Ultra Slow
Woodrow
After installing CCleaner, my Vista started having problems. Programs will not open or open extremely slowly-sometimes as much as a half hour and then don't work properly. I am not an expert, so possibly I didn't install the program properly or chose improper options during setup.
Please Help
Link to comment
Hi Woodrow, welcome.
Where did you download CC from?
Here? http://filehippo.com/download_ccleaner/
or Here? http://www.piriform.com/ccleaner/
These are CC's authentic download sites. If you downloaded from somewhere else, and your system is not performing normally, you may have a rogue imitation.
A genuine copy of CC does not drastically reduce system performance after installation.
Link to comment
Try system restore like what is on my signature.
I love computer maintenance tasks.
Some of my favorite programs:
Wordpad -basic word processing
Notepad - temporary clipboard and basic scripting module
Windows Media Player 12- video, music and online radio player
Windows Media Center - live TV, local FM radio
CCleaner- handy computer maintenance tool
If something fails to work after using the registry cleaner, use SYSTEM RESTORE.
Link to comment
Please Help
Woodrow have you actually run CCleaner yet or just installed it?
If you haven't run it yet then as kroozer says there's nothing in the CCleaner installation that should cause a problem.
If you have run it what options did you select? Did you do a registry clean and if so did you back up the entries
when prompted?
Link to comment
  • Moderators
and if you only ran the cleaner (not the reg section) did you have "old prefetchdata" checked?
Link to comment
Register a new account
Sign in
Important Information
