CCleaner Community Forums
mr don
CCleaner System Restore function
The ability to delete restore points is nice. Very nice.
What about the options to:
- Increase or decrease restore point creation frequency (- or + hours, min, seconds)
- Enable or disable restore on different drives
- Create a new restore point
- Select multiple restore points to delete at a time (What happens when someone has gigs of restore points?)
- Set the amount of allowed diskspace for system restore to use
I believe that these would really be beneficial to CCleaner users.
Share this post
Link to post
I attached 2 files that should help with that. Extract to CCleaner folder
winsys2.zip
winsys2.zip
Share this post
Link to post
Awesome! Just one problem?
I extracted both files to the ccleaner folder, but when I went to sys restore control in ccleaner, I didn't see any new right click or other options. Is it hidden, or did I miss something?
Share this post
Link to post
I see you've never used winapp2.ini or winsys2.ini. That's ok though. Start CCleaner and go to cleaner->Windows Tab-> System -> System restore point. Right click and click clean to create a restore point. Or just check it and click Run Cleaner
Share this post
Link to post
What about an option to start system restore (and restore the selected restore point) from CCleaner?
Share this post
Link to post
I guess it would help if I had system restore enabled first, huh?
I forgot I had turned it off earlier!
Thanks!
Share this post
Link to post
Yep that would probably help!
Share this post
Link to post
Actually, just now enabled Sys Restore on my XP Pro with SP2 & it failed to show any right click option in CCleaner that you can make a new sys restore point. It DID show the new sys checkpoint it created upon enabling.
I verified both files were directly in the CCleaner folder before launching.
Share this post
Link to post
I'll check it out
EDIT:Post a picture
Share this post
Link to post
Register a new account
Sign in
