banabaka Posted July 26, 2010 Share Posted July 26, 2010 hi.i want to try ccleaner's secure deleting. but before tryin, i got 100gb+ empty space.and after( C drive ); how to fix it? __ win7 ultimate x64 system restore off sorry for my bad english.please answer with easy english Link to comment Share on other sites More sharing options...
Willy2 Posted July 26, 2010 Share Posted July 26, 2010 Welcome to the forum. 1. Upgrade to CCleaner v2.34. 2. Don't use the Gutmann (35 passes) secure deletion. Overwriting data one time is good enough and it takes less time. 3. Download and run Treesize. It shows you where all that free space could have gone. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
banabaka Posted July 27, 2010 Author Share Posted July 27, 2010 wow thanks alot and what can i do now? Link to comment Share on other sites More sharing options...
Moderators Nergal Posted July 27, 2010 Moderators Share Posted July 27, 2010 empty your recycle bin. Also, from your description of the problem I'm going to jump to the conclusion that you ran wipe free space (in windows/advanced section of ccleaner.) If so: run it again and it'll delete the file you created that didn't finsh when it ran and then after that don't run wipe free space unless you are selling your drive ADVICE FOR USING CCleaner'S REGISTRY INTEGRITY SECTION DON'T JUST CLEAN EVERYTHING THAT'S CHECKED OFF. Do your Registry Cleaning in small bits (at the very least Check-mark by Check-mark) ALWAYS BACKUP THE ENTRY, YOU NEVER KNOW WHAT YOU'LL BREAK IF YOU DON'T. Support at https://support.ccleaner.com/s/?language=en_US Pro users file a PRIORITY SUPPORT via email support@ccleaner.com Link to comment Share on other sites More sharing options...
banabaka Posted July 27, 2010 Author Share Posted July 27, 2010 thanks to all solved Link to comment Share on other sites More sharing options...
