scriptdaemon Posted March 30, 2010 Share Posted March 30, 2010 Speccy seems to work fine in 2000 and XP without admin (minus some features), but it doesn't even load in Vista and 7 without admin. Is this a bug with Speccy, or can Speccy not run without admin on Vista and 7? Link to comment Share on other sites More sharing options...
Lucky10 Posted April 1, 2010 Share Posted April 1, 2010 Speccy seems to work fine in 2000 and XP without admin (minus some features), but it doesn't even load in Vista and 7 without admin. Is this a bug with Speccy, or can Speccy not run without admin on Vista and 7? Are you talking about installing or running? I have WinXP and Vista and they both work at they should do but if I take the exe to work you get the admin message and it shows all values apart from the later version which says Graphics - Access is denied, but the earlier version showed info there. WinXP SP3 and Vista Home Premium SP2 Link to comment Share on other sites More sharing options...
scriptdaemon Posted April 6, 2010 Author Share Posted April 6, 2010 Are you talking about installing or running? I have WinXP and Vista and they both work at they should do but if I take the exe to work you get the admin message and it shows all values apart from the later version which says Graphics - Access is denied, but the earlier version showed info there. Running. On Vista and 7, Speccy doesn't load at all without admin rights. It does load without admin rights in XP (and I think 2000), however. I'm wondering if this is intentional, or if it could be fixed. Link to comment Share on other sites More sharing options...
Lucky10 Posted April 8, 2010 Share Posted April 8, 2010 It does load without admin rights in XP (and I think 2000), however. No it doesn't properly. I've taken it to work and it shows an admin messagebox on startup then you get Access denied on the Graphics. WinXP SP3 and Vista Home Premium SP2 Link to comment Share on other sites More sharing options...
scriptdaemon Posted April 8, 2010 Author Share Posted April 8, 2010 No it doesn't properly. I've taken it to work and it shows an admin messagebox on startup then you get Access denied on the Graphics. Yes, it does. I'm not arguing what features work and what don't, I'm saying (for the third time now) that it *runs* without admin on XP and 2000, but doesn't run *at all* without admin on Vista and 7. Link to comment Share on other sites More sharing options...
Lucky10 Posted April 8, 2010 Share Posted April 8, 2010 I'm saying (for the third time now) that it *runs* without admin on XP and 2000, Yes and I'm saying it doesn't run properly without admin rights. WinXP SP3 and Vista Home Premium SP2 Link to comment Share on other sites More sharing options...
scriptdaemon Posted April 8, 2010 Author Share Posted April 8, 2010 Yes and I'm saying it doesn't run properly without admin rights. Which is irrelevant to this thread. Link to comment Share on other sites More sharing options...
Lucky10 Posted April 8, 2010 Share Posted April 8, 2010 Which is irrelevant to this thread. Maybe so in your case but I was just commenting on your first post that all. WinXP SP3 and Vista Home Premium SP2 Link to comment Share on other sites More sharing options...
