joanie707 Posted February 23, 2010 Share Posted February 23, 2010 Hi, I really want to remove IE8, I am happy to get back to IE7 and I know if you remove 8 it is suppose to revert to 7 however I have tried the easy way to go through remove programs , but it is not listed there. I also went to the MS page and put a search in for the uninstall file (I am sorry I lost the name) that they suggest I use, this also turned up nothing.. Is there a way to completely remove it, and reinstall IE7? Or even if you can give me some pointers on how to get 8 off I will try that. But IE8 has always given me a lot of problems and when I get to a point where I am ready to blow I use Firefox. However I really feel I need IE7 on my computer and workable. Some info on my computer---HP pavilion dv 6700 Notebook PC ---AMD Turion 64 X2 2 GHz 32 bit vista---3 GB Ram--I have SP2 installed---Hard disk is 174 GB with 96 GB free If I can just get the internet explorer reverted or reinstalled I will be most happy Thanks for any help you all can give me Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted February 23, 2010 Moderators Share Posted February 23, 2010 Have you had a good read through here Joanie? Is this the site you went to? Edit.. forgot link!! http://support.microsoft.com/kb/957700#fixit4me Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
marmite Posted February 23, 2010 Share Posted February 23, 2010 This article suggests it's fairly straightforward to remove it from Vista ... http://www.tech-recipes.com/rx/2817/how_to_uninstall_ie8/ Link to comment Share on other sites More sharing options...
