kaminikij Posted November 18, 2008 Share Posted November 18, 2008 When I run the registry editor I constantly have the same entry for about 2 weeks. It says AC76BA86-7AD7-5464-3428-800000000003 Microsft/windows/current version/App Management/arp cache After upgrading mozilla I had to do an uninstall and reinstall. Also the same with my antivirus software. I wonder if you can help me figure this out and advise me what to do. I have a constant buzz in the PC since. Thanks kaminikij Link to comment Share on other sites More sharing options...
Moderators DennisD Posted November 21, 2008 Moderators Share Posted November 21, 2008 The only thing I can find relating to your query is a possible problem with Adobe Reader. Have you recently installed, or removed this program, or have you had a problem with it? Regarding having to uninstall your AV, that sounds quite serious. Can you provide more details? Have a read here, and see if it relates to your problems. http://www.techsupportforum.com/alternativ...-uninstall.html (Scroll down a little) Link to comment Share on other sites More sharing options...
