Willy2 Posted June 9, 2010 Share Posted June 9, 2010 MRG7, If CC wipes too much settings in other programs/applications as well, there's a place where you can always find the latest embedded *.ini files. http://forum.pirifor...showtopic=15307 With that info you can write/modify your own customized winapp2.ini and/or winapp1.ini file(s). This thread is also always available on the frontpage of the ""CC discussion"" forum. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
MRG7 Posted June 9, 2010 Author Share Posted June 9, 2010 I?ve not noticed any other settings being affected, but I will keep that in mind ? now I know how to do it ! Thank you Willy2. One question though; now I have deleted the PowerPoint RegKey, will that stop CCleaner cleaning any junk files relating to that application? If so, is there any way I can modify it to include PowerPoint, while still avoiding the previous problem? Link to comment Share on other sites More sharing options...
Willy2 Posted June 9, 2010 Share Posted June 9, 2010 If you know where PP and Outlook related info (settings/filenames) is ""hiding"" then you certainly could modify/add more ""Regkey=......"" and/or ""Filekey=...."" lines to specificly target PP and/or Outlook related info. But then you'll have to use a registry editor and search the registry but that's something for more advanced Windows users only. Another suggestion: You don't have to delete that key, I was told today that placing a ";" in front of a line makes CC ignore that line. System setup: http://speccy.piriform.com/results/gcNzIPEjEb0B2khOOBVCHPc A discussion always stimulates the braincells !!! Link to comment Share on other sites More sharing options...
MRG7 Posted June 9, 2010 Author Share Posted June 9, 2010 Thank you, but I don?t think I?ll attempt to edit the registry ! That?s interesting about using a ?;? but would this have any advantages for me? Link to comment Share on other sites More sharing options...
