mrdoc Posted September 16, 2010 Share Posted September 16, 2010 Hi I have been using ccleaner for few years and i simply love it.. recently i have noticed that when i run it, it is not cleaning everything in google chrome e.g. autocomplete history and recently visited websites (displayed when i open a new blank tab). I have not changed any settings recently.. Anybody has any idea about it? Thanks Link to comment Share on other sites More sharing options...
Moderators Nergal Posted September 18, 2010 Moderators Share Posted September 18, 2010 Hi I have been using ccleaner for few years and i simply love it.. recently i have noticed that when i run it, it is not cleaning everything in google chrome e.g. autocomplete history and recently visited websites (displayed when i open a new blank tab). I have not changed any settings recently.. Anybody has any idea about it? Thanks uncheck google chrome - sessions ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
mrdoc Posted September 18, 2010 Author Share Posted September 18, 2010 did.. no luck.. Link to comment Share on other sites More sharing options...
Field of Stones Posted September 24, 2010 Share Posted September 24, 2010 I am having the same issue. CCleaner will not remove my Google Chrome saved form information. I have to use Google Chrome's "Clear Browsing Data..." option to clean everything out. I am using Windows 7 64-bit with Chrome's latest version [6.0.472.63]. Everything worked fine before I downloaded CCleaner's latest version [2.35.1223]. Sincerely, FoS Link to comment Share on other sites More sharing options...
Bananaman Posted September 30, 2010 Share Posted September 30, 2010 I, too, am experiencing this. I'm running Google Chrome 6.0.472.63 and CCleaner 2.35.1223 on Vista Ultimate 32-bit. Unchecking "session" did not resolve the issue. Link to comment Share on other sites More sharing options...
Guest MrT Posted September 30, 2010 Share Posted September 30, 2010 Thanks, we'll look into this. Link to comment Share on other sites More sharing options...
mrdoc Posted October 14, 2010 Author Share Posted October 14, 2010 the recent update v 2.36.1233 didnt fix it Link to comment Share on other sites More sharing options...
mrdoc Posted October 29, 2010 Author Share Posted October 29, 2010 problem solved in new version 3.0.. Thanks team ccleaner.. Link to comment Share on other sites More sharing options...
