CursedVampiricRose Posted August 20, 2010 Share Posted August 20, 2010 CCleaner Should have a feature for advanced computer users, made to add a program to the cleaning feature. Once the program is added, and the selected files that'd be cleaned have been identified, the user would click something like, "Save this selection, and send to the CCleaner database." For example, the 3-D Chatting Software, IMVU. Someone would select each cache folder, and select an option like, "Clear all files in this folder," or, "delete this/these file(s)," or, "restore these files to the previously backed up state." It'd be awesome, considering the fact that I found that IMVU can take over half a Gigabyte of space in the cache folders, if not cleared in awhile. Also, especially consdiering the fact that there are people out there that know where the log files and cache files are for certain programs. It'd make CCleaner the, "All in one," cleaning tool for many programs, making the process of freeing disk space a possible, "1-click," task, for most, to all programs that use a lot of disk space from it's cache. And for the people whom can manually add the programs' sake, before installing the newer version of CCleaner, Piriform should put an extra step in the installation, having in big bold text, "FOR ADVANCED USERS: CCLEANER NOW ALLOWS MANUAL ADDING OF PROGRAMS TO THE CLEANING FEATURE." The extra step should at least exist for a few months, so the people get the message for sure. Thanks for your time, and I hope this may help people in the future. ~Bloody?Black?Rose~ Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted August 20, 2010 Moderators Share Posted August 20, 2010 Do you mean like this? http://docs.piriform.com/ccleaner/using-ccleaner/including-files-and-folders-for-cleaning Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
Winapp2.ini Posted August 20, 2010 Share Posted August 20, 2010 On topic: I believe he may have been referring to winapp2.ini and/or the custom files. OFF TOPIC: Speaking of the IMVU cache, it can take much more than half a gigabyte. I frequently use it to talk to my friend who loathes AIM/IRC for some reason [~IMVU Cache]LangSecRef=3022DetectFile=%appdata%\IMVUClient\IMVUClient.exeDefault=FalseFileKey1=%appdata%\IMVU\cache\|*.*|REMOVESELF|FileKey2=%appdata%\IMVU\AssetCache\|*.*|REMOVESELF| FileKey3=%appdata%\IMVU\PixmapCache\|*.*|REMOVESELF|[~IMVU Logs]LangSecRef=3022DetectFile=%appdata%\IMVUClient\Imvuclient.exeDefault=FlaseFileKey1=%appdata%\IMVU\|*.logFileKey2=%appdata%\IMVU\|*.log.*[/Code] Of course, I actively monitor how large its growing so I never actually delete it, I've posted several times that they should allow for truncation of the cache winapp2.ini additions thread winapp2.ini github Link to comment Share on other sites More sharing options...
