How not to delete user names and passwords
subdiver
Ignore CCleaner for a minute, if you enter a user and password in IE, the close IE, reopen IE and go back to that site does it remember your credentials?
If not then IE is fundamentally where the problem lies. Have a look at this article ... http://pubs.logicalexpressions.com/Pub0009...icle.asp?ID=348
I must admit, even though all of my registry entries and IE Options appear to be set correctly, I can't get saved form passwords to work. I don't use it normally and originally answered 'no' to saving passwords - but now in investigating this thread it doesn't seem to want to turn back on.
If I use another clean user it's fine, so it would appear that something is not being properly reset in my normal user. There are loads of articles on google about people having similar problems.
Link to comment
  • Moderators
I should never update any programms, bevore I had no problems with CCleaner at all <_<
What did you change with the update? It must have to do something with that damn update.
Apologies if you've already said this, but it's a long thread. Are you saying that a previous version worked for you, but now won't because the new version has changed something?
If that's the case, try completely removing CCleaner and do a fresh, clean install. So as not to lose your settings, check the "Save all settings to INI file" box in "Options\Advanced".
Go into the CCleaner folder, "C:\Program Files\CCleaner", and copy the INI file to a safe location. When you reinstall CCleaner, copy the INI file back to the CCleaner folder.
This might enable the older version to work for you again.
Link to comment
If I log in and close out a site and go back later that day it DOES remember name and password. The deletion comes from when I run CCleaner v 2.29.1111 and even previous versions.
I use CCleaner maybe once a week along with IE8 deleting browser history just before I do my weekly back-up.
I can live with it but it is rather annoying to re-enter name and password to my favorite five tech forums.
Link to comment
Born have you tryed unticking every Browser checkbox??? Including non supported browsers. Might sound a strange thing un checking un associated chks but might help narrow it down
1: log in sites
2: close browser
3: reopen browser checking still logged in
4: close browser
5: uncheck all browser chks
6: run ccleaner
7: check login
8: report back
No fate but what we make
Link to comment
1: log in sites
2: close browser
4: close browser
6: run ccleaner
7: check login
8: report back
Where do you #5 uncheck all browser checks?
Link to comment
Isn't it 'Autocomplete form history'?
You can also configure IE's behaviour via Internet Options / Content / Settings.
Found the solution:
Go into CCleaner/options/cookies/and there is where you highlight the ones you want to save and add it to the cookies to keep in the right column. I know this works as I have tested it.
Link to comment
  • 2 weeks later...
Can older versions of the program be downloaded and if so where do I get them?
I was running ver 2.29.111 with IE8 and have the same problems reported with version 2.28.
Link to comment
  • 8 years later...
  • Moderators
Threadcomancy is a lost art.  This is an old thread, if you're trying to aid them; if you are, instead, trying to ask something, please start a new thread and provide much more information.
1 hour ago, ederangelo said:
it is way
remove delete cooks
Link to comment
  • Nergal locked this topic
Guest
This topic is now closed to further replies.
Important Information
