Aethec Posted October 28, 2010 Share Posted October 28, 2010 There's not enough space...the second line (or, rather, the third one since the first one is split) doesn't show. Now French users have no way to wipe their drives. Is it possible to force the dialog to have enough height, or should I remove the line break? Piriform French translator Link to comment Share on other sites More sharing options...
Guest MrT Posted October 28, 2010 Share Posted October 28, 2010 Thanks. We'll look into this. Link to comment Share on other sites More sharing options...
Whiteshark Posted October 29, 2010 Share Posted October 29, 2010 Had the same issue, and fixed it by myself, deleting the wordwrap ( \n ) in my translation: Bad: ATTENZIONE! TUTTI I DATI PRESENTI SUI DRIVE SELEZIONATI VERRANNO DISTRUTTI!\nPer procedere, digita la parola %1 nella casella sottostante: Good: ATTENZIONE! TUTTI I DATI PRESENTI SUI DRIVE SELEZIONATI VERRANNO DISTRUTTI! Per procedere, digita la parola %1 nella casella sottostante Guide in italiano per CCleaner - Recuva - Defraggler - Speccy Link to comment Share on other sites More sharing options...
Aethec Posted October 29, 2010 Author Share Posted October 29, 2010 Yup. But for now no French user can wipe his drive Piriform French translator Link to comment Share on other sites More sharing options...
