Olav the Viking Posted April 30, 2010 Share Posted April 30, 2010 Speccy shows the WiFi as "WiFi not enabled" Speccy: 1.01.132 PC: Dell Latitude D830 CPU: Intel Mobile Core 2 Duo T7100 Network You are connected to the internet Connected through Intel® Wireless WiFi Link 4965AGN - Kaspersky Anti-Virus NDIS Miniport IP Address 192.168.145.26 Adapter Type Ethernet WinInet Info LAN Connection Local system uses a local area network to connect to the Internet Local system has RAS to connect to the Internet Wi-Fi Info Wi-Fi not enabled WinHTTPInfo WinHTTPSessionProxyType No proxy Session Proxy Session Proxy Bypass Connect Retries 5 Connect Timeout 60000 HTTP Version HTTP 1.1 Max Connects Per 1.0 Servers INFINITE Max Connects Per Servers INFINITE Max HTTP automatic redirects 10 Max HTTP status continue 10 Send Timeout 30000 IEProxy Auto Detect No IEProxy Auto Config IEProxy IEProxy Bypass Default Proxy Config Access Type No proxy Default Config Proxy Default Config Proxy Bypass Obviously the WiFi IS enabled, since I was able to post this and I do not have a LAN cable plugged in. I ran Speccy on my big desktop last night, which does have WiFi, and it showed this status: Network You are connected to the internet Connected through NETGEAR WN311T Wireless PCI Adapter - Kaspersky Anti-Virus NDIS Miniport IP Address 192.168.xxx.2 Adapter Type Ethernet WinInet Info LAN Connection Local system has a valid connection to the Internet, but it might or might not be currently connected Local system uses a local area network to connect to the Internet Local system has RAS to connect to the Internet Wi-Fi Info Using native Wi-Fi API version 1 Available access points count 1 Wi-Fi () SSID Name Signal Strength/Quality 78 Security Enabled State The interface is connected to a network Dot11 Type Infrastructure BSS network Network Connectible Network Flags There is a profile for this network Cipher Algorithm to be used when joining this network AES-CCMP algorithm Default Auth used to join this network for the first time 802.11i RSNA algorithm that uses PSK Silverstone SST-TJ06-B Case, Corsair HX750 P/S, XP Pro SP3, KIS2016Intel D925XECV2 MB w P4 560J (3.6Ghz), 4GB Crucial DDR2 PC2-5300 Ram3 x 750 MB HDs, Teac FD-235HF Floppy, 2 Plextor PX-716SA DVD's (SATA)ATI Radeon X1800XT (512Mb 256-bit GDDR3), 2 Dell 2405FPW 24" 1920x1200 LCDs2 Dell AS500 14W Soundbars, configured to give L, C & R Audio ChannelsAdaptec AHA-2930CU PCI Ultra SCSI Ctrlr, HP4C SCSI Scanner (NOT Chinese) Link to comment Share on other sites More sharing options...
