Jamin4u Posted September 6, 2008 Share Posted September 6, 2008 Don't byte my head off if this has been suggested before. The first thing I do when I start or restart my computer, is to open CCleaner and minimize it to the system tray. I use it so often, it's as important to me as my Firewall and Anti-Virus running. Therefore, I would like to see this as an option. Online Documentation...CCleaner, Defraggler, Recuva and Speccy Link to comment Share on other sites More sharing options...
StreamlinePanda Posted September 8, 2008 Share Posted September 8, 2008 Hello Jam, You mean that you keep CCleaner open while you use your computer? For the most part, I just use /AUTO shortcut parameters to run it whenever I feel the need. I'd recommend making a shortcut pointing to "C:\Program Files\CCleaner\CCleaner.exe" /AUTO , with the /AUTO extension at the end making CCleaner stealth run whenever you'd like it to run rather than making it stay on as you browse as an idle task, then putting the link either on your Desktop or Quick Launch bar. Cheers Link to comment Share on other sites More sharing options...
Jamin4u Posted September 8, 2008 Author Share Posted September 8, 2008 You mean that you keep CCleaner open while you use your computer? Thats right, I like to see what its cleaning. How many megs, what files, and so on. I may be one of the few that keeps CCleaner open in the tray. I guess its a matter of personal preference. On my Vista system it cuts down on UAC. Thanks for the good idea. Online Documentation...CCleaner, Defraggler, Recuva and Speccy Link to comment Share on other sites More sharing options...
