Harry07 0 Posted December 1, 2008 Author Share Posted December 1, 2008 Well, yesterday it was D-Day for my PC. I did put the Back-Up back on C. What I saw during the process made me smile a little, all my deleted files popped up again. When it was finished I clicked the IE Button, same Problems! It seems impossible to get it fixed. It could be right, you're not able to turn back from IE8 to IE7 again. I'm not a Pro, therefore need accasionally some help. Regards, Harry Link to post Share on other sites
davey 0 Posted December 2, 2008 Share Posted December 2, 2008 (edited) Well, yesterday it was D-Day for my PC. I did put the Back-Up back on C. What I saw during the process made me smile a little, all my deleted files popped up again. When it was finished I clicked the IE Button, same Problems! It seems impossible to get it fixed. It could be right, you're not able to turn back from IE8 to IE7 again. Only other thing I can think of is At Internet Options > Advanced tab Click on Restore advanced options and try IE. If that does not work then At Internet Options > Advanced tab Click on Reset to reset all IE Explorer settings, etc. Good luck, davey P.S. Other than what YoKenny reports below you may also want to review this MS Blog site. I don't know what was on your system when and if you went to SP3. Note all that is said as regards IE6,IE7 and IE8. http://blogs.msdn.com/ie/archive/2008/05/0...-and-xpsp3.aspx All else fails this IE8 Beta site will be helpful. http://www.microsoft.com/communities/newsg...ng=en&cr=us Edited December 2, 2008 by davey Link to post Share on other sites
YoKenny 0 Posted December 2, 2008 Share Posted December 2, 2008 I think that it is impossible to go back to IE7 after IE8 is installed and I remember reading a warning about it somwhere but I can't find it now. hazelnut to the rescue? I like IE8 on this old PIII as it is quite fast. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to post Share on other sites
Moderators Andavari 2 Posted December 2, 2008 Moderators Share Posted December 2, 2008 You can always go back but it may require WinXP re-install. I think I'd try this as a last resort before formatting and reinstalling, albeit it is a trial program but it "may help." Definitely worth making a restore point before using it though!!! Link to post Share on other sites
Harry07 0 Posted December 3, 2008 Author Share Posted December 3, 2008 Only other thing I can think of is At Internet Options > Advanced tab Click on Restore advanced options and try IE. If that does not work then At Internet Options > Advanced tab Click on Reset to reset all IE Explorer settings, etc.Good luck, davey P.S. Other than what YoKenny reports below you may also want to review this MS Blog site. I don't know what was on your system when and if you went to SP3. Note all that is said as regards IE6,IE7 and IE8. http://blogs.msdn.com/ie/archive/2008/05/0...-and-xpsp3.aspx All else fails this IE8 Beta site will be helpful. http://www.microsoft.com/communities/newsg...ng=en&cr=us Davey, it is not possible to open Internet Options (doesn't work too). Will check those 2 links. I'm not a Pro, therefore need accasionally some help. Regards, Harry Link to post Share on other sites
Harry07 0 Posted December 3, 2008 Author Share Posted December 3, 2008 I think I'd try this as a last resort before formatting and reinstalling, albeit it is a trial program but it "may help." Definitely worth making a restore point before using it though!!! Thanks! I will try this to when noting seems to work/help. I'm not a Pro, therefore need accasionally some help. Regards, Harry Link to post Share on other sites
ugafan412 0 Posted December 5, 2008 Share Posted December 5, 2008 I am having the same problem .... but with mozilla Link to post Share on other sites
Alan_B 0 Posted December 6, 2008 Share Posted December 6, 2008 I am having the same problem .... but with mozilla Ugafan412 It is better to start your own thread, rather than tail-gate a very long pre-existing thread, especially since it is probably that your problems with Mozilla are unrelated to the problem here with IE8. This is also MUCH better for you. Any thread with zero replies is obviously one that needs a solution, and probably has priority. The other threads have been solved, or are in progress, so will be the last things to view. Regards Alan Link to post Share on other sites
Moderators hazelnut 8 Posted December 7, 2008 Moderators Share Posted December 7, 2008 Thanks! I will try this to when noting seems to work/help. Seen a post here http://www.wilderssecurity.com/showthread.php?t=227242 Wondered if it may help CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Moderators hazelnut 8 Posted December 10, 2008 Moderators Share Posted December 10, 2008 Also have you tried installing 1E7 over the top of IE7? Found this also CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Harry07 0 Posted December 11, 2008 Author Share Posted December 11, 2008 Also have you tried installing 1E7 over the top of IE7? Found this also Nice of you to find something like that in Dutch But I'm not able to use this option for know reasons I'm not a Pro, therefore need accasionally some help. Regards, Harry Link to post Share on other sites
Moderators hazelnut 8 Posted December 11, 2008 Moderators Share Posted December 11, 2008 Are you saying you may have a copy of XP which is not legal? CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
Harry07 0 Posted December 11, 2008 Author Share Posted December 11, 2008 Well I've tried about anything and it did not help. So, for fun I tried to download IE8 again. And yes, it works again. Therefore the suggestion "you cannot go back from IE8 to IE7" is 100% right!. I will leave it that way. Now I have a back-up Browser for FF. I'm not a Pro, therefore need accasionally some help. Regards, Harry Link to post Share on other sites
YoKenny 0 Posted December 11, 2008 Share Posted December 11, 2008 Now I have a back-up Browser for FF. Try Opera 10 as it makes FF look as fast as slug crawling over dry concrete. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to post Share on other sites
Harry07 0 Posted December 11, 2008 Author Share Posted December 11, 2008 Try Opera 10 as it makes FF look as fast as slug crawling over dry concrete. Did download it, but unfortunately it's (only?) in English. I'm not a Pro, therefore need accasionally some help. Regards, Harry Link to post Share on other sites
Moderators hazelnut 8 Posted December 12, 2008 Moderators Share Posted December 12, 2008 In opera do tools -preferences, and look at the bottom of the general tab. CCleaner documentation can be found here https://www.ccleaner.com/docs/ccleaner Support contact https://support.piriform.com/hc/en-us/requests/new support@ccleaner.com Link to post Share on other sites
YoKenny 0 Posted December 12, 2008 Share Posted December 12, 2008 I have decided to go back to IE8 on the old PIII as it can use IE7Pro's features that I am accustomed to and its speed is quite acceptable. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to post Share on other sites
greyowl2 0 Posted December 16, 2008 Share Posted December 16, 2008 Try Opera 10 as it makes FF look as fast as slug crawling over dry concrete. Do you think that Opera 10 would be faster than Firefox 3 on a dialup internet connection? I run XP sp3 on a 1.6 Mhz Dell laptop with 512 Ram. I tried Opera a year ago on an older computer and it seemed slower than FireFox 2 at the time. Thanks for the help. Link to post Share on other sites
YoKenny 0 Posted December 16, 2008 Share Posted December 16, 2008 Do you think that Opera 10 would be faster than Firefox 3 on a dialup internet connection? I run XP sp3 on a 1.6 Mhz Dell laptop with 512 Ram. I tried Opera a year ago on an older computer and it seemed slower than FireFox 2 at the time. Thanks for the help. I can't compare it to Firefox but Opera 10 is faster than IE8 on this old PIII Why not give it a try and let us know what you think. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to post Share on other sites
greyowl2 0 Posted December 17, 2008 Share Posted December 17, 2008 I agree. I tried IE7 and it was unbelieveably slow--waiting several minutes for a web page to open sometimes. Link to post Share on other sites
YoKenny 0 Posted December 17, 2008 Share Posted December 17, 2008 waiting several minutes for a web page to open sometimes Last time I waited minutes for pages to open was when I had 33.3Kbps dial-up. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to post Share on other sites
