Vanguard382 Posted August 18, 2005 Share Posted August 18, 2005 For some strang reason now when ever i try uninstalling stuff it says uit uninstals it but it leaves a bunch of s**t in my programs folder. if i try deleting it it say "make sure your disk is not full or write-protected and the file is not curently in use" and i cheeck every thing and i should be able to delete it. Later i tried using the program "Eraser" and it says every time i try to ersae it that "error: reached the end of the file." and it leaves the file there. This is getting really annoying so i need some help as soon as possible. Thank Link to comment Share on other sites More sharing options...
berdy Posted August 18, 2005 Share Posted August 18, 2005 1-check for possible spyware 2-delete the file(s) in safemode 3-if certain process is locking the file(s) try http://ccollomb.free.fr/unlocker/ Link to comment Share on other sites More sharing options...
Moderators rridgely Posted August 18, 2005 Moderators Share Posted August 18, 2005 What are you uninstalling? Link to comment Share on other sites More sharing options...
Vanguard382 Posted August 18, 2005 Author Share Posted August 18, 2005 it's ok now i was able to get ride of them wit bergy help. Thanks anyway Link to comment Share on other sites More sharing options...
