CCleaner Community Forums
dawnbreaker
Missing MUI reference
Every time I scan for issues, I get the following message
MissingMUIreference c:\programmefiles\comodo\comodoantiviru\Emgupd\engAutoupd.exe
Reg key HKCU\software\microsoft\windows\shellnoroam\MUIcach
This happens every time I run CCleaner after every session.
Any fix please???
Share this post
Link to post
Hi, Like many Antivirus and Antimalware programs Comodo antivirus probably does not report correctly to the MUI chache, this is done to make it harder for Malware to disable your protection and/or (as in this case) your protection's ability to update itself. It is common to see one or more entries report as missing MUI in regards to your antivirus solution.
If you ARE currently using the Comodo product then you can ignore the entry.
Highlight the Reg entry right click it and choose open in regedit
Go to Options
Exclude
Click the Add Registry button
Choose HKCU from the drop down and type in the key's value (in your case it'll be something like
software\microsoft\windows\shellnoroam\MUIcach\comodo )
Hope that helps
Share this post
Link to post
Go to Options
Exclude
Hope that helps
Thanks for the info but I don't see OPTIONS OR EXCLUDE
Share this post
Link to post
Options is the button just beneath the picture of a spanner when you open CCleaner on your desktop.
Press options and you will then see the exclude Nergal is talking about.
Share this post
Link to post
Thanks for the info........tried that but it doesn't work.
Such is life.
Share this post
Link to post
Use Windows explorer and look for your missing
c:\programmefiles\comodo\comodoantiviru\Emgupd\engAutoupd.exe.
actually, start looking for c:\p*
I think you will find the correct spelling is C:\Program Files.
Similarly proceed through the rest of the path perhaps Comodoantiviru should have a space.
You MAY eventually discover that ...\Emgupd\ does exist, but that it is inaccessible.
Inaccessible folders are one of the "benefits" you get for free with NTFS.
engAutoupd.exe could exist within a folder, and Comodo could know it is there and use it even if its folder is inaccessible.
The folder could be inaccessible due to :-
registry corruption (inevitable "benefit" free with Windows, how I miss *.ini files); or
a side-effect of a battle between Comodo and Malware; or
part of Comodo's self protection.
If you wanted you could probably disable Comodo's protection;
BUT FIRST check on the Comodo forum - I think you could expose yourself to danger and you really need advice before tampering with malware protection.
If it is inaccessible for any reason, then CCleaner will always be told by Windows that engAutoupd.exe does not exist,
and when you clean the MUIcache it will be purged from the registry,
and immediately Comodo next uses engAutoupd.exe then Windows will say "I see you" and dump the reference back in the registry
(why it should do that is any-ones guess - mysteries also come free with Windows !!!).
Regards
Alan.
Share this post
Link to post
Register a new account
Sign in
