CCleaner Community Forums
Ad-Aware Update Problems
tommyk
Has anyone had a problem downloading the latest definition update for Ad-Aware. I keep locking up and then get a message stating a corrupt file.
Thanks
tommyk,
I have updated to SE1R53 dated 07/07/2005 without any problem. As far as I can tell this is the latest update and mine went fine.
Hope you get it worked out,
Normandie
Link to comment
Thanks
tommyk,
I have to take back my "I didn't have any problems", :unsure: in a previous poste. I came into the office today and tried to update the computer here and it would not work. I ended up by having to download the file on their site and install it myself. Have no idea what the problem is.
Have a good day,
Normandie
Link to comment
tommyk,
Have a good day,
Normandie
DELETE PREVIOUS DEFS.
C:\Program Files\Lavasoft\Ad-Aware SE Personal
delete "defs.ref" and don't worry you'll get it back through update. then
open ad-aware> you'll get warning
"Error while loading the Ad-Aware definition file"
click ok> Ad-Aware opens>click check for update. it works 100%.
Link to comment
berdy,
When I saw your previous post I tried it, did not work, the only way I could get it to work is to download the "defs" from their site and install them myself. Thanks anyway for the suggestion.
Have a good day,
Normandie
Link to comment
Hi Normandie
Strange! it always works for me. I tried it just right now and it worked.
BTW. have you used any reg cleaning program recently.
berdy,
Just CCleaner as usual. When I downoaded the ZIP from their site and installed it manually all was fine.
Have a good day,
Normandie
Link to comment
Hi
I know . manual update works for all programs not ad-aware only. For example I do manual update for Ewido always because I use it uninstalled (through USB flash).
but I'm thinking that the reg link to ad-aware folder could be corrupted.
can you please try it now. and see. if it doesn't work you can restore the defs from recyclebin. thanks
Link to comment
berdy,
Have a good day,
Normandie
berdy,
On the computer I am working with right now your system worked fine. I will have to wait and try it on the other computer at the office tomorrow. That is the one that would not update this morning.
Have a good day,
Normandie
Link to comment
Register a new account
Sign in
Important Information
