Mixalis Posted August 1, 2008 Share Posted August 1, 2008 I have a problem when I copy ccsetup210.exe from the computer in my usb flash drive. The problem is that the file that I copied in usb flash drive I can not install it. When I try to install it it show me this message "Error launching installer", but the file in the computer can install it normally.I download the CCleaner from a internet cafe because I do not have internet in my home. Can any one help me? Sorry for my english Link to comment Share on other sites More sharing options...
CeeCee Posted August 1, 2008 Share Posted August 1, 2008 So you mean, that you can't run it from the flash drive? Just copy the installer file to hard drive and run then. Path Copy TeraCopy Unlocker Link to comment Share on other sites More sharing options...
Mixalis Posted August 1, 2008 Author Share Posted August 1, 2008 So you mean, that you can't run it from the flash drive? Just copy the installer file to hard drive and run then. I have try but dosent work Link to comment Share on other sites More sharing options...
CeeCee Posted August 1, 2008 Share Posted August 1, 2008 I have try but dosent work Use CCleaner Portable: http://www.CCleaner.com/download/builds/downloading-portable CCleaner Portable description The normal CCleaner program, but it doesn't require installing To install CCleaner Portable extract the ZIP file to a folder of your choice on a flash drive or burn the files to a CD or DVD. Start the CCleaner by double-clicking on portable.exe instead of CCleaner.exe and use CCleaner normally. Path Copy TeraCopy Unlocker Link to comment Share on other sites More sharing options...
YoKenny Posted August 1, 2008 Share Posted August 1, 2008 Use CCleaner Portable: http://www.CCleaner.com/download/builds/downloading-portable I use that and it works well. I have WinPatrol on the same Flash drive so that I can install it before I leave. "Education is what remains after one has forgotten everything he learned in school." - Albert Einstein IE7Pro user Link to comment Share on other sites More sharing options...
Mixalis Posted August 2, 2008 Author Share Posted August 2, 2008 Finally the problem was the computer. I download the CCleaner from another computer and operates normally Link to comment Share on other sites More sharing options...
