michika Posted March 15, 2009 Share Posted March 15, 2009 Hello, have to repair a notebook from a friend. He cleaned with ccleaner and after the reboot, win began to compile all files on the hd with a remark for error in security settings, can tell u more cause I haven't seen it by myself. After this win starts and all looks good but now you couldn't drag and drop most software doesn't work including windows help many progs from system control like system reconstruction. Then I tried to start win xp sp3 update but it was impossible, says (translated) Update.inf couldn't be verified. Be shure that the crypthography service is running. Never had this in xp before any help appreciated, thanks for yer precious time (and sorry for bad english)! michika Link to comment Share on other sites More sharing options...
Robbie Posted March 15, 2009 Share Posted March 15, 2009 I hope this is of some help. http://support.microsoft.com/kb/822798 One of the errors covered in that Help and Support article is when the following error is reported: "When you try to install an update or to install a service pack, you may receive an error message that is similar to one of the following: (Name of Update Package) Setup could not verify the integrity of the file Update.inf. Make sure the Cryptographic service is running on this computer." Further down in the article are a series of possible solutions. Edit: Having read your post again, I just realised that the above error relates to the failure of the laptop to install Win XP SP3 which is likely to happen given the other errors that you have reported. Apologies for that since it doesn't address the main problems you outlined. Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 15, 2009 Moderators Share Posted March 15, 2009 Hi michika, and welcome to the forum. First place to start I think is with that service. Go to... Start\Run\ enter "services.msc" (without quotes)\OK. Scroll down to "Cryptographic Services". This should be set to "Automatic" and already running. If not, right click the entry and select "Properties". In the "Startup Type" window, use the drop down menu to select "Automatic", and then OK. Your English is fine by the way. Link to comment Share on other sites More sharing options...
michika Posted March 15, 2009 Author Share Posted March 15, 2009 Hello Robin and Dennis, thx for your ideas, I tried to start the cryptographic services in this and also in compatibble mode but doesn't start, also some other services. I even can't select the properties. What I ask me is what switch caused the system to change all files and how can I rechange it. Must be somewhere in the registry. Have a nice week michika Link to comment Share on other sites More sharing options...
Moderators DennisD Posted March 15, 2009 Moderators Share Posted March 15, 2009 I wonder if there's anything here might help. http://www.updatexp.com/cryptographic-service.html Another mention about RPC service running, which Cryptographic apparently needs to run, and a fix from Microsoft. http://help.wugnet.com/windows/Cryptograph...pict442610.html http://support.microsoft.com/kb/838428 Nothing better at the moment. Link to comment Share on other sites More sharing options...
