mastavic Posted May 19, 2008 Share Posted May 19, 2008 Hello, I have been using CCleaner for years, but never added it to the Recycle Bin. I was just wondering what the following options do and what their differences are: -Add "Run CCleaner" option to Recycle Bin context menu -Add "Run CCleaner..." option to Recycle Bin context menu Do these functions do the exact same thing as running CCleaner by loading up the program through typical ways, such as from All Programs or from CCleaner's *.exe file in Program Files? Thanks. Link to comment Share on other sites More sharing options...
Disk4mat Posted May 19, 2008 Share Posted May 19, 2008 I just added CC to the Recycle to see what it does. You have 2 menu items. Open CC which simply opened the program and Run CC which runs CC minimized in the sys tray and performs a cleaning (without user interaction). Link to comment Share on other sites More sharing options...
CTskifreak Posted May 20, 2008 Share Posted May 20, 2008 I've done it from the beginning. It is easier than opening up the program to clean. It just goes by your saved settings, so its quicker. Just two clicks and done. AJ Link to comment Share on other sites More sharing options...
mastavic Posted May 20, 2008 Author Share Posted May 20, 2008 Ah, thanks for letting me know. I initially thought it had something to do with the Recycle Bin - perhaps clean the Recycle Bin and clear it of more sensitive items or something - but it didn't seem to say anything like that, which is why I asked. Thanks again. Link to comment Share on other sites More sharing options...
