MrFahd 0 Posted September 1, 2010 Share Posted September 1, 2010 There was a bug in CCleaner v2.35.1219 which was not detecting Adobe Flash Cookies. There is a new version of CCleaner v2.35.1223 which is available and this issue has been resolved Link to post Share on other sites
Willy2 0 Posted September 3, 2010 Share Posted September 3, 2010 I installed the latest version (v2.35.1223) and I am puzzled. When I compare the embedded *.INI file info of v2.35.1219 with v2.35.1223 I don't see any changes but in spite of that the latest version does detect Adobe Flash Player. And in spite of that *.xpt file not being present in that particular folder. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Moderators Nergal 0 Posted September 3, 2010 Moderators Share Posted September 3, 2010 I installed the latest version (v2.35.1223) and I am puzzled. When I compare the embedded *.INI file info of v2.35.1219 with v2.35.1223 I don't see any changes but in spite of that the latest version does detect Adobe Flash Player. And in spite of that *.xpt file not being present in that particular folder. Are you magic? how are you comparing the embedded for .1223? it's not posted ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
Willy2 0 Posted September 3, 2010 Share Posted September 3, 2010 (edited) I use a program called Resourcehacker. (RH) Open in RS CC version v2.35.1223. Edited September 3, 2010 by Willy2 System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Jamin4u 0 Posted September 3, 2010 Author Share Posted September 3, 2010 What's the difference between the embedded .ini file and the winapp.ini file in the CCleaner folder? Online Documentation...CCleaner, Defraggler, Recuva and Speccy Link to post Share on other sites
Willy2 0 Posted September 3, 2010 Share Posted September 3, 2010 Resource hacker: http://www.angusj.com/resourcehacker/ System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to post Share on other sites
Winapp2.ini 0 Posted September 3, 2010 Share Posted September 3, 2010 the latest revision has [Adobe Flash Player] ID=2055 LangSecRef=3023 Detect=HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} DetectFile=%windir%\system32\Macromed\flash\flashplayer.xpt Default=True SpecialKey1=N_FLASH_COOKIES and the previous version had [Adobe Flash Player] ID=2055 LangSecRef=3023 Detect=HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} DetectFile=%windir%\system32\Macromed\flash\flashplayer.xpt Default=True SpecialKey1=N_FLASH_COOKIES Make of it what you will, they appear the same to me winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Winapp2.ini 0 Posted September 4, 2010 Share Posted September 4, 2010 What's the difference between the embedded .ini file and the winapp.ini file in the CCleaner folder? CCleaners INI's have been embedded into the exe for a while. Either you have a really old ini, or you've been downloading the embedded ones and putting them in the ccleaner folder. Deleting it does nothing, since its already inside the exe. winapp2.ini additions thread winapp2.ini github Link to post Share on other sites
Jamin4u 0 Posted September 4, 2010 Author Share Posted September 4, 2010 CCleaners INI's have been embedded into the exe for a while. Either you have a really old ini, or you've been downloading the embedded ones and putting them in the ccleaner folder. Deleting it does nothing, since its already inside the exe. I always update CCleaner by installing the new version over the old one. So the winapp.ini file in the CCleaner folder must be a leftover and useless. Just got back 39.0 KB of my HD. Thanks Online Documentation...CCleaner, Defraggler, Recuva and Speccy Link to post Share on other sites
Moderators Nergal 0 Posted September 4, 2010 Moderators Share Posted September 4, 2010 the latest revision has [Adobe Flash Player] ID=2055 LangSecRef=3023 Detect=HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} DetectFile=%windir%\system32\Macromed\flash\flashplayer.xpt Default=True SpecialKey1=N_FLASH_COOKIES and the previous version had [Adobe Flash Player] ID=2055 LangSecRef=3023 Detect=HKCR\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000} DetectFile=%windir%\system32\Macromed\flash\flashplayer.xpt Default=True SpecialKey1=N_FLASH_COOKIES Make of it what you will, they appear the same to me I think that the difference (maybe and this is only a guess) that detects have now become OR as opposed to AND by which I mean oldversion Detect=hkcr... and detectfile=%wirdir%... newversion Detect=hkcr... or detectfile=%windir%... ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. CCLEANER, RECUVA, DEFRAGGLER AND SPECCY DOCUMENTATION CAN BE FOUND AT https://support.piriform.com/hc/en-us and https://www.ccleaner.com/docs Pro users file a PRIORITY SUPPORT request at https://support.piriform.com/hc/en-us/requests/new link to WINAPP2.INI explanation Link to post Share on other sites
