Tom AZ Posted April 23, 2009 Share Posted April 23, 2009 I've just started having trouble minimizing Firefox 2.0.0.20. Maybe it's always been that way, but if so, I don't remember it. I click on the "minimize" button and the screen quickly blinks, but then it remains "full-screen." If I keep horsing around with it and clicking the buttons long enough, I MAY finally get it to minimize, but not very often. Any thoughts as to what might be causing this? I don't seem to have a problem minimizing anything else. Link to comment Share on other sites More sharing options...
Robbie Posted April 23, 2009 Share Posted April 23, 2009 I have the same version of Firefox and can get it to minimise. Have you tried a re-install? Link to comment Share on other sites More sharing options...
Woody Posted April 23, 2009 Share Posted April 23, 2009 Get the latest version and have done with it. http://www.mozilla.com/en-US/ It is never difficult to distinguish between a Scotsman with a grievance and a ray of sunshine. P. G. Wodehouse Link to comment Share on other sites More sharing options...
Robbie Posted April 23, 2009 Share Posted April 23, 2009 Get the latest version and have done with it. http://www.mozilla.com/en-US/ There are many users of Firefox 2 who refuse to upgrade to Firefox 3 because of the integration of bookmarks and history, both of which are now stored in the places.sqlite file. As a result some users feel that this compromises privacy. With Firefox 2 the History file can be very easily securely deleted. I use the On-Demand feature of Eraser to securely delete a series of files and folders on Firefox 2 which include the History file. It's quick and easy to securely delete. I can't delete the places.sqlite file in Firefox 3 as I'd be wiping my bookmarks too. If it wasn't for this integration of History with Bookmarks, which I don't like, I would happily upgrade to Firefox 3. Link to comment Share on other sites More sharing options...
Tom AZ Posted April 24, 2009 Author Share Posted April 24, 2009 I've tried Firefox 3, but didn't like it. IMO FF2 seems much cleaner -- much tighter -- just a better written app overall. Link to comment Share on other sites More sharing options...
Moderators Andavari Posted April 24, 2009 Moderators Share Posted April 24, 2009 I'm not in love with FF3 either, however my reason for upgrading was because of security updates which for you FF2 users won't ever get fixed. Link to comment Share on other sites More sharing options...
Tom AZ Posted April 24, 2009 Author Share Posted April 24, 2009 I'm not in love with FF3 either, however my reason for upgrading was because of security updates which for you FF2 users won't ever get fixed. I understand what you're saying about security, but I'm not overly concerned because I run FF2 under Sandboxie (in addition to a firewall and A/V) Link to comment Share on other sites More sharing options...
Moderators DennisD Posted April 24, 2009 Moderators Share Posted April 24, 2009 If you still have your minimize problem Tom, have you tried right clicking the shortcut and select "properties" and then select "run maximized" from the drop down menu. Might not make a difference, but worth a shot. Link to comment Share on other sites More sharing options...
Tom AZ Posted April 25, 2009 Author Share Posted April 25, 2009 If you still have your minimize problem Tom, have you tried right clicking the shortcut and select "properties" and then select "run maximized" from the drop down menu. Might not make a difference, but worth a shot. Gave it a try, Dennis, but it didn't fix the problem. However, as I mentioned, it is somewhat of a sporadic issue. I also have a workaround -- so I guess it's not a big deal. The biggest frustration now is just trying to figure out what happened to cause it. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted April 25, 2009 Moderators Share Posted April 25, 2009 The biggest frustration now is just trying to figure out what happened to cause it. That's a direct route to grey hair and ulcers Tom, if you're not there already. Some things you just can't figure. I had a similar problem with Defraggler some time ago. I minimised it, and when I clicked it to restore, it maximized. I couldn't find anyway to get it back to the original size. Minimized or Maximized was all I had, so I reinstalled and it was fine. Maybe that's your solution. Link to comment Share on other sites More sharing options...
Tom AZ Posted April 25, 2009 Author Share Posted April 25, 2009 That's a direct route to grey hair and ulcers Tom, if you're not there already. Some things you just can't figure. I had a similar problem with Defraggler some time ago. I minimised it, and when I clicked it to restore, it maximized. I couldn't find anyway to get it back to the original size. Minimized or Maximized was all I had, so I reinstalled and it was fine. Maybe that's your solution. Actually, I did reinstall, Dennis, but that didn't fix it either. I didn't uninstall first, just went over the top. Maybe an uninstall/clean install would help, but not sure it's worth worrying about all my bookmarks, extensions, etc. Link to comment Share on other sites More sharing options...
Icedrake Posted April 26, 2009 Share Posted April 26, 2009 Back up your extensions, bookmarks etc. with FEBE (version for FF 2). Here's the link: https://addons.mozilla.org/en-US/firefox/ad...9#version-5.3.1 5.3.1 is the latest version that works for FF2. Any other versions past that, versions 6+ are only for FF3. Link to comment Share on other sites More sharing options...
