big mac Posted May 24, 2010 Share Posted May 24, 2010 Hi, I have ran speccy in order to query the performance of a new Tier 1 lappy. Running VMware workstation seems slower than on my old machine so wanted to check out why. Had a look at the memory of the device, Core 2 4Gb (800mhz according to the book) and Speccy reports 533Mhz FSB ram running at 399Mhz. However, the manufacturer is insisting the memory is actually 800mhz and questions the Speccy software accuracy. They have tested another,faster machine with Speccy and suggest on a more advanced machine with a Core i3 and 4GB of memory at 1066Mhz Speccy is stating that it is a 533Mhz unit. i n Would appreciate some advice as the supplier have been great but I need to know if the s/w is accurate. Link to comment Share on other sites More sharing options...
jojotjuh Posted May 31, 2010 Share Posted May 31, 2010 I may be wrong, but speccy shows my 800mhz (ddr2 pc-6400) as 401mhz as well, so what I think is that because DDR2 has a double data rate, it might have something to do with that. Link to comment Share on other sites More sharing options...
cdebel2005 Posted December 27, 2010 Share Posted December 27, 2010 i'm using DDR3 1600mhz, and Speccy report me 802mhz. Maybe the programmers will do some fix about this problem someday. Link to comment Share on other sites More sharing options...
Guest MrRon Posted December 27, 2010 Share Posted December 27, 2010 Can you post some .speccy files so we can have a look at these in more detail? Link to comment Share on other sites More sharing options...
Pragmatic Parisite Posted December 31, 2010 Share Posted December 31, 2010 (edited) Hello~ I may have a similar problem but not really sure. I just purchased pc2-4200 (533) and speccy is reporting it as being pc2-6400 (800). Generated by Piriform Speccy v1.07.205 31 Dec 2010 @ 14:41Summary Operating System MS Windows Vista Home Premium 32-bit SP2 CPU Intel Core Duo T2250 @ 1.73GHz Yonah 65nm Technology Intel Core Duo T2250 Cores:2 Threads:2 Name:Intel Core Duo T2250 Code Name:Yonah Package:Socket 479 mPGA Technology:65nm Specification:Genuine Intel(R) CPU T2250 @ 1.73GHz Family:6 Extended Family:6 Model:E Extended Model:E Stepping:8 Revision:C0 Instructions:MMX, SSE, SSE2, SSE3 Bus Speed:133.0 MHz Rated Bus Speed:532.1 MHz Stock Core Speed:1733 MHz Stock Bus Speed:133 MHz Average Temperature:94 ?F Caches L1 Data Cache Size:2 x 32 KBytes L1 Instructions Cache Size:2 x 32 KBytes L2 Unified Cache Size:2048 KBytes Core 0 Core Speed:1729.0MHz Multiplier: x 13.0 Bus Speed:133.0 MHz Rated Bus Speed:532.1 MHz Temperature:94 ?F Thread 1 APIC ID: 0 Core 1 Core Speed:1729.0 MHz Multiplier: x 13.0 Bus Speed:133.0 MHz Rated Bus Speed:532.1 MHz Temperature:94 ?F Thread 1 APIC ID: 1 RAM 3.0GB Dual-Channel DDR2 @ 266 MHz (4-4-4-12) RAM Memory slots Total memory slots:2 Used memory slots:2 Free memory slots:0 Memory Type:DDR2 Size:3072 MBytes Channels #:Dual DRAM Frequency:266.1 MHz CAS# Latency (CL):4 clocks RAS# to CAS# Delay (tRCD):4 clocks RAS# Precharge (tRP):4 clocks Cycle Time (tRAS):12 clocks Bank Cycle Time (tRC):16 clocks SPD Number Of SPD Modules:2 Slot #1 Type:DDR2 Size:2048 MBytes Manufacturer:ElpidaMax Bandwidth:PC2-6400(400 MHz) Part Number:EBE21UE8AFSA-8G-F Serial Number:5AF61A02 Week/year: 10 / 10 SPD Ext.:EPP JEDEC #3 Frequency:400.0 MHz CAS# Latency:6.0 RAS# To CAS#:6 RAS# Precharge:6 tRAS:18 tRC:24 Voltage:1.800V JEDEC #2 Frequency:333.3 MHz CAS# Latency:5.0 RAS# To CAS#:6 RAS# Precharge:6 tRAS:16 tRC:21 Voltage:1.800V JEDEC #1 Frequency:266.7 MHz CAS# Latency:4.0 RAS# To CAS#:4 RAS# Precharge:4 tRAS:12 tRC:16 Voltage:1.800V Slot #2 Type:DDR2 Size:1024 MBytes Manufacturer:Samsung Max Bandwidth:PC2-4300(266 MHz) Part Number:M4 70T2953CZ3-CD5 Serial Number:F5232680 Week/year: 21 / 06 SPD Ext.:EPP JEDEC #3 Frequency:266.7 MHz CAS# Latency:5.0 RAS# To CAS#:4 RAS# Precharge:4 tRAS:11 tRC:15 Voltage:1.800V JEDEC #2 Frequency:266.7 MHz CAS# Latency:4.0 RAS# To CAS#:4 RAS# Precharge:4 tRAS:11 tRC:15 Voltage:1.800V JEDEC #1 Frequency:200.0 MHz CAS# Latency:3.0 RAS# To CAS#:3 RAS# Precharge:3 tRAS:8 tRC:11 Voltage:1.800V Still, I think in slot#2 speccy reported it as pc2-4300 when I believe the sticker on the ram chip read pc2-4200. The pc2-6400 reported by speccy may or may not be pc2-6400. I just bought this and maybe they tagged it wrong@pc2-4200 at the factory. PP Edited January 3, 2011 by Nergal code tags added for easier reading Link to comment Share on other sites More sharing options...
dissss Posted January 6, 2011 Share Posted January 6, 2011 i'm using DDR3 1600mhz, and Speccy report me 802mhz. Maybe the programmers will do some fix about this problem someday. This isn't a problem at all - read how DDR memory works here: http://en.wikipedia.org/wiki/DDR2_SDRAM Link to comment Share on other sites More sharing options...
Robbie 1939 Posted January 12, 2011 Share Posted January 12, 2011 Hello, CPU Temp is not being displayed and RAM speed is showing 400 Mhz although I'm using 800 Mhz sti9cks. See attached clip. Thanks for this great tool I'm counting on it for up to date system info. Link to comment Share on other sites More sharing options...
Pragmatic Parisite Posted January 13, 2011 Share Posted January 13, 2011 Speccy reports 800 on a dual channel 1600 and 400 on a dual channel 800. Thats because there is 400 to each channel for 800mghz, and aprox. 800 per channnel for 1600mghz. That particular specification is per channel. Read the link above to see how Double data rate works. Link to comment Share on other sites More sharing options...
Arska Posted December 20, 2017 Share Posted December 20, 2017 I have DDR3 1600mhz 8gb (4gb HyperX Blu and 4gb Corsair? Valueram) Speccy shows 439mhz Link to comment Share on other sites More sharing options...
Moderators mta Posted December 20, 2017 Moderators Share Posted December 20, 2017 and if you try Speccy with just one of those chips at a time, does it show 800MHz each time? Backup now & backup often.It's your digital life - protect it with a backup.Three things are certain; Birth, Death and loss of data. You control the last. Link to comment Share on other sites More sharing options...
