help!
TheFiresInTheSky
hey, i got an xp and i got a few questions.....is there a certain folder in system32 ect... that opens the cd drive? i wanted to make a shortcut and have that point to that folder so i could open, close, or send it 2 someone else. thanx B)
Link to comment
Download Tray Commander lite FREE(253Kb)
http://www.ardamax.com/info_tcl.html
EDIT: SORRY This info for full paid version 2.2
the EDIT because I couldn't find any info in this page that say this is a trial version and for howlong. the info is at the bottom of the left panel (i.e the homepage)
http://www.ardamax.com/help/open_cdrom.html
Tray Commander is a small shell extension that lets you gain access to most frequently used system commands and applications via a customizable menu. The menu in its turn pops up as you click on the program icon in the system tray. You can add your own commands to the menu, specify other options and then only access the commands you need most with a single click.
Supported commands:
Load application
Open folder
Open Special folder
Open Control Panel item
Open file
Open URL
Write letter
Launch screensaver
Make screenshot
Reboot computer
Shutdown computer
Shutdown monitor
Open/close CD drive
Paste text
Set video mode
Separator
Command series
Submenu
Other commands
Link to comment
Supported commands:
Load application
Open folder
Open Special folder
Open file
Open URL
Write letter
Launch screensaver
Make screenshot
Reboot computer
Shutdown computer
Shutdown monitor
Open/close CD drive
Paste text
Set video mode
Separator
Command series
Submenu
Other commands
ok.....i wanted something i could send to my friend over aim or e-mail and he clicks that link. i dont want a program. i want something that would work on his computer to.
Link to comment
HUH? Are you trying to exchange files with your friend? If so, what does the cd drive have to do with it? Looks like you need to link with your friend. If you need a shortcut to your cd drive: start>my computer>right click your drive and select "create shortcut". That will give you a desktop shortcut. From there you can add files to a cd, or create files from a cd that is not write protected. If you can tell us what you want to send or receive it would help a lot.
If it isn't broke, tweak it.
Link to comment
  • Moderators
From what I understand he only wants a shortcut when clicked will open or close the CD drive. The only problem is I've never known of such a way of doing that without the usage of software, I'm thinking it would also mean an ASPI driver/layer would have to be pre-installed. I don't know if it could be done with a JavaScript file (.js) or Visual Basic file (.vbs).
Link to comment
Guest Mangix
ummmm. a .vbs is a VBScript file not a VB file.
and it is possible if there is a COM object that can let you open/close a CD Drive
Link to comment
yea.....i just wanted a link to open my cd drive. (i no nothing with vbs, java script, ect...) i wanted to make it so i could send just that link to my friend and he would click it...it would open up cd drive
what about using command prompt?
Link to comment
Years ago, there was a e-mail prank going around that had an attachment. When you opened the attachment, you got a window that said you would get a free beverage holder and had a "OK" button. When you clicked the OK button, your CD tray would open. A rumor got started that it had a trojan hidden in it and people stopped sending it. You can download it here and scan the crap outta it just to be sure it's clean. Cokegift.exe
http://www.angelfire.com/mn/coolcrapcentral/programs.html
Link to comment
i tried it but angelfire wouldnt allow me to download it
Link to comment
still wanna no bout that folder
Link to comment
i want something hes not gonna c. so he wont no it was from the coke thing. and i didnt want him 2 hav 2 click on anything. look on second page
Link to comment
so basically a virus were he gets an email from you and his drive opens? as for simple, djlizard's works good, and its crazy small.
so ur sayin w/ this program he's not gonna even c it? wats the link to this program?
Link to comment
i guess what i should be asking is whats a good website to learan computer code? because i wanted to also do stuff like make a file that turns off my computer. it would be fine if i could just write it in notepad and save it. then whenever i wanted to turn it off i just double-click it.
Link to comment
Register a new account
Sign in
Important Information
