klumy Posted July 30, 2009 Share Posted July 30, 2009 Hello, there should be an option to shutdown the pc after cleaning CCleaner (newest version)Windows 10 Link to comment Share on other sites More sharing options...
Moderators DennisD Posted July 30, 2009 Moderators Share Posted July 30, 2009 Already a well used and popular feature. Full instructions here: http://forum.piriform.com/index.php?showtopic=16551 Link to comment Share on other sites More sharing options...
Keithuk Posted July 30, 2009 Share Posted July 30, 2009 there should be an option to shutdown the pc after cleaning There is, look in Options\Advanced there is a checkbox that says Close program after cleaning. Keith Windows XP 2002 SP3 IE 7.0 Martin2k Rorshach112 is the best Link to comment Share on other sites More sharing options...
mr don Posted July 31, 2009 Share Posted July 31, 2009 There is, look in Options\Advanced there is a checkbox that says Close program after cleaning. Why would you need this feature, anyway? CCleaner only takes seconds to run on my computer. What is say, 5 seconds or less? Can't wait for 5 seconds? Gee, isn't that impatient? Link to comment Share on other sites More sharing options...
mr don Posted July 31, 2009 Share Posted July 31, 2009 There is, look in Options\Advanced there is a checkbox that says Close program after cleaning. I think he means shut down the pc, not the program. Link to comment Share on other sites More sharing options...
Keithuk Posted July 31, 2009 Share Posted July 31, 2009 I think he means shut down the pc, not the program. Well I can make him a program that does that if he wants. Keith Windows XP 2002 SP3 IE 7.0 Martin2k Rorshach112 is the best Link to comment Share on other sites More sharing options...
