05" ( without inverted commas) It's a very small download, and so easy to use.Theres no adware/spyware, as I have checked with Webroot Spysweeper and Trend Micro. Good Luck Link to comment Share on other sites More sharing options...
Moderators rridgely Posted November 5, 2005 Moderators Share Posted November 5, 2005 I have been using cheetah audio converter. http://www.download.com/3000-2140_4-10280605.html Link to comment Share on other sites More sharing options...
yinyang4evry1 Posted November 5, 2005 Share Posted November 5, 2005 does any of them convert MIDI files to mp3? thanks, tim =) Link to comment Share on other sites More sharing options...
Moderators Andavari Posted November 5, 2005 Moderators Share Posted November 5, 2005 does any of them convert MIDI files to mp3? thanks, tim =) <{POST_SNAPBACK}> If you by any chance use Winamp you can output them as .wav using the disk writer and then encode them with whatever mp3 encoder you wish. Link to comment Share on other sites More sharing options...
Matt_ Posted November 5, 2005 Share Posted November 5, 2005 I personally use LAME with the RazorLAME U.I to encode my .mp3 files and decode them to the .wav file format. http://fileforum.betanews.com/detail/LAME/955435184/1 (LAME build 3.97) http://fileforum.betanews.com/detail/RazorLame/1011170460/1 (RazorLAME build 1.15) Both freeware and easy to use. http://www.last.fm/user/Matt714 Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted November 6, 2005 Moderators Share Posted November 6, 2005 I use the free Easy CD-DA Extractor. Does mp3,wav,ogg and others. Drag, drop press button! http://www.poikosoft.com/ Also rips CD's as well. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
kika Posted November 6, 2005 Share Posted November 6, 2005 I am using "CD MP3 Terminator" Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted November 6, 2005 Moderators Share Posted November 6, 2005 does any of them convert MIDI files to mp3? thanks, tim =) <{POST_SNAPBACK}> You can use this free for a month, just time to do them all!! http://www.allformp3.com/convert-midi-to-wav.htm Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Eldmannen Posted November 7, 2005 Share Posted November 7, 2005 Convert them to Ogg Vorbis (.ogg) instead of MP3. That way you get a smaller file size due to better compression while at the same time get higher quality than you would if used MP3. And Matt_ uses good tools, LAME and RazorLAME are good products. LAME is known as the best. Everyone with knowledge about ripping, encoding/decoding use LAME. Link to comment Share on other sites More sharing options...
yinyang4evry1 Posted November 7, 2005 Share Posted November 7, 2005 thanks a bunch ya'll =) tim Link to comment Share on other sites More sharing options...
?10 Posted November 8, 2005 Author Share Posted November 8, 2005 No sorry it doesnt.Its a completely different source Link to comment Share on other sites More sharing options...
?10 Posted November 8, 2005 Author Share Posted November 8, 2005 Cheers... i'll keep that one in mind too Link to comment Share on other sites More sharing options...
