Jerry86 Posted August 28, 2010 Share Posted August 28, 2010 Hi, I want you ask to support some other popular browsers: Orca Browser, Avant Browser And: Open Office, Java (Sun)e.g. there are rubbish in Documents and Settings\XYZ\Dane aplikacji\Sun\Java\Deployment Nokia products should be added too, because it left a lot of things on hdd: C:\Documents and Settings\All Users\Dane aplikacji\NokiaInstallCache (or sth like that) unncesessary installations may be deleted too: C:\Documents and Settings\All Users\Dane aplikacji\Installations Google Chrome old installation file: C:\Documents and Settings\XYZ\Ustawienia lokalne(local settings)\Dane aplikacji (application data)\Google\Chrome\Application Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 28, 2010 Share Posted August 28, 2010 Hi, and welcome to the forums. As far as my research shows, it is safe to delete the deployment cache [*Java Deployment Cache] LangSecRef=3022 DetectFile=%ProgramFiles(x86)%\java\jre6\bin\java.exe DetectFile=%programfiles%\Java\jre6\bin\java.exe Default=True FileKey1=%appdata%\Sun\Java\Deployment\cache|*.*|RECURSE FileKey2=%appdata%\Sun\Java\Deployment\javaws\cache|*.*|RECURSE FileKey3=%locallowappdata%\Sun\Java\Deployment\cache|*.*|RECURSE FileKey4=%locallowappdata%\Sun\Java\Deployment\javaws\cache|*.*|RECURSE If you do not already have a winapp2.ini file, please place that in a text file and save it as "winapp2.ini" in your CCleaner directory. If you do have a winapp2.ini file, add that to it. I cannot help with your other requests. Perhaps another forum member could. winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Saintj Posted August 28, 2010 Share Posted August 28, 2010 Hi, and welcome to the forums. As far as my research shows, it is safe to delete the deployment cache [*Java Deployment Cache] LangSecRef=3022 DetectFile=%ProgramFiles(x86)%\java\jre6\bin\java.exe DetectFile=%programfiles%\Java\jre6\bin\java.exe Default=True FileKey1=%appdata%\Sun\Java\Deployment\cache|*.*|RECURSE FileKey2=%appdata%\Sun\Java\Deployment\javaws\cache|*.*|RECURSE FileKey3=%locallowappdata%\Sun\Java\Deployment\cache|*.*|RECURSE FileKey4=%locallowappdata%\Sun\Java\Deployment\javaws\cache|*.*|RECURSE If you do not already have a winapp2.ini file, please place that in a text file and save it as "winapp2.ini" in your CCleaner directory. If you do have a winapp2.ini file, add that to it. I cannot help with your other requests. Perhaps another forum member could. A bit offtopic but it might be helpfull to the poster aswell, could you link the Winapp2.ini link, search came up with to much stuff to find the right post xD Thanks, Saint. Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 28, 2010 Share Posted August 28, 2010 Surely. The "official" winapp2.ini is located here if you use windows vista/7 or 64 bit versions of windows, you may want to check out this winapp2.ini which provides for support for xp, vista, and 7 32/64bit winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
Saintj Posted August 28, 2010 Share Posted August 28, 2010 Surely. The "official" winapp2.ini is located here if you use windows vista/7 or 64 bit versions of windows, you may want to check out this winapp2.ini which provides for support for xp, vista, and 7 32/64bit Thanks alot Well I got multiple systems really but I was looking for the XP one (Still the most stable out of the 3 if you ask me... *sigh* dmn microsoft lol) But again thanks I can add some stuff, still looking for the paths to clean in XBMC and some other apps (but that's for home use really ) Greetz, Saint. Link to comment Share on other sites More sharing options...
Kand.in.Sky Posted September 20, 2010 Share Posted September 20, 2010 ORCABROWSER is "only" a new GUI for the Gecko. Folders, Data, handling etc.. is the same as on FireFox. AVANTBROWSER is the same, based on the IE. You can use AVANT on nearly any IE-Version. It works on IE5 just as it works on IE9. it should be not very diffucult to add ORCA support to CC. greetings, #k. Link to comment Share on other sites More sharing options...
Jerry86 Posted January 20, 2011 Author Share Posted January 20, 2011 ORCABROWSER is "only" a new GUI for the Gecko. Folders, Data, handling etc.. is the same as on FireFox. AVANTBROWSER is the same, based on the IE. You can use AVANT on nearly any IE-Version. It works on IE5 just as it works on IE9. it should be not very diffucult to add ORCA support to CC. greetings, #k. Yeah you have right, orca and avant have all files in profile folder Link to comment Share on other sites More sharing options...
Jerry86 Posted September 24, 2011 Author Share Posted September 24, 2011 Why CCleaner doesn't support Temp folders ? c:\Documents and Settings\XYZ\Ustawienia lokalne\Temp\ (ustawienia localne = local settings) I noticed that I have there 8gb of trash. I haven't checked my profile folder because I use CCleaner and I thought that i don't have to search manually for trash but unofrtunately i have to. Please add support of temp folders in Windows XP temp/temporary internet folder etc. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted September 24, 2011 Moderators Share Posted September 24, 2011 It should be cleaning your temp folders. Unless you have some environment variables configured differently. On XP you can find out where your temp folders are mapped to by: 1. Right click: My Computer, and select Properties 2. Click: Advanced (tab) > Environment Variables (button) Or you can input your Temp folder as an Include in CCleaner: 1. You'll first need to open in Windows the 'Folder Options' and then enable the view of 'Hidden Files and Folders' to add your temp path. Remember to undo this setting when done. 2. In CCleaner: 'Options > Include', then select the path you want to clean. 3. Then under 'Cleaner > Windows > Advanced', enable/tick 'Custom Files and Folders' so it will clean your Include path. Recommend using Analyze first though before committing to Delete! Link to comment Share on other sites More sharing options...
Moderators DennisD Posted September 24, 2011 Moderators Share Posted September 24, 2011 You beat me to it Andavari. Win XP SP3 here, and that temp file is cleaned ... ... however that particular folder is used by Avast occasionally, so I'm wondering if you may have any protected files in that location. Just a thought. Link to comment Share on other sites More sharing options...
Jerry86 Posted October 4, 2011 Author Share Posted October 4, 2011 I have had a few gigabytes of trash in temp folder i don't know why Ccleaner won't cleaned it up I must say that registry cleaning function in CCleaner sux! I've used it and I lost my settings in Orca Browser, Tlen.pl Communicator and few other applications and what's weird i've lost my savegame in game Blacksite Area 51 Before cleaning up the registry all was fine, unfortunately i didn't used registy backup - this should be made automatically Link to comment Share on other sites More sharing options...
Moderators Andavari Posted October 4, 2011 Moderators Share Posted October 4, 2011 I must say that registry cleaning function in CCleaner sux! I've used it and I lost my settings in Orca Browser, Tlen.pl Communicator and few other applications In version 3.11 it has been tamed down allot and is safer. However as with any registry cleaner you may or will need to input some exclusions. To learn how to exclude something in the registry cleaner see this post: http://forum.piriform.com/index.php?showtopic=33247&view=findpost&p=199605 Link to comment Share on other sites More sharing options...
Moderators Nergal Posted October 11, 2011 Moderators Share Posted October 11, 2011 uncheck only delete window temporary files older than 24 hours it's in options»advanced if the language is opposite in the setting I apologize, I am not on a PC right now ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
