lovejoy Posted July 2, 2005 Share Posted July 2, 2005 Could someone please tell me how to update CCleaner, in the simplest language please I'm fairly new to this. Thanks. Link to comment Share on other sites More sharing options...
Capman Posted July 2, 2005 Share Posted July 2, 2005 Could someone please tell me how to update CCleaner, in the simplest language please I'm fairly new to this. Thanks. <{POST_SNAPBACK}> In the very bottom right hand corner of CCleaner, you will see "Check for updates now...", Click it and you will be taken to a website which will state whether or not there is a newer version, if there is you will have the option of downloading it. Once downloaded, double click the installation file, (there is no need to remove previous versions first), and the new version will be installed. Hope this helps. Link to comment Share on other sites More sharing options...
lovejoy Posted July 2, 2005 Author Share Posted July 2, 2005 In the very bottom right hand corner of CCleaner, you will see "Check for updates now...", Click it and you will be taken to a website which will state whether or not there is a newer version, if there is you will have the option of downloading it. Once downloaded, double click the installation file, (there is no need to remove previous versions first), and the new version will be installed. Hope this helps. <{POST_SNAPBACK}> That was easy enough thanks CaPMan, just one more question when installation is complete when you have clicked on "finish" you are left with a little blue icon on your desktop (the icon you click on to start the install) Can I now bin this? Link to comment Share on other sites More sharing options...
Moderators rridgely Posted July 2, 2005 Moderators Share Posted July 2, 2005 Yes you can delete the installer icon. Link to comment Share on other sites More sharing options...
lovejoy Posted July 2, 2005 Author Share Posted July 2, 2005 Yes you can delete the installer icon. <{POST_SNAPBACK}> Thanks rridgely. Link to comment Share on other sites More sharing options...
