Newt Posted October 24, 2010 Share Posted October 24, 2010 Hi, Recently, CCleaner has added the option under System to clean FTP Accounts. Could you please provide more information about what this does? I'm wondering what the implications are, if this is selected. I am using Windows XP Home SP 3. Thanks, Newt Link to comment Share on other sites More sharing options...
kroozer Posted October 24, 2010 Share Posted October 24, 2010 FTP is File Transfer Protocol. See here for an explanation. Link to comment Share on other sites More sharing options...
Newt Posted October 24, 2010 Author Share Posted October 24, 2010 FTP is File Transfer Protocol. See here for an explanation. Thanks for your reply. I am familiar with FTP itself (I have used FileZilla client to upload files such as web pages to remote servers). However, I am not sure what "FTP Account" means in the context of my local system that CCleaner cleans. Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 24, 2010 Moderators Share Posted October 24, 2010 This has been asked often but hasn't yet been answered by the devs however what it does is delete (which windows will remake empty) the registry key HKCU\Software\Microsoft\Ftp\Accounts This key stores the information that is made when you use windows explorer to connect to a ftp (file transfer protocol) site (i.e. a remotly stored website directory where you upload your website to make it live). This key has the following information: Site, Username, Password. ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
Newt Posted October 25, 2010 Author Share Posted October 25, 2010 Thanks for your explanation. I have not used FTP in Windows Explorer before (I use a stand-alone client, such as FileZilla). Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 26, 2010 Moderators Share Posted October 26, 2010 If I get a chance I plan on downloading filezilla to make a ccleaner winapp2.ini entry. So that may be coming soon (No Promises ) ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
