CCleaner Community Forums
CCleaner Slim download problems
NewScience
Each time I try to download the slim version of CCleaner, the connection eventually is reset by the download server. My network connection stays up, but the connection is reset.
The data transfer rate starts at 5Kb, then goes to 3Kb, 1Kb, 950bytes, ... eventually sometimes to 700 bytes ... and then quits. I once got to 73% downloaded but it still quit.
What is going on?
My dial-up: 28.8 (never had problems before)
Windows 2000 SP4
64MB Ram
This is happening on multiple OS on this same PC (win95, 98, Me 2000).
Link to post
What is going on?
Windows 2000 SP4
64MB Ram
Hello,
This link helps fix many install problems for older OS. http://forum.piriform.com/index.php?showtopic=5739 Don't forget to Reboot(important)
Also note that Win95 is not supported by CCleaner.
Good luck,
:) davey
Link to post
Are you downloading from the CCleaner site?
Here:
I've just tried it and it seems fine. Maybe a lot of traffic or a hiccup with your ISP.
Have another try at that link.
Yes: ... http://www.CCleaner.com/download/builds/downloading-slim
Today somehow everything is cleared up (after 2 days). My transfer rate is 3.12Kb/sec
So something has changed dealing with the CCleaner download server
Link to post
Hello,
Good luck,
:) davey
I'll keep this in mind when I have an INSTALL problem. Since my problem entailed DOWNLOADING the package ... this does not pertain to me.
Link to post
  • Moderators
Who knows for sure, although I don't envy you still being on dial-up. You should probably find yourself a good freeware or open source download manager to help get those pesky files that don't want to finish when downloading from within a web browser. I'm on DSL and still find them useful sometimes! ;)
Link to post
Archived
This topic is now archived and is closed to further replies.
