CCleaner Community Forums
currajong
DEFRAGGLER DOES NOT TOTALLY DEFRAG A DRIVE
I run the current version of Piriform Defraggler on a Win XP PC. I note that defraggling a drive often does leave quite a significant number of files/significant amounts of data fragmented.
If I then run MSoft Disk Defragmenter, the drive is then significantly further defragmented. WHY IS THIS?
Any help/advices appreciated.
Thanks to all in advance.
currajong
Share this post
Link to post
Which method of defragging are you using?
I use whole drive defrag with the option - move large files to end of drive during whole drive defrag.
Is this what you mean?
regards,
currajong
Share this post
Link to post
Yes, that's what I meant. I do not use "move large files to the end of disk" option, but using Defrag Drive defragment 100% all my drives. Do you have a lot of programs running in the background? Any programs that may be accessing the disk?
Share this post
Link to post
Thanks for help. I had problem with that.
___________
buy Klonopin
alcohol and klonopin
Share this post
Link to post
Share this post
Link to post
eL_PuSHeR,
Thank you for your input. I have switched off the Defraggler option regarding the relocation of large files.
I do have a number of programs running in the background, e.g., Personal Firewall, Anti Virus and Windows Security Essentials - these are first to come come to mind.
But I still wonder why Windows Defragmenter seems to be more thorough - or is it just my imagination?
Regards,
currajong
Share this post
Link to post
For me, Defraggler is more thorough when running in Full Defrag mode (not quick) but IT TAKES AGES to defragment any partition bigger than 30Gb.
Share this post
Link to post
Register a new account
Sign in
