chrissy99 Posted January 29, 2010 Share Posted January 29, 2010 Greetings, How can I 'point' CC cleaner to my usb drive to clean it? Many thanks, chrissy99 Link to comment Share on other sites More sharing options...
kroozer Posted January 29, 2010 Share Posted January 29, 2010 It doesn't. Link to comment Share on other sites More sharing options...
JDPower Posted January 30, 2010 Share Posted January 30, 2010 Greetings,How can I 'point' CC cleaner to my usb drive to clean it? Many thanks, chrissy99 What is on your usb that could be cleaned? Link to comment Share on other sites More sharing options...
Ishi Posted January 30, 2010 Share Posted January 30, 2010 Well CCleaner can't clean your USB. Usually the computer doesn't automatically put junk files in your USB unless it was you who put some crappy files in it in the first place. But it is possible to install CCleaner Portable on a USB flash drive that you can then carry and use in different computers without having to install CCleaner in the hard disks of those computers. CCleaner Portable along with other CCleaner builds can be downloaded for free in this link. http://www.piriform.com/ccleaner/builds I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
Alan_B Posted January 30, 2010 Share Posted January 30, 2010 I disagree. 1. You can run portable Applications on a USB drive, and through no fault of your own they may create junk files you want to purge. 2. Ccleaner IS ABLE to clean a USB drive, even a Flash drive. You can stipulate all the Folders and Files that you wish to Include for deletion. BUT it may be reluctant to use its built in knowledge to FIND those junk files, other than in accordance with your specific directions of what to Include. 3. I suspect Ccleaner can also find for itself and then delete all the normal Windows junk files on a USB drive if you have booted into Windows on that USB drive and that USB drive is therefore your system partition. In practice however it may normally be simpler to put on the USB drive a simple Batch script to purge all the junk you anticipate when using the USB drive, and to run that script when you have finished using the drive. Regards Alan Link to comment Share on other sites More sharing options...
Ishi Posted January 30, 2010 Share Posted January 30, 2010 I don't think it is possible to install your operating system in your USB flash drive. USBs use fast flash memories and by default, formatted as FAT or FAT32, not the standard NTFS on internal hard drives where you install the operating systems and besides, many USBs have far smaller capacities that hard disks and, lets say those only 1,2,4 and 8 GB in size. CCleaner does have an option to clear certain files and folders in the computer. Just open CCleaner, go to Options, click the Include button and from there you can see the Add Folder and Add Files buttons. Clicking the Add Folder button lets you browse in whatever location in the computer that you want CCleaner to clean and that includes USBs and even the folders inside those USBs. The trick is, if you add a folder on the USB in the include list, how would you suppose that CCleaner will know which files are safe to delete inside those folders???? It might end up deleting important files in your USB. Well if you want a program that can supposedly search for junk files on the USB, there is a free program called Advanced System Care 3. Its not really fast. It has this disk cleaner tool for all drives and you can use it to search for junk on the USB only but for multiple times, I tried to scan my USB with that disk cleaner tool, no junk files were ever detected. If the USB is small in size, especially if it doesn't have many folders and subfolders, its not hard navigating inside it and locating which files are no longer needed. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
Alan_B Posted January 31, 2010 Share Posted January 31, 2010 I don't think it is possible to install your operating system in your USB flash drive. The trick is, if you add a folder on the USB in the include list, how would you suppose that CCleaner will know which files are safe to delete inside those folders???? It might end up deleting important files in your USB. Hi I was slightly ahead of you there ! ! My point 3 specifically refrained from referring to booting from a FLASH drive. I had in mind my 320 GB USB2 connected HARD drive with both FAT32 and NTFS partitions. And when I said "BUT it may be reluctant to use its built in knowledge to FIND those junk files," I really meant "There is no way that Ccleaner could distinguish between junk and vital files on Flash drive" but that would suggest I had more knowledge than the developers of Ccleaner, and therefore knew their limitations. If I include C:\Windows\System32\*.* for cleaning, it is POSSIBLE that Ccleaner would refrain from purging all the *.EXE files, BUT I assume that Ccleaner is more likely to obey orders ! ! Regards Alan Link to comment Share on other sites More sharing options...
Ishi Posted January 31, 2010 Share Posted January 31, 2010 Wow, 320 GB, that's a different issue. Why don't you try the app, I suggested you then??? When you open its disk cleaner tool, it auto-detects all drives plugged in your system and that includes USBs and external hard drives. It searches for junk in all those external drives. I love computer maintenance tasks. Some of my favorite programs: Wordpad -basic word processing Notepad - temporary clipboard and basic scripting module Windows Media Player 12- video, music and online radio player Windows Media Center - live TV, local FM radio CCleaner- handy computer maintenance tool If something fails to work after using the registry cleaner, use SYSTEM RESTORE. Link to comment Share on other sites More sharing options...
chrissy99 Posted February 1, 2010 Author Share Posted February 1, 2010 Thanks to all for your responses. This was my first post, and I'm always willing to learn. Will try adding to the include set as well as the suggested SW. Let's consider this thread closed. Thanks, Chrissy99 Link to comment Share on other sites More sharing options...
