swan_x Posted October 30, 2008 Share Posted October 30, 2008 i have used CCleaner with advanced option, tray notification cache-user assist history-IIS log files after cleaner, in my win xp, icon in my desktop not work, my recycle bin is hidden, in all directory "file, modify, favorite..." is hidden, in all directory standard button toolbar disappeared why?????? Link to comment Share on other sites More sharing options...
davey Posted October 30, 2008 Share Posted October 30, 2008 i have used CCleaner with advanced option, tray notification cache-user assist history-IIS log files after cleaner, in my win xp, icon in my desktop not work, my recycle bin is hidden, in all directory "file, modify, favorite..." is hidden, in all directory standard button toolbar disappeared why?????? Hi swan-x, Welcome to the forums. The Advanced cleaning options are installed at "default " settings of "OFF". These cleaning options are for Advanced users for special purposes. Advanced does not mean "better" when it come to cleaning. Turn off those Advanced cleaning options. Many of your settings have now been reset.You will have to reset those settings. We will need more specific information to help you. http://www.ccleanerbeginnersguide.com/ CCleaner Beginner's Guide.com Bookmark and save to Favorites New Users Advice for CCleaner Start here with this link and follow its advice. http://forum.piriform.com/index.php?s=&...st&p=105208 Also see this link about the Registry and newbies. http://forum.piriform.com/index.php?s=&...ost&p=96510 Good luck, davey Link to comment Share on other sites More sharing options...
Keithuk Posted October 30, 2008 Share Posted October 30, 2008 Welcome to Piriform swan_x. Davey that's another reason for having an help file included in the installation package. I know there is online help but if you have no connection for some reason then you're stuffed. That way new users on CC startup could have the option to read the help before using CC. If they don't read the help file then it could be noted in the registry or ini file. That may stop users just clicking all options and running clean. Then they post here with bugs and problems. Or it could give a brief explanation of what each checkbox/option does in a Statusbar or label when the users clicks or just holds the mouse over the object. This as been disgust before but MrG doesn't like adding extra files because he wants to keep the package as small as possible. I would hardly think that 65Kb is going to break the bank. Plus I'm not sure if he knows how to write an help file because TwistedMetal made that one. Keith Windows XP 2002 SP3 IE 7.0 Martin2k Rorshach112 is the best Link to comment Share on other sites More sharing options...
YoKenny Posted October 30, 2008 Share Posted October 30, 2008 This as been disgust before but MrG doesn't like adding extra files because he wants to keep the package as small as possible. Keithuk, I like that Freudian slip. I would hardly think that 65Kb is going to break the bank. I guess dial-up users would object but there are plenty of Download Managers that can handle the extra bytes. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to comment Share on other sites More sharing options...
writeaway Posted October 31, 2008 Share Posted October 31, 2008 Keithuk, I like that Freudian slip. I guess dial-up users would object but there are plenty of Download Managers that can handle the extra bytes. Until recently, I struggled with dial-up. Regardless, I hated having to go online for help and I still do. I never purchase software of any kind that does not come with a good help file. CCleaner is about the only thing on my computer that doesn't have one. So - there's my twopence. Oh yeah. I loved the Freudian slip too Link to comment Share on other sites More sharing options...
Moderators hazelnut Posted October 31, 2008 Moderators Share Posted October 31, 2008 i have used CCleaner with advanced option, tray notification cache-user assist history-IIS log files after cleaner, in my win xp, icon in my desktop not work, my recycle bin is hidden, in all directory "file, modify, favorite..." is hidden, in all directory standard button toolbar disappeared why?????? You could do a system restore to a date just before you did the clean. Support contact https://support.ccleaner.com/s/contact-form?language=en_US&form=general or support@ccleaner.com Link to comment Share on other sites More sharing options...
swan_x Posted October 31, 2008 Author Share Posted October 31, 2008 system restore not work... Link to comment Share on other sites More sharing options...
